Old 08-30-2010, 08:39 AM   #16876
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by sidecarphil1 View Post
any one ???
start 3k
end 15500
timing boost 45 (go up if the track can handle it)
fdr6.8
adjust gearing as needed and play with a little motor timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-30-2010, 08:40 AM   #16877
20 SMOKE's Avatar
Originally Posted by CarbonJoe View Post
I was looking on Tekin's site for setup sheets for 1s 13.5 WGT but couldn't find any. There are a couple of 1/12 13.5 setups on there, so my question is shouldn't those be fairly close due to the same power and motor? Maybe just drop a tooth or two on the pinion due to the difference in weight? (730g for 1/12, 930g for WGT). Or am I way off here?
WGT from tekins site
http://www.teamtekin.com/hotwire/ESC...Paved-Nats.pdf
Jamie W
Old 08-30-2010, 08:41 AM   #16878
20 SMOKE's Avatar
Originally Posted by noline View Post
Hey guy,s
I have a question about 1/12th. I have a Tekin rs and I plan to run 1c 3.7 13.5 lipo, I was thinking about useing LRP's capacitor would it be ok to use this capacitor here's the part# and what I'm talking about.
Works Team ESC Capacitor, 3.7-4.8v
Part#: LRP 82530
http://www.nexusracing.com/product_i...oducts_id=3122
i personally use what comes with it and dont see a need to change
Jamie W
Old 08-30-2010, 08:51 AM   #16879
Originally Posted by 20 SMOKE View Post
start 3k
end 15500
fdr6.8
thanks Jamie
The last time i was there i used my SPX and it was quick enough
what can i do to make the Tekin feel like the SPX did ???
sidecarphil1 is offline   Reply With Quote
Old 08-30-2010, 08:58 AM   #16880
20 SMOKE's Avatar
thanks Jamie
just drive it,they are totally different
Jamie W
Old 08-30-2010, 09:06 AM   #16881
Regional Moderator
CarbonJoe's Avatar
Would different surfaces change the setup much? I'm running indoors on carpet vs. outdoors on asphalt?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-30-2010, 09:08 AM   #16882
M-Technic's Avatar
Trader Rating: 15 (100%+)
thanks Jamie
Using a wider RPM window, and a lower turbo ramp would make it more smooth like an SPX. For example, 5,000-22,000 RPM range, turbo ramp 1 or 2. You will need to use a heavier FDR to compensate.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-30-2010, 09:27 AM   #16883
20 SMOKE's Avatar
what size track and motor
Jamie W
Old 08-30-2010, 09:36 AM   #16884
Regional Moderator
CarbonJoe's Avatar
New Duo2 13.5. 90x40 carpet track.
Old 08-30-2010, 09:40 AM   #16885
20 SMOKE's Avatar
i ran this yesterday and won
8500
2xxx
53
motor 0,add a little if you need more out of the corner
gearing 45/100
my motor was 100*
Jamie W
Old 08-30-2010, 12:30 PM   #16886
Regional Moderator
CarbonJoe's Avatar
8500
2xxx
53
gearing 45/100
my motor was 100*
What tire size (so I can figure out rollout)?
Old 08-30-2010, 02:11 PM   #16887
20 SMOKE's Avatar
small,i dont use rollout,i dont see the need with the esc's we have today,i can let you know when i get home from work
Jamie W
Old 08-31-2010, 06:15 AM   #16888
Default RC Madness 10.5 setup??
any one got a good starting setup for RC madness TC track, 10.5 novak motor
never been there but going soon.
Brian H is offline   Reply With Quote
Old 08-31-2010, 11:01 AM   #16889
maxepower's Avatar
Thumbs up Tekin Brushless or Brushed!
Just wanted to mention FYI.
Using the Tekin RS brushless system for a brushed silver can motor just won 1st place in the TCS National Championship. He was a 16 year old and he blew away the field, everyone said who watched the race that his car just had more power than the rest of the field.
I too also used the same ESC and performance was flawless. I used it because I didn't have any good brushed ESC so I gave it a shot. Who knew?
So, what I'm saying is if you want to run a brushed motor you don't have to go out and buy another ESC if you have a Tekin brushless. If you do use it you will not be disappointed!
Just my 2$
Now back to our regularly scheduled programs!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 08-31-2010, 12:53 PM   #16890
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default KO radio settings
Hi,
I have a KO Eurus radio and I have forgotten what the throttle exp setting should be? +10%?
Also anyone with a good 17.5 limited profile set-up for 1C 12th scale racing V208? Average size track.
Thanks Greg G
Swampracer is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
