Old 08-23-2010, 02:32 PM   #16741
lbckevin's Avatar
Trader Rating: 91 (99%+)
I love the new 208 software...
I have no problems with it. I followed the instructions from Tekin and installed it on my laptop and my hobby shop computer and works great.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-23-2010, 02:45 PM   #16742
Armaan's Avatar
Trader Rating: 49 (100%+)
Default Tekin RS problem: Steering works, throttle dead
So, on Saturday I was at WCRC, and after hitting the double/tabletop jump, my B4 landed and just stopped moving. I pulled it off and noticed that the steering worked, but the throttle was dead.
I tried different sensor wires, 2 different motors, still nothing.
The LEDs on the RS all light up in sucession when I pull the trigger, and also light up when I brake, just as they normally would do...the only thing is that the motor doesn't move. I tried a brand-new motor, and the same thing...speedo lights up, but no movement.
I switched the channels of my receiver just to make sure it wasn't that, and the channels work fine (pulling the trigger steered the servo, turning the wheel lit up the LEDs on the speedo).
Anyone have something like this happen before?
Armaan is offline   Reply With Quote
Old 08-23-2010, 03:01 PM   #16743
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Me to love it!!! Tekin 208 for the win!!! Heard you killed it last night in 17.5 truck way to go kevin!!! See you soon!!!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 08-23-2010, 03:34 PM   #16744
macdude's Avatar
only time is when the power leads shorted together and the controller lost the program. I hooked it up to the hot wire and downloaded the defaults, then changed the settings and everything worked like normal again.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-23-2010, 04:22 PM   #16745
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
does it beep when turning on,make sure the voltage is set,this happens when going from 2cell to 1cell and you forgot to switch to 1cell.check solder joints and try moving the car and giving throttle at the same time
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-23-2010, 04:35 PM   #16746
Armaan's Avatar
I don't have the Hot Wire. I guess I'll go pick that up tonight from my LHS. I'll give that a shot. Thanks!
Old 08-23-2010, 04:35 PM   #16747
Armaan's Avatar
I only run 2 cell. It does not beep when I turn it on. Thanks though!
Old 08-23-2010, 04:39 PM   #16748
20 SMOKE's Avatar
i know,this is a problem that some have when going from 2-1 it does the same thing,ramp and no movement,check to make sure it did not change the voltage,it is a long shot but with some funny things happening anything is possible.try a reset and recalibrate
Jamie W
Old 08-23-2010, 05:07 PM   #16749
noline's Avatar
Hello There,
Does anyone have a LRP X12 8.5 Brushless 1/12th setup in the sensord mode? And what Spur and pinion should I use?
Here's the track size and my car info:
100"X45" Feet
1.72" inch rear tire
noline is offline   Reply With Quote
Old 08-23-2010, 06:28 PM   #16750
Originally Posted by Cpt.America View Post
Did you remember to a) reset your EPAs back to 100%, and then b) recalibrate your transmitter to your ESC?
yes, it's the weirdest thing i've ever seen, i work with embedded controllers and firmware every day, i cannot for the life of me work out why a simple software flash can cause this
with 203 i run my brakes at 65-75% on the radio, with 208 even on 100% they are strong but delayed when braking from high speed (ie. turbo mode on) the motor is turning in the 50k+ rpm mark.
I can see the full brake lights flashing so there's no issue with not getting full signal.
XRAY T3 | Team HEI Australia
gameover is offline   Reply With Quote
Old 08-23-2010, 07:02 PM   #16751
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
What motor is this?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-23-2010, 07:06 PM   #16752
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
looking for a starting poing on a 17.5 tekin rs setup on 1s lipo in a 5.1. We are allowd to run boost and my track is 70x35 feet.
micrors4guy is offline   Reply With Quote
Old 08-23-2010, 07:21 PM   #16753
20 SMOKE's Avatar
http://www.teamtekin.com/hotwire/ESC...03-17-5-TC.pdf
Jamie W
Old 08-23-2010, 09:24 PM   #16754
MantisWorx's Avatar
Trader Rating: 28 (97%+)
just making sure i have this right before i melt somethin down! if you are running in sensored mode it does not matter where the endbell timing is right?
MantisWorx is offline   Reply With Quote
Old 08-23-2010, 09:27 PM   #16755
20 SMOKE's Avatar
no,motor timing is used.dual mode does not
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
