Old 09-19-2010, 01:14 PM   #17056
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by Tag View Post
hi question for you guys , i am planning to run non timing 17.5 and have hence deactivated all boost/timing feature on my Rs , how many lights will lit up when turning on the ESc indicating timing deactivation ? i am asking becuse i have not notice anything different, still one solid light would lit up , did i miss anything ?
i have the most update software installed, if that helps.
Just moving the sliders to zero boost/turbo won't activate "spec mode" leds. You have to put the timing profile on 1 and then the middle led will flash when you are at neutral.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 09-19-2010, 01:19 PM   #17057
wingracer's Avatar
Trader Rating: 24 (100%+)
The one led will be on (the third one I think) but keep watching it. It will flash but it's a slow flash. It stays on for a while then goes out for just a fraction and comes on again. Kind of like intermittent windshield wipers, it's not a continuous flash.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-19-2010, 03:34 PM   #17058
nerdling's Avatar
Originally Posted by Jsaves View Post
I apologize for the newbe question that I should know, but how do you change the motor timing? I have not done it in a while. So I loosened the motor plastic cap screws and tried to turn the black cap to no avail. What am I doing wrong?
Thanks and God Bless
what type of motor?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 09-19-2010, 04:40 PM   #17059
Jsaves's Avatar
Default 17.5 redline
Sorry,
17.5 redline
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 09-19-2010, 05:00 PM   #17060
RDOUBLEDAY's Avatar
Anyone Have a Good Setup for 12th scale With Rs And duo2 17.5? I think the Track has A 70 ft strait. its in a crc carpet knife with it geared 44/81
Mugen Mbx6 Eco .
RDOUBLEDAY is offline   Reply With Quote
Old 09-19-2010, 05:32 PM   #17061
RC-ProSpeed's Avatar
Actually the light will blink/flash continuously (fast pace)in neutral... You won't have a doub when you see it; it will switch to from time to time to temp indicator but will go back to the continuos flashing
Timing profile needs to be on 1 (not CS1) go all way down on the slider when using hot-wire and I think you can adj. On the esc with the on board control... TP set it to led 1 I believe.
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 09-20-2010, 05:34 PM   #17062
lightfoot's Avatar
Default idiots need help...
I was at Corona track last Sunday pitting with 3 other guys... we were all running 17.5 with Tekins... 2 of us had laptops, and non of us knew exactly what we were doing... Is there any website out there that explains what each setting does, when to use it, when not to use it... kinda of like a "Idiots guide to the Tekin 208" ???
Love and Peace...
lightfoot is offline   Reply With Quote
Old 09-20-2010, 07:07 PM   #17063
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Included from Tekin with the 208 update
I would assume the built in profiles would be very useful, did you try them ?
Making it easier. RS and RX8 On-Board Timing Profiles
Who needs a separate programming box when all the features are available on the ESC at the touch of a button? While the HotWire is needed for fine-tuning and software updates, we realize not everyone wants to carry a computer to the track. To make it easier, 208 has new Timing Profiles which are taking the place of Throttle Profiles on the RS's onboard interface. Throttle Profile settings are still available using the HotWire. Throttle curve adjustments can also be made on almost all good radios.
The user can now select from 5 preset Timing Profiles on the RS and RS PRO without a HotWire.
RS and RS PRO
TP1 Spec Mode 0deg Boost (LED flashes when in neutral so Tech can easily verify mode)
TP2 15deg Boost, 5442 RPM to 20,000 RPM
TP3 25deg Boost, 5442 RPM to 20,000 RPM
TP4 35deg Boost, 5442 RPM to 20,000 RPM
TP5 45deg Boost, 5442 RPM to 20,000 RPM
C1 Custom settings using Hotwire
C2 Custom settings using Hotwire
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-20-2010, 08:38 PM   #17064
I find the built-in TP4 and TP5 mode pretty powerful (with a 10.5 motor). If you are not sure what you are doing, try TP1 then TP2 ... TP5 one at a time and see which profile you like. You may not even need to use a custom profile.
hardmankam is offline   Reply With Quote
Old 09-21-2010, 01:40 AM   #17065
TrevCoult's Avatar
Perfectly described. That is exactly what happens.
For now have a look at my 203 guide here.
http://www.carsrcracing.co.uk/?p=188
It has almost everything you need to figure out 208 too, just in a different place in the software and the timing profiles are missing.
I have a 208 one in progress too, screen shots done and the words just need to go in the right place now....
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 09-21-2010, 04:41 AM   #17066
TrevCoult's Avatar
The Vegas 208 version of my Tekin RS beginners programming article is now complete. It can be found at
http://www.carsrcracing.co.uk/?p=244
Trev
Schumacher Racing
Old 09-21-2010, 05:34 AM   #17067
georgec's Avatar
When using the TP settings in 208 should I remove timing from the motor end bell? (Redline 17.5)
georgec is offline   Reply With Quote
Old 09-21-2010, 06:00 AM   #17068
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you can use motor timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-21-2010, 06:23 AM   #17069
Trev
Many thanks, Trev. Very well written and very helpful.
Larry Brown is offline   Reply With Quote
Old 09-21-2010, 03:45 PM   #17070
Bubblehead's Avatar
Default 17.5 Redline
Should I be adding timing to my motor? I have the timing at 0.
Bubblehead is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
