Old 10-10-2010, 10:34 PM   #17401
san.'s Avatar
Trader Rating: 60 (100%+)
It was the 2nd post of the previous page.
Originally Posted by JayBee View Post
Just had to buy a new speedo @ the TimezoneII GP and got myself the TekinRS Pro. I'm extremely late to the game. Kenny Lambert helped me out tremendously. But naturally I still have alot of questions....is there any 'definitive' guide that defines for me what the different parameters DO?
Please don't flame me guys Just don't feel like reading through TONS of pages here....
- JB
Originally Posted by TrevCoult View Post
Read the timing section of the article here.
http://www.carsrcracing.co.uk/?p=244
Should explain it.
Trev
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 10-11-2010, 05:51 AM   #17402
Does any one have a good setup for a novak ballistic 13.5 in an xray T2 009 for indoor carpet racing using sorex tyres
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-11-2010, 05:55 AM   #17403
Default holy phuk
wow, 1,161 posts on this thread!!!
anyways is there thread for tekin redline motor range?
or is this thread used for the motors too?
DEIGIMA is offline   Reply With Quote
Old 10-11-2010, 06:07 AM   #17404
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
motors to
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-11-2010, 08:42 AM   #17405
Clint161's Avatar
Default Timing profile 1
What kind of FDR's are you guys running with stock no boost profile. I'm looking for a track with a 75 foot straight. 17.5 1/10 TC.
Clint161 is offline   Reply With Quote
Old 10-11-2010, 09:00 AM   #17406
Regional Moderator
CarbonJoe's Avatar
3.75 - 4.0
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-11-2010, 09:02 AM   #17407
pakk's Avatar
Trader Rating: 79 (100%+)
That's 1161 pages. This reply would make 17407
I think the track I race at has a little bit of a longer strait. Yesterday I was geared at 3.85. Other people at the track were geared anywhere from 3.4-4.1. I'd start at 4.0 and adjust as necessary.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-11-2010, 11:03 AM   #17408
Kuttermax's Avatar
Make sure you check forward and reverse speeds with the Novak Ballistic. I had major problems with Ballistic motors with my RS (reverse faster than forward) that are referenced a number of pages back and in this video.
http://www.youtube.com/watch?v=CJWiwi4Nqt0
The problem went away after I switched to a Tekin Redline BL motor.
Kyosho RB5 SP2 and SC-R
Traxxas Slash PE 4x4 and E-Revo BL
Tamiya Egress, RC10
Hometrack: http://www.crcrc.com
Kuttermax is offline   Reply With Quote
Old 10-11-2010, 11:44 AM   #17409
san.'s Avatar
Originally Posted by EAMotorsports View Post
Just a simple error...its being sorted out now.
EA
Originally Posted by Chaz955i View Post
Hi EA,
Any detail what the error was related to? Seems kind of weird that ROAR would have an issue if this was something that fell outside of the requirements for a approved spec setting. Not trying to put you on the spot but for the sake of transparency it would be interesting to know what exactly ROAR was concerned about.
Thanks,
Chuck
According to ROAR's status, they're awaiting a new software update. By the lack of information being provided, it seems that the 208 No Timing profile wasn't in spec to begin with. Or, you can get the blinky by setting other options besides the No Timing profile.
The good news is, the revised software should be ready by Cleveland?
Old 10-11-2010, 11:54 AM   #17410
I'm using a Ballistic 17.5 with Hara's IIC settings and that thing screams. Timing on the motor is slightly + of N on the can. ONly problem I had with the ballistic was when I tried to turn the motor timing way down.
Carter
darcydawg is offline   Reply With Quote
Old 10-11-2010, 07:03 PM   #17411
doriftu's Avatar
I need help...
When I connect the batts and switch on my RS Pro, it does not light up and chime.
The fan and transponder are working. I checked all the connections and all are well.
I was using a 17.5 with zero timing.
It was doing great in the qual heats and by the time the last final, it went dead.
Any clues from you guys?
Thnks.
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 10-12-2010, 09:03 AM   #17412
BoneCrusher's Avatar
Not sure if it's been asked before, but if I wanted to use Hara's settings for 17.5 Superstock in a Novak Ballistic instead of the Duo 2 he used at the IIC, with all things being equal, what would you change to not fry the motor (motor timing, ESC settings)?
Then, if I wanted to tone the settings down again cause i'm nowhere even close to his throttle control, what would i modify (gearing, rpm range, boost, turbo)?
Thanks,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 10-12-2010, 09:13 AM   #17413
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks,
Ivan
Hara's ESC settings are pretty safe. I would first start with lower motor timing, and perhaps work with the gearing as well.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-12-2010, 09:47 AM   #17414
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hara's setup isn't that forgiving. Make sure you have your gearing down BEFORE you turn on the turbo. Not doing so can ruin a motor.
For the orange motor setup it up to be -5 from the N mark. This will get you close to Hara's Duo2 setup.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-12-2010, 10:59 AM   #17415
I eased up to Hara's settings and I don't drive quite as hard he does. Thanks for the motor setting tip.
On that note, do you have a Redline motor setting for Donny Lia's 13.5 12th scale settings?
Thanks,
Carter
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
