Old 10-14-2010, 11:39 PM   #17431
Hi, if you buy the rs esc by itself tt1152 does it come with a sensor wire? Thanks.
rayrush is offline   Reply With Quote
Old 10-15-2010, 12:05 AM   #17432
HarryLeach's Avatar
Send a message via AIM to HarryLeach
No.
The Tekin motors come with a sensor wire though.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 10-15-2010, 12:53 AM   #17433
Old 10-15-2010, 02:00 AM   #17434
question:
if the turbo delay set to 0.0, and set boost start rpm high...
what happen when i punch the throtle from stop (low motor rpm),
is the speedo will apply boost timing+turbo directly or not before start+end rpm sequence done then the turbo kick in..
QDriver is offline   Reply With Quote
Old 10-15-2010, 02:30 AM   #17435
Skitee's Avatar
Originally Posted by QDriver View Post
question:
With your setup using the zero turbo delay when you punch the throttle, the esc will start applying TURBO immediately and when you get to your start rpm only then will the BOOST TIMING be added through your set rpm range.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 10-15-2010, 04:40 AM   #17436
Thanks for the suggestions, guys. I will try that next time at the track.
I thought that I should keep timing below 62-65 degrees - but as far as I can hear, this rule is BS?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-15-2010, 06:00 AM   #17437
Tread1's Avatar
Trader Rating: 18 (100%+)
Any news on the ROAR approved sportsman fix?The Halloween classic is just a week away.
"If you just want to bitch well, feel free to post here on RC Tech and look like the other 95% of the illiterate posts that are written here."---- ROAR ExCom member
Since when does 0=9?
Tread1 is offline   Reply With Quote
Old 10-15-2010, 07:23 AM   #17438
M-Technic's Avatar
Trader Rating: 15 (100%+)
question:
My problem with setups like this is that if you are at low speed and not at full throttle you are getting no boost/turbo at all. It seems like that would make for a jerky setup in tight infields.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-15-2010, 07:35 AM   #17439
Senna Racing's Avatar
+1
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 10-15-2010, 10:05 AM   #17440
Chaz955i's Avatar
Interested to hear what the deal is.
Hopefully not that the level playing field sportsman is supposed to be hasn't been that level after all.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-15-2010, 10:19 AM   #17441
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
It should be posted here today or Monday. Its all been taken care of. Chicky should have info by now if not then by the weekend.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-15-2010, 10:23 AM   #17442
avs
avs's Avatar
as far as equivalent endbell timing, what i could gather so far from posted settings:
bodine's spec 1/12 and wgt setup with duo2 at 20.
hara's boosted tc with duo2 at 8.
maybe a duo2 at 8degrees compares to tekin at 0?
and duo2 at 20degree suggests tekin at 12?
X12 4dot is similar to tekin at 0
so a 2dot or 1dot X12 is similar to duo2 at 20 and tekin at 12
so a starting timing settings for a zero-timed spec class might be:
duo2 at 20
tekin at 12
X12 2dot or 1dot
one obvious flaw in this logic is duo2 at 20 is also max timing, so it isn't clear whether more than 12degrees on the tekin isn't worth going after.
any advice or experience on endbell timing for this spec class is welcome.
Tony Shimko
avs is offline   Reply With Quote
Old 10-15-2010, 01:24 PM   #17443
timmig's Avatar
Trader Rating: 25 (100%+)
Default 1/12 scale 17.5 setups??
Hi,
There's only one software 208 1/12 scale setup on the Tekin website--and it's for 13.5. I started there. But---does anyone have a really good setup for 1s/ 1/12 scale on carpet-- Tekin Rs in an associated car--Novak 17.5 motor w/ stock endbell timing? I'm racing this weekend and a call to Tekin got me no help at all. Just -
"email" Randy Pike. But when I did that---I got an auto-response saying he wouldn't get back RE: sponsorship for 4 to 6 weeks!!!
NO one could answer any questions at Tekin---then--"try the chat room"!! NO ONE THERE EITHER!!! Geez---it's a simple question about their products?
Help!!!
Tim
timmig is offline   Reply With Quote
Old 10-15-2010, 02:12 PM   #17444
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
duo2 at 20
tekin at 12
X12 2dot or 1dot
well i can say that my 12th setup with a redline 13.5 compared to others that have duo2 is that they need 15-20 more timing and gear just to keep up and the same with the x12.i run no turbo setups with redlines and the murfdogg 13.5 and others use turbo and motor timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-15-2010, 02:25 PM   #17445
TrevCoult's Avatar
Originally Posted by timmig View Post
Hi,
Help!!!
Tim
First, there are four 208 12th scale setups on the Tekin web site, not one as you say. There is one 17.5 spec, two 13.5 and one 10.5 (mine). Several have been recent additions so you may have missed them.
You don't say whether you want a stock setup or a timing setup. If you want a stock one try Brian Bodine's. If you want a timing setup, 208 setups are still pretty similar to 203 setups, so try Yang Lai's setup from the web site.
If you are prepared to search there have been several setups posted on this thread too.
Hope this helps.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
