Old 10-07-2010, 04:18 PM   #17341
nashrcracer's Avatar
R/C Tech Charter Subscriber
someone tell Randy to hurry up
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow — never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long — you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 10-07-2010, 05:57 PM   #17342
CanyonCarverR1's Avatar
I don't see any 1/12 1S setups on the Tekin site. Where else might I look?
Originally Posted by avs View Post
check out the setups that are already on tekin's website. there are 13.5 and 17.5 examples for 1/12. the 203 and 208 versions are equally useful guides.
in general you will use higher rollout (like 80's), more boost (like 50) some turbo (maybe 10) and lower end RPM.
CanyonCarverR1 is offline   Reply With Quote
Old 10-07-2010, 06:13 PM   #17343
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Just scrole down, they are there.
http://www.teamtekin.com/hotwire/ESCsetups/index.html
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-07-2010, 08:12 PM   #17344
got it, thanks!
Originally Posted by BCbud View Post
Good day!
Old 10-08-2010, 02:08 AM   #17345
djiewie's Avatar
I heard that with 3,7V the Tekin RS can do 4,5T in stead of 5,5T because it applies to 7,4V
Is this true, can i drive a 4,5T brushless with 1s lipo
Greetz JW
djiewie is offline   Reply With Quote
Old 10-08-2010, 03:53 AM   #17346
TrevCoult's Avatar
Greetz JW
No it is not true.
Lower voltage = more current = same heat.
You need the RS Pro.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 10-08-2010, 04:58 AM   #17347
mangoman's Avatar
If you are talking about 12th scale i would think that weight would impact load on the motor and how hard the speedie works.
And thus motors which could be used?
Although i remember 5 cell (NiMH) mod used to really heat up the batteries and esc. But i think we were also pushing the esc/motors harder.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-08-2010, 08:55 AM   #17348
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Trevor is correct. Less voltage means more current. For 1s mod racing you should be uisng the RS Pro. I've seen others use the RS for it and you "can" but it may thermal so testing would need to be done.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-08-2010, 12:20 PM   #17349
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
1s 1/12 mod is none issue with rs... We never even see three lights on the speedo.... 6.5 - 5.5 is a much better drive then a 4.5.... Laptimes are the same more of a element of gearing to get the speed then the wind in mod. If you go back to the days we were running 4 cell and 10.5 was SS. The 10.5 qual by ray at the 08 nats would of tq'd open mod.... He backed that up also.
Not much has chainged in the motor relationship the 10.5 can get it done just a lot softer drive and you have to drive more like a stock car then a
Open mod....
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is online now   Reply With Quote
Old 10-08-2010, 03:03 PM   #17350
Revlimit's Avatar
I just got my first rs, I generally run speed passion. I really think the Tekin is smoother and has better throttle response. But I did have a little problem. When I was celebrating I had to set my trim and subtrim all the way to the high side on my m8 to get neutral to be recognized. Even with the trims all the way up I still had to pull the trigger just a little bit to get the speedo to recognize neutral. Since I had to pull the trigger it gave the throttle a large dead band feel. Any help here will be greatly appreciated. Thank you
Dirt oval crazed!
Custom Works Rocket 13.5 latemodel, FT B4 backup latemodel/offroad
Boss tuned Speed Passion Power http://bossrcmotorsports.com/
Proud member of Hubbard Motorsports, Team Wicked, and Boss RC Motorsports!
Revlimit is offline   Reply With Quote
Old 10-08-2010, 03:53 PM   #17351
STLNLST's Avatar
Trader Rating: 21 (100%+)
Did you set all the radio trims to their normal positions before starting the set up process? The trims and sub trims should be set at zero at first set up I believe. All other trims should be set at 100 when setting the radio to the speedo. Something must be a little off it it's not picking up neutral.
STLNLST is offline   Reply With Quote
Old 10-08-2010, 04:09 PM   #17352
Team Tekin
Randy_Pike's Avatar
Clint is right, 0 our your subtrims and trim. If it can't find nuetral there, reverse the throttle channel.
If you can't get a nuetral setting to calibrate make sure your NW setting is at default at least until you get a radio calibration.
Old 10-08-2010, 04:35 PM   #17353
DaveW's Avatar
With my M8 i had to reset the model memory i was currently using and start from scratch. All trims were centered, and EPA for throttle and brake were set to 95%. After RS calibration, i opened EPA to 100% for throttle and brake. This is the only way i dont lose turbo in the middle of a run, and 8-10 deadband on Hotwire feels like older Novak speedo deadband (GT7/GTX).
This had to be done with my older crystal TX/RX setup, and my newer Airtronics 2.4 TX/RX (for M8/M11) as well. I thought the newer TX/RX might solve the issue, but it didnt.
Did you ever happen to cut, or change out your throttle trigger spring?
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 10-08-2010, 04:42 PM   #17354
Revlimit's Avatar
The first thing I did before I even attempted a calibration I did the factory reset. I bought the speedo used so I wanted to make sure everything was "normal". When I first tried to calibrate the speedo all my trims were at 0 and my epa was at 100 on high and low. I followed the manual exactly. The only thing I didn't try was reversing the throttle channel. I'll give it a try in a little bit and let you guys know how it works. Thanks again.
Dirt oval crazed!
Old 10-08-2010, 04:49 PM   #17355
DaveW's Avatar
My throttle is Normal direction. Let me know if the change makes a difference for you...
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
