Old 08-31-2010, 01:49 PM   #16891
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Swampracer View Post
Hi,
I have a KO Eurus radio and I have forgotten what the throttle exp setting should be? +10%?
Also anyone with a good 17.5 limited profile set-up for 1C 12th scale racing V208? Average size track.
Thanks Greg G
yes add 10 to the epa
this should help with the setup,just gear for you track http://www.teamtekin.com/hotwire/ESC...03-17-5-TC.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-31-2010, 02:24 PM   #16892
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default V203 vs V208
Quick question:
The link provided is the Jeff Cuffs set-up for V203 using 2C Lipo. Will this be a proper starting set-up for a 1C Lipo 12th scale running 17.5 limited profile.
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 08-31-2010, 03:58 PM   #16893
20 SMOKE's Avatar
opps he has a 12th setup on there
Jamie W
Old 08-31-2010, 04:16 PM   #16894
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I am hoping somebody can help me here, I think I'm in the right spot to ask this. But will a boosted 10.5 motor running the 208 software be compareable to a standard esc with a 5.5 motor. The reason why I am asking is I have been going back and forth to either running stock or mod and I dont have standard esc.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*Daves RC Track*
ChadB. is offline   Reply With Quote
Old 08-31-2010, 05:40 PM   #16895
JayL's Avatar
depends on track. We have a 120+ ft straight and had a guy try 10.5 boost in mod and he was slow traffic everywhere especially the infield where our torque would kill him, we usually run 4.5
JayL is offline   Reply With Quote
Old 08-31-2010, 06:44 PM   #16896
xray09ACT's Avatar
Hi guys.
I am looking at starting to run Modified locally and also around the state/s here in AUs.
I currently have an RS not and RS Pro.
Even though the motor rating is 5 turn s on the RS it seems not a lot of people are running the RS in mod, they tend to use the RS pro. I do not plan on using a motor any lower that 5.5.
Will my RS be able to handle this competetivly?
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 08-31-2010, 08:25 PM   #16897
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Not likely. The RS is rated to a 5.5 in a 2wd application only like 2wd buggy.
For TC mod you will need the RS Pro.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-31-2010, 09:42 PM   #16898
xray09ACT's Avatar
Thought so thanks Randy. Figured i better check before i turn something good into something that doesn't even make a good paperweight.
Old 08-31-2010, 11:51 PM   #16899
STLNLST's Avatar
The straight is 160ft Billy would jack you up for cheating him out of 40ft....LOL
STLNLST is offline   Reply With Quote
Old 09-01-2010, 07:25 AM   #16900
M-Technic's Avatar
Trader Rating: 15 (100%+)
What is a safe mod motor for a regular RS in 4wd touring? 8.5? 7.5?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-01-2010, 07:33 AM   #16901
20 SMOKE's Avatar
i would say 8.5 but if you want it to go fast let me drive
Jamie W
Old 09-01-2010, 08:54 AM   #16902
claymonkey's Avatar
I asked this in another thread, but would like to know your opinions on the redline motors compared to others on the market, I am getting another esc and motor for my sc10ft that is coming. It will be a 17.5 motor and of course am really leaning to another RS controller. Thanks all.
The golden rule rulez. The world is nuts, let's go racin!!
Mugen MBX6R, MBX6T
Associated B4.1FT, SC10FT
claymonkey is offline   Reply With Quote
Old 09-01-2010, 09:00 AM   #16903
macdude's Avatar
I'm running the Novak ballistic 17.5 in all my offroad stuff. These motors have tons of torque so you can gear up a little for speed and still have plenty of low end power. A couple of the guys at my track are running the Duo 2's and they seem to work well also. I don't know about the tekin motor as I burned mine up at the snowbirds. So I switched to the duo 2 for TC.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 09-01-2010, 09:03 AM   #16904
claymonkey's Avatar
Thank you macdude, I have had great experience with the Novak motors, but have switched to Tekin speed controllers and was curious to what people thought of the redlines, thanks dude.
Mugen MBX6R, MBX6T
Old 09-01-2010, 09:28 PM   #16905
Default Too much timing
After reading the last 25 pages of posts, I have seen several guys posting talk about 60+ degrees of timing, this is not good, so I wanted to post an exerpt from RC CAR ACTION...
"With each coil occupying 120 degrees of the circle, and its center being zero degrees of advance, there's only an opportunity to apply 60 degrees of either advance or retard timing. If the speed control tried to apply 61 degrees of advance, the actual outcome would be 59 degrees of retarded advance on the next bank of coils. So contrary to popular belief, you can indeed have "too much of a good thing," and there is a set physical limit to just how far a speed control and/or motor can go."
So, if you are programming a ton of advance into the speedo then adding more via the motor you may find yourself boosting down the straight only to cross into a ton of retarded timing and come to a screeching crawl.... So next time somebody tells you to push past 60 degrees total timing, think twice!
Just my 2 cents......
Cyclone Bender is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
