Tekin RS ESC sensored >
Old 09-11-2010, 08:23 PM
  #16996
gdiddy's Avatar
Default LED1&2, 6&7 Flashing
I don't know if this problem had been brought up, if so I apologise. LED's 1&2, 6&7 are flashing on my RS Pro, which according to the manual, the wrong motor type has been selected. I'm running a brushless and that's what I selected in the Hot Wire program, when I press 'Apply Settings' the pop up window informs me that my settings has been saved. But the LED's keep flashing. Any assistance with this issue would be greatly appreciated.
Thanks in advance.
gdiddy is offline
Old 09-11-2010, 10:04 PM
  #16997
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Martyn666 View Post
Hi guyz, could you please taky a look at my setup and tell me what do you think? Car is Xray T3, motor LRP X12 17.5T with -10 timing, gearing 6.4, small outdoor asphalt track, rubber tires.
Timing advance 0
Boost 55
Start 3095
End 17993
Turbo 20
Delay 0.04
Ramp 2.0
Have no problem with engine temparature.
Also im going to race indoor carpet w rubber in winter, could you reccomend something for that?
Thanks a lot..
If it were me I would drop the turbo to 5 or less, drop the timing to 50, increase your timing advance to max (the timing advance is just back up in case you run into sensor or sensor wire failure), increase your delay to at least .2, and move the end RPM to something between 12k and 14k. Be sure you're running in sensored only mode. As always check your temps; you may be able to move the timing on the motor back to 0.
Thanks in advance.
I am not certain, but I think I have seen LEDS on hte outside light up when an incorrect lipo cutoff is set; ie when you have 2s as the cutoff and are trying to run 1s. I would check in the HW that you have your cutoffs where they should be.
andrewdoherty is offline
Old 09-11-2010, 10:54 PM
  #16998
trf415msx's Avatar
Trader Rating: 20 (100%+)
Thanks in advance.
you blow the speedo need to contact tekin
trf415msx is offline
Old 09-12-2010, 07:03 AM
  #16999
Senna Racing's Avatar
Thanks in advance.
before you contact tekin try a different sensor wire, then try removeing ever thing from your reciver then power up the esc, and see if it gives you the beep beep
lastly try the motor if you have a spare
but it could be your tekin
Senna Racing is offline
Old 09-12-2010, 08:11 AM
  #17000
DaveW's Avatar
Until yesterday, i have had a great experience with my second RS. On a whim, it decided to only give me drag brake and NO push brake. Its like my mom decided to take away my pudding, even though i ate my meat. (Thats a nod to Pink Floyd for you pervs out there)
Anyways. I changed NOTHING brake related on the radio. I changed nothing brake related on the speedo. I did not do anything that required a radio recalibrate. I did not leave it unplugged too long so the time needed to be reset.
All i did was turn it on, and NO PUSH BRAKES. It worked fine the week before. Today, drag brake was kicking in around 2/3 throttle, nowhere near neutral, and my deadband is set to 10. I have been using the throttle/brake EPA settings at 95 and opened up to 100 after ESC calibration for months, and now this. I have an M8 FHSS2 Airtronics transmitter/module/receiver that i know very well, and have had NO issues with.
WTF?!
DaveW is offline
Old 09-12-2010, 08:15 AM
  #17001
stiltskin's Avatar
Trader Rating: 103 (100%+)
Thanks in advance.
Check your solder connections on the motor and speedo. If there is even the smallest sliver of solder connecting two poles, it will give you those lights. Been there, done that. Make sure you check the bottom of the poles as well for any solder that may have dripped down to make the ground.
stiltskin is offline
Old 09-12-2010, 08:33 AM
  #17002
Trader Rating: 36 (100%+)
Yeah, what Tony said.
EVILGRAFX is offline
Old 09-12-2010, 10:39 AM
  #17003
Potoczak's Avatar
Trader Rating: 113 (100%+)
Hey guys, have a question, i am running 208 software in my rs pro would there by any issue going back to the 203 version. I have 2 different laptops one with 203 and one with 208. Any help would be great.
Potoczak is offline
Old 09-12-2010, 11:31 AM
  #17004
WTF?!
Have you re-calibrated your radio to the esc to see if that helps? Almost sounds like your neutral is off. I had this last week with my 3PK and had to adjsut the neutral nad endpoints on the radio itself as they had just crept out of what the RS could pick up
JR007 is offline
Old 09-12-2010, 02:41 PM
  #17005
DaveW's Avatar
I wanna say thanks for responding.
No i didnt recalibrate, and only because i didnt think i should have to. I have calibrated speedos to my radio that to this day after years of sitting in a box, operate perfectly with my radio set to the neutral settings the speedos were calibrated with. NO issues.
Are you suggesting that my radio may need servicing? I dont know how the settings could creep out of adjustment without either something going wrong with the radio, or physically making changes. Was there a problem with your radio, or are we coming to the conclusion that there is something wrong with the RS in that it needs to be randomly recalibrated?
This is frustrating. The RS is such a wonderful speedo with all of its (tun)ability, but the 'bugs' or 'quirks' that seem to be passed off as urban legend can wear thin on you in the middle of a hectic race day.
DaveW is offline
Old 09-12-2010, 02:53 PM
  #17006
Xpress's Avatar
The potentiometer in the radio for the throttle may be out of adjustment causing the nuetral point to wander. You can "reset" the nuetral and end points through one of the functions on the radio.
Xpress is offline
Old 09-12-2010, 06:15 PM
  #17007
Default tekin rs
I am runing a sc10 on a hard and slick indoor dirt track thundervalleyrcraceway.com, just purchased a tekin and a duo epic 17.5. I have the hotwire and downloaded the latest version. I need help setting this thing up.
thanks everyone
eapatt76 is offline
Old 09-12-2010, 06:27 PM
  #17008
Trader Rating: 18 (100%+)
"How can you have any pudding if you don't eat your meat?"
P.S. change your sensor wire.
Advil is offline
Old 09-12-2010, 07:57 PM
  #17009
Team Tekin
Randy_Pike's Avatar
If you get 12 67 try another known good motor. The sensor harness has NO absolutely NO affect on this led sequence.
If your Rs is acting funny a fresh radio calibration is always the next step.
Randy_Pike is offline
Old 09-12-2010, 09:43 PM
  #17010
With the modern electronics, they are quite sensitive. Most drivers get around it by having a wide Neutral Width, which accomodates for the neutral drift.
If you can't adjsut that manually, you may need to send it in, or try widening the neutral width as mentioned. Make it about 40 or so and see if it works.
Not sure about your radio, but on the 3PK there is a adjustment setting that lets you "confirm" the positions of the trigger from neutral, full throttle, and full brake.
JR007 is offline
