Old 12-18-2008, 09:42 PM   #1726
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Nice car Bob.
Well little personal tidbit about me that Ty knows but most don't is that for the last decade I've been with Dodge/Chrysler in the tech department. Trust me, I like Dodge much better as well.
Hemi! Do we need to say more?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-19-2008, 05:56 PM   #1727
Trader Rating: 35 (100%+)
Josh Keller is offline   Reply With Quote
Old 12-20-2008, 02:21 PM   #1728
i have updated some one els his Tekin RS pro from 180 to 189.
Damn wath a speed. The car was verry fast. (fastest car on the track)
I drove mine in the 183.
The thing that i want to cange is the acceleration.
It is in nr 5 a litle bit to agressife. in nr 4 it is a litle bit to slow for me. The gap is to big for me.
I was faster with the acceleration at 5. Only it was harder to keep the car good on the track.
Also i have changed the pinion from 24 to 23. This made the car a bit faster and kept the motor under the 60degrees Celcius.
It was a good practice but i hope that my speedo will work also on the 189. I want that speed also
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-20-2008, 03:41 PM   #1729
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Hey guys just got my new RS. Had a question about the wiring? I am running a brushed motor and to do it you have to run 3 wires into 1. Instead of doing it that way can you just jump the 3 together at the posts and run 1 wire back? In my thinking its the same. But not pysically the same..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 12-20-2008, 04:09 PM   #1730
Yup, you can wire it up that way without any problem for brushed.
Fred_B is offline   Reply With Quote
Old 12-21-2008, 01:44 PM   #1731
C van der Hagen's Avatar
Originally Posted by TRF415boy View Post
Run it in sensored only mode and turn the timing on the motor to the max.
Is this possible without hotwire?
C van der Hagen is offline   Reply With Quote
Old 12-21-2008, 02:34 PM   #1732
no you need the hotwire.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 12-21-2008, 04:19 PM   #1733
Trader Rating: 26 (100%+)
im having a problem, when the car accelerates from a dead stop it stutters badly then about 15ft it goes away. heres my setup, anyone with ideas much appreciated
12th scale rs pro 17.5 tekin nihm
no drag
limiter off
profile 3
brake %5
sesored only mode
motor timing max
what ive tried so far
motor(tried a 13.5 much worse)
sensor wire
re setup rs pro
eddie10 is offline   Reply With Quote
Old 12-21-2008, 04:21 PM   #1734
shadow102's Avatar
Trader Rating: 21 (96%+)
no drag
limiter off
profile 3
brake %5
sesored only mode
motor timing max
sensor wire
re setup rs pro
are the sensor lights lighting up?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 12-21-2008, 05:07 PM   #1735
yes they are
Old 12-21-2008, 05:28 PM   #1736
CCristo's Avatar
Trader Rating: 55 (100%+)
What firmware version? Can you test it with a 6 cell to see if the problem goes away?
CCristo is offline   Reply With Quote
Old 12-21-2008, 05:33 PM   #1737
i beleive its 189 ill check it
Old 12-21-2008, 05:43 PM   #1738
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
If it is, do you also have the "turbo boost"? How much motor timing do you have, max?? If you have the boost on and more then 6 deg. motor timing it's too much total timing and probably overgeared. With the Tekin 17.5 at zero timing and max in speedo you would want to start about 3.00" roll out for a 90 x 60 track. Smaller tracks go down to 2.90" rollout. The stuttering should go away. When I first started with the boost and motor timing I had the same problem.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-21-2008, 05:46 PM   #1739
sorry its 180 firmware wth sesored only box checked
Old 12-21-2008, 05:50 PM   #1740
sg1
sg1's Avatar
That's still high timing, What roll out did you have? How hot was the motor?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
