Tekin RS ESC sensored >
Old 10-02-2010, 03:22 AM
  #17221
mutley001's Avatar
Default M05 setup
Hey guys
Anyone put their tekin in a tamiya mini?
I could use a starting point for 13.5 in a m05 on carpet indoors. Any advice appreciated.
Cheers in advance
Paul
mutley001 is offline
Old 10-02-2010, 03:13 PM
  #17222
Aahj's Avatar
Default Is this right?
Just finished up putting my SC10 together. I've been out of the hobby for almost a decade and was curious if my set-up was working correctly. Using a Tekin RS with a Novak Ballistic 17.5 motor, Spektrum 3100 receiver, 15/87 gearing.
Watch this video and tell me if this looks normal to you…just seemed kinda slow to me, but like I said, been out of the sport a while.
Thanks for your input,
AJ
http://gallery.me.com/ajnealey#100085
Aahj is offline
Old 10-02-2010, 03:26 PM
  #17223
reenmachine's Avatar
Trader Rating: 26 (100%+)
AJ
IMO, you're geared super super low. We've been gearing SC10s at 78/23-25 or thereabouts on our medium-sized outdoor track. This setup sheet has been a good starting point (it's a v203 setup sheet but still applies):
ROAR SCT 17.5 Tekin setup sheet
EDIT: Watching that video it looks like you've got massive drag brake on there. With the setup above, you'll have to be careful free-revving it like that as the tires can separate from the rim.
reenmachine is offline
Old 10-02-2010, 04:30 PM
  #17224
Aahj's Avatar
Thank you very much for the quick response. Made the changes…especially to the gearing…and it's a crapton faster!
Thanks again and can't wait to hit the track.
AJ
Aahj is offline
Old 10-02-2010, 04:34 PM
  #17225
AJ
No problem. just be sure to check motor temp every couple minutes until you're comfortable that you can go the distance without overheating. On most tracks that setup will be fine -- even a bit conservative.
Old 10-02-2010, 09:48 PM
  #17226
Trader Rating: 5 (86%+)
Default 1/12 17.5 and wgt 13.5
does anyone have a good starting point for 208 no boost, no timing for 1/12 17.5 and wgt 13.5...running speedpassion v3 motor...i need a rollout for a 40x100ft track and a 30x70ft track.
obi wun is offline
Old 10-02-2010, 10:00 PM
  #17227
Xpress's Avatar
Originally Posted by MikeXray View Post
I know a few who did this for that reason this summer outdoors. It takes a pretty big straight, like 200+ to see a difference.
Any idea what their speedo setting were? Just looking for how much boost and what timing window etc...
Xpress is offline
Old 10-02-2010, 10:50 PM
  #17228
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
For 12th scale
85+ roll, you may want to crank some endbell timing up to get top end also.
RedBullFiXX is offline
Old 10-03-2010, 08:07 AM
  #17229
I have an RS and just finished updating to the 208 software. I cannot find any instructions for setting the ESC into Spec mode. Any help would be appreciated.
Jeff
TKG27 is offline
Old 10-03-2010, 08:34 AM
  #17230
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
using the hot wire click throttle and #1 on the slider,using the pit mode go the TP then INS to #1led
20 SMOKE is offline
Old 10-03-2010, 12:49 PM
  #17231
bhambrent's Avatar
Default hotwire
Will the hotwire software install on a PS3?
Thats the only pc that I have. lol The rest are mac's.
Thanks for your help.
bhambrent is offline
Old 10-03-2010, 01:18 PM
  #17232
20 SMOKE's Avatar
there is a way to use it on a mac,some one else will have to help you
20 SMOKE is offline
Old 10-03-2010, 01:58 PM
  #17233
Iwould like a set up for 1/12th with a 10.5 SP v3 motor and the track has a 25m long straight and flowing but tight infield
including some idea for roll out , i have been running today and the motor is cold
final settings were
Start 4,XXX
End 18,XXX
boost 35
Turbo 5
delay 0.15
ramp 2.0
roll out 45 ish
push control 5
drag off
brake max
throttle profile 3
Thanks Phil
sidecarphil1 is offline
Old 10-03-2010, 02:44 PM
  #17234
final settings were
Start 4,XXX
End 18,XXX
boost 35
Turbo 5
delay 0.15
ramp 2.0
roll out 45 ish
push control 5
drag off
brake max
throttle profile 3
Thanks Phil
rollout looks ok, but the last time i ran, I had my rpm ranges very different (800-10000 ish), no turbo and a little more boost (mid 40's) that was ok as a starting point.
I've not run it for a while now though.
chris_dono is offline
Old 10-03-2010, 03:12 PM
  #17235
M-Technic's Avatar
Trader Rating: 15 (100%+)
Can someone please PM me a link to download the Hotwire 4 software so I can downgrade back to v203? Thank you!
M-Technic is offline
