Old 10-07-2010, 11:57 AM   #17326
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
wow,so whats going to happen with cleveland coming up is it going to be a track approval
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-07-2010, 12:31 PM   #17327
Hi,
Whats a good fdr to start with for an indoor track running a Redline 13.5t with the stock 12deg motor timing. Track has a straight of 30m and the rest is normaly tight and technical but sometime's slightly different depending on the track layout. At the moment I've set my fdr 7.60 . Mt end rpm is set to 25900 which is the maximum for the Redline (I think ?) Boost is 40 and I've left Turbo at 0.
Do I first get the gearing correct for the infield and then sort the boost out for the straight ?
Am I correct in saying I don't want the boost coming on infield ? so I may have to increase my start rpm to stop this ?
If I need anymore speed on the straight then I may add boost but only if needed ?
Have I got the right idea here
S.A.W is offline   Reply With Quote
Old 10-07-2010, 01:11 PM   #17328
BCbud's Avatar
Trader Rating: 37 (100%+)
Originally Posted by S.A.W View Post
Hi,
Good day!
You have the right idea, what class and car are you running?
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-07-2010, 01:16 PM   #17329
TrevCoult's Avatar
I think you're confusing boost and turbo. Boost (the one with start and end RPM) and gearing should be figured out for the infield together. You DO want boost coming in in the infield.
Turbo (the one with a delay and ramp) is the one you want for added speed on the straight. You do NOT want this coming in in the infield.
Of course there are always exceptions, but this is the usual way of doing things.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 10-07-2010, 01:19 PM   #17330
TrevCoult's Avatar
I'm sure it will all be sorted out by Cleveland.
Trev
Schumacher Racing
Old 10-07-2010, 01:32 PM   #17331
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Trev
Just a simple error...its being sorted out now.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-07-2010, 01:41 PM   #17332
Trev
Yeah sorry I meant if I need more on the straight then I add Turbo not boost.
So I do need boost infield ? not just geared for the infield ?
Good day!
T3 13.5t
Old 10-07-2010, 01:56 PM   #17333
syndr0me's Avatar
Trader Rating: 32 (100%+)
Glad to hear it. Tekin always takes care of us.
syndr0me is offline   Reply With Quote
Old 10-07-2010, 02:36 PM   #17334
TrevCoult's Avatar
T3 13.5t
Yes, both gearing and boost for the infield. The gearing, along with the amount of boost and the difference between the start and end RPM will define your punch out of the corners. In fact I move the start RPM when I want to fine tune the amount of punch, leaving the end RPM the same. There are several ways of having the same effect, and all are valid.
Trev
Schumacher Racing
Old 10-07-2010, 02:40 PM   #17335
Thanks, so is 7.60 ok to start with ?
Do you start with the lowest start rpm, then try the next ect to find which is best ?
Old 10-07-2010, 02:43 PM   #17336
I just recieved my Tekin RS Pro, and I put it in the car, and tested it tonight. The track is small and technical, and has a 30m straight.
This is my settings:
Motor: Speed Passion V3 17.5T
FDR: 5.95
Motor Timing: +5 degrees
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 10
Turbo Delay: 0.5
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 1.0
I started out with 35 boost and 5 turbo - just to get used to onroad again. In my second run I switched to the settings above, and WOW!!! It has so much rip in the infield, but still feels very smooth. And on the straight when the turbo kicks - oh... my... god...
Next time I will switch to a Turbo Delay of 0.3 instead - the turbo kicked in a little bit to late. Other than that, I got the speed I need. And best of all: After 7 minutes, the motor was 40 degrees celcius!
So I am definately staying with Tekin!
One thing though: I am currently running without a capacitor. Normally the long leg on the capacitor is negative, but on the capacitor I got, the drawing on the top said the other way around. So I didn't dare to use it, as I didn't know what was right.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-07-2010, 03:02 PM   #17337
Regional Moderator
CarbonJoe's Avatar
If it is the small silver Tekin cap, the negative side is marked in blue on the top of the cap.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-07-2010, 03:13 PM   #17338
It is the silver Tekin cap that comes with the RS Pro.
So I should trust the "drawing" on the top, and just ignore the length of the legs?
Niklas Hansen
Old 10-07-2010, 03:14 PM   #17339
20 SMOKE's Avatar
blue is neg
Jamie W
Old 10-07-2010, 03:14 PM   #17340
Regional Moderator
CarbonJoe's Avatar
Yes. All 3 of my RSes have the same cap installed with the blue side lead to "B-".
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
