Old 10-16-2010, 07:28 PM   #17476
Low_E's Avatar
Send a message via MSN to Low_E
Sorry for the noob-questions. I have no experience on 1/12, only on 1/10.
I have both a Tekin RS and an Rs Pro
Can one or both of these ESC's be used in a 1/12-car?
Can they run on a 3.7V lipo (or does it/they need a voltage-booster)?
if no need for a booster, will it or they provide 6V for the receiver and servo?
thx!!
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 10-16-2010, 07:28 PM   #17477
dzstr's Avatar
Trader Rating: 20 (100%+)
Originally Posted by 20 SMOKE View Post
ps,if the release is to the team in the next week and you could through a helpful non tekin driver(hint hint wink wink) a early release i have our next state race next weekend and would like to test 1s wgt.ha ha
Send it to him right after the race on Sunday. Jamie are you racing tomorrow?
dzstr is offline   Reply With Quote
Old 10-16-2010, 07:40 PM   #17478
Regional Moderator
CarbonJoe's Avatar
thx!!
You can run either in 1/12 scale, but you will need either a Rx pack of voltage booster, since the ESC can't boost the voltage to the servo/transponder. Just plug the Rx pack or booster into your Rx. If you want to use the LiPo cutoff, leave the ESC switch on. If not, leave it off.
I use a switch inline with the Rx pack + lead to the receiver to make/break the circuit so that the LiPo Rx pack can be shut off.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-16-2010, 07:42 PM   #17479
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
no,right know i am only doing the state series,next month i will since there are a few races i am not going to
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-16-2010, 08:44 PM   #17480
pakk's Avatar
Trader Rating: 79 (100%+)
thx!!
If you are going to use an RX pack, make sure you are not using 2s lipo(8.4v) strait to the RX. You will damage your ESC.
Here are the approved methods if I remember right.
1. Booster
2. Regulated Voltage
3. 2s LiFe RX pack
4. in line switch mod
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-16-2010, 09:01 PM   #17481
pakk's Avatar
Here is the link to the thread.
http://www.rctech.net/forum/electric...packs-bad.html
*Photon* *SC10 4x4*
RCRD
Old 10-16-2010, 09:12 PM   #17482
STLNLST's Avatar
Trader Rating: 21 (100%+)
Team Tekin wins 17.5 at the 10th annual Speedworld Cup in Roseville. The RS/Redline combo was the hot ticket. Had an awesome time and fun with my fellow racers bench racing in the pits. Tekin will be taking the show on the raod to Ripon RC Speedway next weekend. If you're in the area come out and rub some lexan with us.
STLNLST is offline   Reply With Quote
Old 10-16-2010, 11:11 PM   #17483
darrenoakley's Avatar
Great speedo for 1s 12th. I use the Novak smart boost with the lipo protection removed.( simple snip the thing off of the pcb) it also has an in built switch. I know there has been issues with the lipo protection on it but once it has been removed it is great. Tekin is the way to go for 12th though mate.
Just in the process of selling the hobbywings to get another RS much better as rpms can be limited.
iPhone app would be amazing though.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 10-16-2010, 11:12 PM   #17484
pakk's Avatar
Please share on how to remove the lipo cut.
*Photon* *SC10 4x4*
RCRD
Old 10-16-2010, 11:18 PM   #17485
speed-e's Avatar
Trader Rating: 28 (100%+)
What exactly is to be simply snipped off to remove the lipo protection? Please share
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 10-17-2010, 06:05 AM   #17486
hope this helps thanks to novak for supplying it on request. Attatched pdf guys
Xray x11
Xray T3 011
Old 10-17-2010, 06:19 AM   #17487
20 SMOKE's Avatar
now you make sense,your post was a little short
Jamie W
Old 10-17-2010, 06:20 AM   #17488
From what i understand , if you use a booster then you turn the speedo off then the lipo cut off doesnt work
you just use the booster switch as the main switch for the car
I have used my RS in my new Corally with the Corally Vboost and it works perfectly and no Lipo cut off\
I think it isn't a good idea opening speedos and cutting things out of it !!!
Not something i will be doing
sidecarphil1 is offline   Reply With Quote
Old 10-17-2010, 06:26 AM   #17489
pakk's Avatar
we're talking about cutting the LVC out of the Novak Smart boost, not the Tekin RS.
*Photon* *SC10 4x4*
RCRD
Old 10-17-2010, 07:10 AM   #17490
jjfo80's Avatar
hey guys I have read thru a few pages but havent came across this as yet.
I have a futaba 2.4ghz stick radio with a 603ff rx running with a tekin rs and a simple johnson 540 silver can. I am teaching a new guy about learning how to gear a engine and driving style as the engine is very forgiving for treating it like shit and still working but heres my problem,
I have the hotwire and updated the firmware to vegas 208 set the transmitter trims and sub trims all to zero and 100% where they need to be. Cal'ed the tx to the speedo and the speedo is getting full brake signal and full throttle signal but heres the catch. I have full throttle but the engine is not getting full brake even tho the lights on the speedo is telling me it is by scaling down and then flashing all the lights to say yes I have full brake.
I went to the hotwire and set everything up by having 100% brake strength no push control and a custom throttle profile. and still the same thing.
But if I move the brake strength to 0% I notice the engine doesnt even think of wanting to try and slow down but put it back to 100% and you can here the engine wanting to slow down but no where near strong enough to stop the car.
Can anyone point me in some direction please.
Cheers
Ian
Owner of Precise Fuels and RC and Podified Fuels
jjfo80 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
