Old 09-24-2010, 06:02 AM   #17116
macdude's Avatar
Originally Posted by velotek1 View Post
After updating to 208 my Tekin RS is not working. Steering works but there is no throttle. There is also no response from either of the buttons on the esc. Anybody know how to go back to version 203? or maybe something else I could do to get it working? thanks
Just bought a couple used RS controllers and had a similar problem with one of them. Here is what I did. Plug it back into the HW and apply the firmware again. Then unplug the controller and calibrate it to your controller. If everything went well it should work now. If you want to change the custom profiles, plug it back into the HW and adjust and apply the settings.
When I originally changed the firmware, I also changed the custom profiles and for some reason this controller did not like it in that order. All the other RS's worked after the update, but this one needed it twice.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 09-24-2010, 11:13 AM   #17117
I keep hearing that Tekins are great for stock, but not mod. And that Tekin RS Pro thermals when running mod.
Anybody got any experience using the RS Pro for mod TC 5.5T? I don't plan on running turbo or boost - just mod.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 09-24-2010, 11:33 AM   #17118
I am running RS Pro, no prob running 5.5t in my xray.
hardmankam is offline   Reply With Quote
Old 09-24-2010, 11:48 AM   #17119
Originally Posted by tc3team View Post
+1, sometimes it is even beneficial to get the 200mm sensor wire for this reason alone, so some of its cable is routed away from the outside of the car and out of reach from snagging on something
Zip ties weigh nothing, so one each end as close as you can to it being attached to anything is even better.
It wasn't snagging on anything. The g-forces from the crash and the weight of the cable were pulling it out of the plug. With the cable locked down on a motor wire it doesn't come out anymore. A 90degree plug on one end of a sensor cable would be great cos in a TC5 I've had some T-bone crashes that have broken my sensor wires with a Redline motor.
spongerX is offline   Reply With Quote
Old 09-24-2010, 01:30 PM   #17120
BCbud's Avatar
Trader Rating: 37 (100%+)
Default Max Total Timing
Good day!
I have read that the max total timing that you should apply is 60*. My motor has 30* of internal timing at the zero mark on the endbell. Would this mean I should only add 30*(boost + turbo) more with the RS?
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 09-24-2010, 01:39 PM   #17121
So the Orange guys have convinced you, eh?
Whom ever told you that has 1, never owned or used a Tekin, 2, haven't a clue about what they're saying.
The Tekins, both RS and Pro, have no problems thermaling like certain orange products or even blue ones. The RS is good to 5.5 and unlimited for brushless. The Pro can run anything.
Problem is that some people tend to use too tall over a gear and overheats the motor and the ESC but they would do that with any ESC since they don't know that when the turns go low so do the pinion teeth.
I ran a whole season with a RS Pro and a LRP 4.5 and never overheated anything.
AreCee is offline   Reply With Quote
Old 09-24-2010, 01:55 PM   #17122
Thank you for your answer.
Just out of curiousity, which orange product are you thinking about? I am pretty sure I know what you mean with blue ones, but not orange
(If you don't want to say it here, you can PM me)
Niklas Hansen
Old 09-24-2010, 01:55 PM   #17123
Trader Rating: 36 (100%+)
My RS used to thermal about two minutes into a race in TC with a 6.5.
I switched to an RS Pro and have not had any problems since.
The RS says it can run as low as a 5.5 but, I believe that is only under certain conditions. If you go with the Pro in Mod, you should have no problems at all.
EVILGRAFX is offline   Reply With Quote
Old 09-24-2010, 01:58 PM   #17124
wingracer's Avatar
Trader Rating: 24 (100%+)
Seriously? You don't know what an orange brand is? Here's a hint, starts with N and ends with K.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-24-2010, 02:05 PM   #17125
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
5.5 in 2wd not TC
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-24-2010, 02:27 PM   #17126
Bubblehead's Avatar
Originally Posted by STLNLST View Post
We run all the same stuff. I have the Cyclone TC. I ran these settings last weekend and the car was a rocket. Try it and see if it works for you.
Boost: 45
Turbo: 15
Start: 27XX
End: 8500
Turbo Ramp: 2
Throtle profile: 3
Neutral Width: 9
Motor Timing: 8
Drag Brake: 20-25
Brake Strength: 90
FDR: 6.0
My motor temps aren't super high and the car has plenty of power on the low and top end. My car balances fine with the Exotek chassis and isn't as heavy as yours. What other electronics are you using? My car is1425 with a fan.
I will try the setting this weekend. What about Turbo Delay?
I have the following in my car:
Futaba Digital Servo: S9451
AMBrc DP:
Futaba Receiver: HRS R203HF
Tekin RS Pro:
Tekin Redline: 17.5
I also have an Exotek chassis order, should be here Monday.
Bubblehead is offline   Reply With Quote
Old 09-24-2010, 04:15 PM   #17127
I have run 4.0t to 6,5t at the Heemstede track in the Netherlands and
it is never overheated or thermal shut down.
The nice thing is that I reached the same top speed aprox. 110km/h with all motors, thanks to the timing advance the only difference was the bottom power, very understandable I think.
Regards
Ed
eded1 is offline   Reply With Quote
Old 09-24-2010, 04:22 PM   #17128
bfong13's Avatar
Trader Rating: 17 (100%+)
What?????? Not sure where you're getting your info from but, you're wrong.
Tekins are great for stock and mod.
I've run an RS Pro in my 4wd buggy with 6.5 and in my TC with 5.5. No problems at all.
bfong13 is offline   Reply With Quote
Old 09-24-2010, 04:31 PM   #17129
STLNLST's Avatar
Trader Rating: 21 (100%+)
AMBrc DP:
Tekin RS Pro:
Tekin Redline: 17.5
For that track I ran the delay at .20
STLNLST is offline   Reply With Quote
Old 09-24-2010, 05:26 PM   #17130
Bubblehead's Avatar
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
