Old 08-23-2010, 09:34 PM   #16756
Regional Moderator
CarbonJoe's Avatar
Originally Posted by MantisWorx View Post
just making sure i have this right before i melt somethin down! if you are running in sensored mode it does not matter where the endbell timing is right?
No, in sensored mode it matters very much. The static timing in the motor is always there in sensored mode. In sensorless, the static timing doesn't really matter since the sensors aren't used anyway. In dual mode, the sensors are only used at startup and below some fixed low RPM.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-23-2010, 10:27 PM   #16757
warnos's Avatar
Default New Redline motors
Just a little something I noticed on my Tekin Reline motors.. two of my Tekin Redline motors have a 12.3mm rotor (21.5 and 17.5).. these motors are the older motors with no laser engraving.. the newer laser engraved motors I have came with 12.5mm rotors.. anyone else noticed this??
Always thought the newer motors had more punch.. but seems its also to do with the bigger rotor. On a large track we raced at recently the older motor had more speed down the straight.. makes sense why now..
cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 08-24-2010, 04:35 AM   #16758
Trader Rating: 15 (100%+)
Originally Posted by gameover View Post
yes, it's the weirdest thing i've ever seen, i work with embedded controllers and firmware every day, i cannot for the life of me work out why a simple software flash can cause this
with 203 i run my brakes at 65-75% on the radio, with 208 even on 100% they are strong but delayed when braking from high speed (ie. turbo mode on) the motor is turning in the 50k+ rpm mark.
I can see the full brake lights flashing so there's no issue with not getting full signal.
iv got this problem with 203 and 208, ok in dual mode but in sensor mode at end of long straight delayed brakes, only happens when brakeing after full timming (long straight), in,field ok. good luck let me know if you work it out id love to use my tekin again.
jay m is offline   Reply With Quote
Old 08-24-2010, 04:40 AM   #16759
HoJo's Avatar
Default ESC Shuts down after Turbo Kicks In
Hi, just wondering if anyone has experienced a situation where the ESC and/or radio seems to shut down upon turbo kicking in.
Let me describe the situation : this past weekend, my son's car had no steering whatsoever when it reached full speed with turbo. I am not sure if the throttle also shut down, but the the car had no steering and the momentum carried it straight into the wall at the end of the straight (damage assessment : spool outdrive smashed, broken top-deck, suspension pins and arms kaput !)
Car is a T3 with 7.6 FDR, timing boost at 50, start rpm 8k, end rpm 18k, turbo boost at 18, turbo ramp 1, delay 0.2.
I am wondering if the ESC could have shut-down once turbo kicked in as the power draw lowered the battery voltage below the LIPO voltage cutoff ?
Any views on what could have happened.
TIA
HoJo is offline   Reply With Quote
Old 08-24-2010, 04:59 AM   #16760
Originally Posted by Randy_Pike View Post
What motor is this?
Hi Randy,
I'm running a 10.5t X12
Chris...
XRAY T3 | Team HEI Australia
gameover is offline   Reply With Quote
Old 08-24-2010, 05:05 AM   #16761
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
make sure there is no push control on
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-24-2010, 05:36 AM   #16762
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Default LED question
Currently using version 208 and noticed something different with the LED's.
The LED in the middle is on then it takes the temp reading and back to the middle LED. Sometimes all the LED's flash for a second. This happens as soon as i turn it on, its not after a run.
Is this normal now for 208? You can see it happen at the 13,27, and 33'rd second. I tried new sensor cable, motor, and re-calibrated the radio.
+ YouTube Video
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-24-2010, 06:03 AM   #16763
20 SMOKE's Avatar
try resetting and re flashing 208 back
Jamie W
Old 08-24-2010, 06:37 AM   #16764
hairy's Avatar
[quote=nitrobeast;7847475]Currently using version 208 and noticed something different with the LED's.
+ YouTube Video
[/quote
Talk to the Techs at Tekin. that is the sure fire way to get an answer to your problem. they are there to answer questions about their product. I did and found that they are very helpful and knowledgable(sp?).
Since they built it they should know...right?
You will gat all kind of answers on this thread and some may be right and some will be wrong.
I spent time talking to Tekin reps. and got a solution to my problem.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 08-24-2010, 06:58 AM   #16765
Same problem here, ive read that this should be solved by reflashing ESC..
Xray | Tekin | LRP | Corally
Martyn666 is offline   Reply With Quote
Old 08-24-2010, 07:02 AM   #16766
Default f
+ YouTube Video
nitrobeast,after load 208 u have reset your esc then re-calibrated ? is reset not is re-calibrated..hope is help...
on d way is offline   Reply With Quote
Old 08-24-2010, 07:12 AM   #16767
hairy's Avatar
I rest my case......TALK TO TEKIN for straight answers!
MERLIN RACING
Old 08-24-2010, 09:33 AM   #16768
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
TIA
Sounds to me... most likely... he was just on the trottle too much, turned while still in turbo.. and pushed into the wall. either way, doesnt' sound like an issue with the tekin.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-24-2010, 10:17 AM   #16769
TIA
Had same thing happen to me but with car having no steering and going WOT down the straight. I have installed an external BEC and the car runs fine now. I have sent in a e-mail to tekin but still have not heard back
Friulimotosport is offline   Reply With Quote
Old 08-24-2010, 10:20 AM   #16770
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If the car lost steering that's a receiver/radio issue. What radio system are you using?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
