Tekin RS ESC sensored
The fact that the ESC was/is ROAR legal should tell you enough about the loyalty Tekin has to its customers...
Does it really matter what the answer is? If they say "no" you all will accuse them of lying and cheating. If they say "yes" then they are cheaters as well. What difference does it make one way or the other? They have answered the question as best they can/want to and if its not good enough then move on to another brand if that answer doesnt satisfy you.
EA
EA
if the sanctioning body feels that 208 was not within the sporting reg, then they should do something about it in the results. 208 was run at on-road nats if I am not mistaken. I have not seen the results change for that race. the IIC is scotty's race. 208 was legal for spec in that class as well. I have seen no adjustments in the results.
lets move on.
lets move on.
lets move on.
lets move on.
I second that
EA
EA
Yes !
If they say no you will accuse them of lying and cheating.
How do you know that ?
What difference does it make one way or another ?
If you don't know, well ....
They have answered the question the best they can/want to ....
Is that good enough for you ?
Like I said I race at a very competitive track and I spend alot of money to go as fast as I can and now because of Tekin dodging the question of timing in the 208 I will forever be asking the question after the race, 'are you running 208 or 212' ?
Does it really matter what the answer is ?
Yes !
Yes !
Randy has said enough to you ppl I dont understand why you ppl keep carrying on!!!
No results will change for the same reason that you can't outlaw any cheating manufacturers from competition for a year, like someone wanted to do earlier in the thread.
ALL racers are the victim when putting their trust in the manufacturer to provide something thats legal, whether it be motors, batteries, or ESC software. It doesn't only effect the nonusers who see the disadvantage on the racetrack.
In the case of IIC, and whether Tekin's software had advance or not, you'd be expecting everybody in a Sportsman class to test their ESC's with oscilloscopes if you wanted to DQ them. That's IF the software had timing in it. It was ROAR approved and that's all the knowledge a racer is supposed to require in bringing a car that's legal to tech.
There simply isn't a method currently in place to penalize a cheating manufacturer, that doesn't also penalize the victims.
Team EAM
Yes !
How do you know that ? Because of how some people are acting on here....thats what they are looking for.
Is that good enough for you ? I know the answer....but me stating what the answer is still wouldnt shut some people up!!
Yes !
Like someone else said if you are at a ROAR race you wotn have to worry about it. I know my track has already stated once released you can not run 208 in limited class anymore. And after running both I can tell you that there's no reason to want to run it.
EA
where do you down load the 212????
[QUOTE=jjfo80;8098413.... if its not run under roar rules and its at your local track its up to you... [/QUOTE]
Your right, it is up to me and that's why I'm on hear trying to get an answer.
Team EAM
EA, you say you know the answer.
Why don't you go on record and tell us if there is more then zero degree timing in the sportsman spec profile ?
Let's set this record straight. Tekin chose to make 212 the ROAR approved software. We CHOSE to change the led's so ANYONE can see that the user is using 212.
The ROAR paved nats spec class was won by an LRP TC SPhere Comp, I know I was there.
At the IIC the majority of the guys running spec were already running Tekin. Why WOULD they switch if they already have it and know how it works. We dominated nearly EVERY stock anything class at that race spec or not.
The team has ran 208 vs. 212 already and told you there is no difference. Tekin has always used superior components and superior assembly techniques. A quote from a ROAR member " You can't blame them for building a better mouse trap" un-named.
Move on.
Guys we're still working on the server. If you need 212 right away hit me up on Live Chat I can give it to you there.
Move on.
Randy, thanks again for the software via Live Chat.. much appreciated.
-Mark
-Mark
