Old 10-20-2010, 08:40 PM   #17731
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
try a different cap,are the wires getting hot or warm
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-20-2010, 08:43 PM   #17732
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
You mean there is a small cracking sound when you plug your batteries in coming from the plug?
Thats good that is your cap discharging.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 10-20-2010, 08:57 PM   #17733
big al's Avatar
the spark can be seen and heard. I don't have any heating of the wires at all. There isn't any smoke or anything that seems dangerous. It's done this since I've owned it and the esc works perfectly.
big al is offline   Reply With Quote
Old 10-20-2010, 09:02 PM   #17734
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
That is just the cap taking its charge, no problem.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-20-2010, 09:10 PM   #17735
tallyrc's Avatar
Originally Posted by tallyrc View Post
couple q's.. i'm sure this has been asked but the search seems to never work these days.. first.. certainly the default deadband of 56 is not % of total throtle so what is it? a percentage of somethign else? and with deadband in the modern radios should either the radio or esc be set at "0"? also.. are out base setups from 208 a good starting point with 212? excited to give it whirl this weekend..
i'll try it again..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 10-20-2010, 09:19 PM   #17736
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Randy_Pike View Post
Greg make sure you're setting your LVC to 1s. The chime is created by the motor so do you have your motor hooked up?
Nuetral width is the "window" in which we wil accept a calibrated nuetral.
i'll try it again..
See above post?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 10-20-2010, 09:20 PM   #17737
georgec's Avatar
Had my RS updated this afternoon before practice by the track owner and I think I like 212 better than 208. Braking is much improved and overall has a smoother feel, as for top speed I could tell no difference.
Thanks Tekin for a great product and excellent support!
georgec is offline   Reply With Quote
Old 10-20-2010, 09:34 PM   #17738
Default 208 cannot update to 212
Maybe it is just me, but my RSpro 208 cannot be updated to 212. I have download and installed hotwire212 onto my PC. The 208 software uninstalled and the new version prompted to update the ESC when plugged in.
When all the steps are completed (with 212 updated confirmation) the hotwire interface popped up, it shows all the options etc... (like normal). However, when I unplugged the ESC and replug into the hotwire, hotwire again prompts to update again saying that my ESC needs to be updated with a newer version. I have tried this like 10x with no luck.
I reinstalled 208 onto the PC and the hotwire 208 detects the ESC with 208 firmware.
Apparently, my ESC did not get updated with the 212 software although it confirmed that it should. Again, I have reflash and reflash like 10x but still cannot find a solution.
Is there anything I am doing wrong? Please help!
Note: I have updated v198>v200>v203>v208 with NO problem before.
Many thanks!
And keep up the good work, Team Tekin!
hardmankam is offline   Reply With Quote
Old 10-20-2010, 09:54 PM   #17739
tallyrc's Avatar
Originally Posted by bukil View Post
See above post?
thanks, that didnt answer them.. sorry to have bothered you
Old 10-20-2010, 11:16 PM   #17740
rambolin's Avatar
Default 212 - settings not updating in ESC
Hi
Settings do not update - I am getting the message '..install the newest version..!'. I am using Windows 7. Help appreciated.
rambolin is offline   Reply With Quote
Old 10-20-2010, 11:46 PM   #17741
rambolin's Avatar
Default Re 212 - settings not updating in ESC
Hi
Further to my post above - my ESC does not work at all any more. Still being detected on HotWire but no lights once on battery.
HELP
Old 10-21-2010, 12:02 AM   #17742
do you still have install program for 208 ?
may pay to go back and flash it again with that and then try 212 after that...
ed
Edwin Pibal is offline   Reply With Quote
Old 10-21-2010, 12:07 AM   #17743
Originally Posted by rambolin View Post
Hi
HELP
My ESC also has some problems updating to v212 as mine does not flash to v212 and being 'stuck' on v208.
You may try to re-flesh to v208 first and see if it works.
Old 10-21-2010, 12:11 AM   #17744
twk-b's Avatar
Send a message via MSN to twk-b
Default ah, amazing temperatures?
Ah, so after jumping back into touring car after the summer break, I updated to 208, and setups that used to be pushing the limits temperature wise (150+) are all coming off at 90-100C. B=45 T=10, delay=0.05 ramp=2 5000-9000
I tested both 17.5 and 13.5 with ORCA motors... just a heat sink...
It was a new track layout, so I was unsure on the gearing... I tried a couple teeth each way and my times didnt seem to waiver much either way. Previously with two teeth up, it should have been ready to cook a meal but never over 110.
It seemed there were similar results up and down the pit lane....
No track time between now and race day.. so was hoping to find the follow...
1) With the reduced temperatures are team drivers (and others), making new changes (gearing, RPM gap, etc) to the setups to bring the temps up again, or everyone is just sitting at 100C now in TC? ramp=3 was pretty much off limits from my experience in TC. with the new temps that seems like something worth retesting?
2) With 203 it seemed that boost really spooled up, and was most noticeable in the last 1/3 of the straight almost leaping ahead.... With 208 things seem much more linear which is great, but it doesnt seem to have the same top end.... (b) is this related to "203 level rpm schedules" in 212?
3) What all is recorded with the 2 Custom Profiles? Thottle Profile, drag/push and some other settings also change between classes, are these values stored for each, or shared for all profiles? (Super Stock, Stock, VTA)
I am totally blown away by the temps! Thanks for providing a great product. Keep up the great work!
-b
twk-b is offline   Reply With Quote
Old 10-21-2010, 12:16 AM   #17745
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're having a hard time getting your 212 to update do a factory reset on the unit, try again.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
