Tekin RS ESC sensored >
Old 09-16-2010, 04:29 PM
  #17041
auzzy_mate's Avatar
Default Offroad Gearing
Gday All,
I have just bolted (stuck) an RS into my Team Associated T4 for offroad racing, and then proceeded to blow the tyre off the rims in the bench test, WOW! The difference between my old ESC and the RS is amazing.
I was wondering what the difference was between the older ESC gearing (recommended at 7.5 FDR) and what I should be running with the RS and its timing options? Should I be down at 8 or so FDR to get more bottom-end and then use the timing to get the top-end? Should I leave it the same and see what the temps do?
Ben
auzzy_mate is offline
Old 09-16-2010, 07:28 PM
  #17042
What size and type of motor? large or small track?
JR007 is offline
Old 09-16-2010, 08:11 PM
  #17043
auzzy_mate's Avatar
Default Stock
17.5 Redline Motor.
Large Track (long straight).
Old 09-16-2010, 09:10 PM
  #17044
You're going the wrong way with that motor. You should be gearing up big-time. Start with no turbo, gear it for acceleration on the infield, then add turbo to reach the end of the straight, if you need it. I'd be looking at gearing around 5.0 to start with for off-road.
JR007 is offline
Old 09-16-2010, 09:38 PM
  #17045
jjfo80's Avatar
Originally Posted by AOD View Post
I'm I the only person having their faast receiver overheat and shut down with the tekin rs? And does anybody know if there is a fix for this.
Sorry mate I havent had a problem but I am running a rs pro with a 604fs rx.
I dont know if thats any difference but mate its perfect even after a 20min race.....
Hopefully you can work it out.
jjfo80 is offline
Old 09-16-2010, 11:48 PM
  #17046
waOscar's Avatar
Try opening the receiver case and blowing it out. If it is full of dust and dirt this will happen.
I run 604fs and 603fs receivers with RS in a couple differant models with no problems.
waOscar is offline
Old 09-17-2010, 01:25 AM
  #17047
xray09ACT's Avatar
Hi guys, anyone know the base timing on the new 2010 orion? I am led to belive 20 deg. how does this comapre with the spv3?
cheers
xray09ACT is offline
Old 09-17-2010, 04:39 AM
  #17048
mok
mok's Avatar
Originally Posted by Airwave View Post
Very interesting! So to be sure you motor run like that:
0 - 9200RPM : -10
9200RPM - 24000RPM : going from -10 to 40 (or 30?)
@ full throttle : 55 (or 45?)
Is the negative value on the motor substracted to the ESC value?
Thanks anyway!
i am presuming that there is 30 degrees of physical motor timing on the LRP x12 motor at its middle point, so when i run the -10 insert, it leaves me with 20 degrees of physical motor timing which remains static and set regardless of esc settings.
so therefore, at 0 rpm there is a total of 20 degrees physical (or static) motor timing..
at 9200 rpm, the esc starts to feed on timing which adds to the motor physical timing...
by the time the rpm reaches 24000, there is the static 20 degrees physical motor timing plus 40 degrees of esc motor timing, giving a total of 60 degrees..
when i hit full throttle, the esc adds on another 15 degrees of turbo timing, giving a maximum of 75 degrees of total timing achievable with the settings i've chosen.
-Mark
mok is offline
Old 09-17-2010, 02:53 PM
  #17049
cheers
What car and how many turns your orion has?
eded1 is offline
Old 09-17-2010, 08:18 PM
  #17050
hairy's Avatar
Is it shutting down the car or are you losing power?
Do you know at what temp this is happening?
hairy is offline
Old 09-17-2010, 08:42 PM
  #17051
Regional Moderator
CarbonJoe's Avatar
How old is your Rx? The first shipments of FAAST Rx were notorious for having thermal issues, especially for Nitro guys. There are plenty of pictures of Jared Tebo's 1/8 buggy with a swiss cheesed Rx box to keep the Rx cool.
CarbonJoe is offline
Old 09-17-2010, 08:52 PM
  #17052
RDOUBLEDAY's Avatar
For 1s lipo on the tekin, Do you have to use the boost, ive read both, you do and then you dont, so which one?
RDOUBLEDAY is offline
Old 09-19-2010, 12:44 PM
  #17053
Jsaves's Avatar
Default Changing Motor Timing
I apologize for the newbe question that I should know, but how do you change the motor timing? I have not done it in a while. So I loosened the motor plastic cap screws and tried to turn the black cap to no avail. What am I doing wrong?
Thanks and God Bless
Jsaves is offline
Old 09-19-2010, 12:53 PM
  #17054
my set up from todays 1st indoor race of the season , the speed was nice and power delivery was nice and smooth
25m straight with a tight technical infield
v208 softwere
SP 13.5v3 motor timing 5
boost 50
Turbo 5 or 10 depending on grip
Start revs 5XXX
End revs 15XXX
Turbo delay 0.15
Turbo ramp 3
Gearing 6.9ish
Temp after 6 mins 50 degrees C
sidecarphil1 is offline
Old 09-19-2010, 12:58 PM
  #17055
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi question for you guys , i am planning to run non timing 17.5 and have hence deactivated all boost/timing feature on my Rs , how many lights will lit up when turning on the ESc indicating timing deactivation ? i am asking becuse i have not notice anything different, still one solid light would lit up , did i miss anything ?
i have the most update software installed, if that helps.
Tag is offline
