Old 09-23-2010, 10:07 PM   #17101
Originally Posted by wingman2 View Post
Hi guys, I have just uploaded the new software to the RS Pro in my 1/12th car, and just wanted know a 'base' setting for the speedo using a 10.5 motor in the car. Got it running really sweet with the 203 software, so could anyone help me out getting going with the 208 software, and then I can fine tune from there. Thanks very much in advance! Cheers.
I think the suggested starting point with 208 is just whatever you were running with 203. The UI looks different, but the underlying options are all the same.
-Mike
Old 09-23-2010, 10:18 PM   #17102
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Bubblehead View Post
Hot Bodies Cyclone (2.4375 IR) after balancing chassis 1480g. I not why I had to add that much weight 126g, no fan on motor, 17.5 Redline. I have tried just about everyone's profile at the track. FDR this weekend 1st round 6.5, 2nd 6.9, 3rd 6.4.
Boost: 45
Turbo: 14
Start: 4748
End: 13003
Turbo Ramp: 3
Throttle Profile: 3
Neutral Width: 10
Motor Timing: 0
We run all the same stuff. I have the Cyclone TC. I ran these settings last weekend and the car was a rocket. Try it and see if it works for you.
Boost: 45
Turbo: 15
Start: 27XX
End: 8500
Turbo Ramp: 2
Throtle profile: 3
Neutral Width: 9
Motor Timing: 8
Drag Brake: 20-25
Brake Strength: 90
FDR: 6.0
My motor temps aren't super high and the car has plenty of power on the low and top end. My car balances fine with the Exotek chassis and isn't as heavy as yours. What other electronics are you using? My car is1425 with a fan.
Last edited by STLNLST; 09-23-2010 at 10:27 PM. Reason: Bill kindly pointed out I forgot to put my turbo...LOL
STLNLST is offline   Reply With Quote
Old 09-23-2010, 10:23 PM   #17103
Still Bill's Avatar
Forgot your turbo Mr. LST.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-23-2010, 10:27 PM   #17104
STLNLST's Avatar
Bill
Done
Old 09-23-2010, 10:29 PM   #17105
Still Bill's Avatar
It's hell gettin' old isn't it?
Old 09-23-2010, 10:32 PM   #17106
STLNLST's Avatar
I blame it on the kids.....LOL
Old 09-23-2010, 10:34 PM   #17107
Default hotwire version 208
After updating to 208 my Tekin RS is not working. Steering works but there is no throttle. There is also no response from either of the buttons on the esc. Anybody know how to go back to version 203? or maybe something else I could do to get it working? thanks
velotek1 is offline   Reply With Quote
Old 09-23-2010, 10:38 PM   #17108
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Did you recalabrate your radio to the speedo?
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 09-23-2010, 10:42 PM   #17109
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Velotek, does the unit light up normally?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-23-2010, 11:10 PM   #17110
no all the LED's are flickering which it says in the manual that that means a poor radio signal , but the connections ae good and the radio systemworks great with other ESCs. Also there is no response from eitherof the buttons.
Old 09-23-2010, 11:24 PM   #17111
BCbud's Avatar
Is everything the same as when you had 203: car, battery and setup on the RS?
Recycled teenager.
Old 09-23-2010, 11:28 PM   #17112
yep everything is the same except the software
Old 09-23-2010, 11:32 PM   #17113
BCbud's Avatar
Try turning on the car befor the radio , this has worked for me when the speedo will not respond.
Recycled teenager.
Old 09-24-2010, 12:48 AM   #17114
TrevCoult's Avatar
Go into the software and check the cutoff voltage, this is almost always the reason after upgrading. The settings can change themselves after an upgrade, which can make the RS look like it isn't working when it it is just the settings.
If you need to, go through the common problems section of my article here.
http://www.carsrcracing.co.uk/?p=244
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 09-24-2010, 03:39 AM   #17115
tc3team's Avatar
Originally Posted by spongerX View Post
I've taken to zip tieing my sensor cable to one of the motor cables to stop it coming out in a crash on my Redline motor
+1, sometimes it is even beneficial to get the 200mm sensor wire for this reason alone, so some of its cable is routed away from the outside of the car and out of reach from snagging on something
Zip ties weigh nothing, so one each end as close as you can to it being attached to anything is even better.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
