Old 09-05-2010, 06:42 PM   #16936
Trader Rating: 36 (100%+)
Originally Posted by jammincrtjames View Post
I had a problem with settings holding on 208 this weekend. The speedo would not take my start and end RPM inputs. It took 6 times to get it to hold. Is there a trick for this when that happens? I always make my settings changes and then re-open to make sure they take, but 6 times was a little annoying. Is this just a normal glitch?
I had the same problems. I ended up trying a different persons computer and it took on that computer only to end up doing the same exact thing on that computer later in the day.
Everything would set except for the Timing boost, it kept going back to 5XXX start and 20000 end.
EVILGRAFX is offline   Reply With Quote
Old 09-05-2010, 07:31 PM   #16937
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
here what we have at our track
+ YouTube Video
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-05-2010, 08:35 PM   #16938
MaxSp97's Avatar
Reupdate the RS with 208 and this will solve your problem.
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 09-05-2010, 08:38 PM   #16939
phisher's Avatar
Trader Rating: 14 (100%+)
Originally Posted by phisher View Post
I'm looking for a copy of v203. Does anyone have it. If so, please PM me. I have little experience with the Tekin RS Pro / Hotwire but I have notice a difference. Thanks.
Anyone? Or does anyone know where I can still download it?
www.MichiganRC.net
phisher is offline   Reply With Quote
Old 09-05-2010, 08:51 PM   #16940
phisher's Avatar
lupin_au rocks. Thanks man.
www.MichiganRC.net
Old 09-06-2010, 01:45 AM   #16941
jtrcracing's Avatar
Hi,
any good setups for the rs pro and redline motor kombo?
running Robitronic avid v2.
Shepherd velox v10, robitronic protos v2,robitronic mantis.
Shepherd Velox v8.
jtrcracing is offline   Reply With Quote
Old 09-06-2010, 04:01 AM   #16942
jammincrtjames's Avatar
Those are the same numbers it would default to. Strange.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 09-06-2010, 04:12 AM   #16943
marcel p's Avatar
Send a message via MSN to marcel p
+ YouTube Video
thats awsomelol
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-06-2010, 07:51 AM   #16944
Nope, Sorry, I did exactly that and had the same problems.
Old 09-06-2010, 10:02 AM   #16945
Wall Banger's Avatar
You can not change Timing profiles 1-5 You can change timing profiles C1 and C2.
Timing profiles 1-5 are preset and C1and C2 user profiles
Wall Banger is offline   Reply With Quote
Old 09-06-2010, 10:54 AM   #16946
JohnWinn's Avatar
I'm having a bit of trouble trying to get my new RS to calibrate to my radio (ko helios). I believe I have the transmitter set to all the correct defaults (throttle on normal, 100 on both epa's). When I go into calibration mode, the ESC seems to find the neutral setting just fine, but when I try to set full throttle, it just sits there, beeps and flashes. Should I try to rebind my receiver? Should I try another receiver? Or does my ESC need service?
“We live in an age when unnecessary things are our only necessities.”
JohnWinn is offline   Reply With Quote
Old 09-06-2010, 12:29 PM   #16947
It's set to C2, that did not change, that is not the problem.
Old 09-06-2010, 12:30 PM   #16948
With the KO, The throttle needs to be set to REVERSE.
Old 09-06-2010, 01:38 PM   #16949
And set your EPAs to 90 before starting calibration and reset to 100 when calibration is finished
yellowshark is offline   Reply With Quote
Old 09-06-2010, 02:12 PM   #16950
JohnWinn's Avatar
I'll give those changes a try, thanks.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
