Old 08-16-2010, 09:04 PM   #16561
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by mist467 View Post
Im experiencing problems with 208 i never has with 203..Car is overheating and feels alot less punchy. I can deal with the less punchy part but its been running at 200 since i switched over and i cant get it to cool down.
Setup is
Epic Dual2 17.5
Middle on the timing
45 timing
10 turbo
.3 delay
Throttle profile 5
turbo ramp 3
and have tried between 6.4 to 7.2 gear wise. Seems to always be at 185 and up temp. Any ideas? This was at a tight indoor track.
turn the turbo off and go to the first mark to the pos side from center and see how it feels,leave everything the same with a 3k start and 12k end
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-16-2010, 09:07 PM   #16562
chinamonkey7's Avatar
Setup is
Epic Dual2 17.5
45 timing
10 turbo
.3 delay
Throttle profile 5
turbo ramp 3
Use Mark Burt's national setup, that will work for sure
chinamonkey7 is offline   Reply With Quote
Old 08-16-2010, 09:08 PM   #16563
Originally Posted by EAMotorsports View Post
Is it a newer Duo 1 motor? If so they changed the stator design in them about 2 months ago to the same as a Duo 2 so they have to run with less timing in the motor now like the 2's like.
EA
So I should start out at the first hole and try a 6.0 final??
Old 08-16-2010, 09:16 PM   #16564
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Yes that is what I would try first. Possibly even try a 6.3-6.5FDR depending on track size.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-16-2010, 09:24 PM   #16565
Impulse_racer's Avatar
Thanks for putting this link up. The article cleared up a lot of questions. I would advise everyone who is trying to figure out this programming the ESC stuff on the RS/RS Pro. This will save you hours of reading back on the thread. If you cook a motor after reading this, well.....there is always silver can racing.
Originally Posted by 20 SMOKE View Post
a write up on the rs that helps
http://www.carsrcracing.co.uk/?p=188
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Old 08-16-2010, 09:27 PM   #16566
Trader Rating: 27 (100%+)
link to marks setup?
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
[email protected]
mist467 is offline   Reply With Quote
Old 08-16-2010, 10:23 PM   #16567
RTR canada's Avatar
yea link would be great or even if Tekin would post some new setup's for 2.08 TC 17.5. just want to see if it's at all close to what i have. Thanks
RTR canada is offline   Reply With Quote
Old 08-16-2010, 11:08 PM   #16568
syndr0me's Avatar
Trader Rating: 32 (100%+)
My newer RS requires a higher delay than my old one to keep the turbo from kicking in at the wrong time. The old one is fine at .2, the new one needs at least .4 with all other things exactly the same. I don't know what that means, but I guess don't be afraid to raise your turbo delay, even if it's higher than what your buddies tell you they run.
syndr0me is offline   Reply With Quote
Old 08-16-2010, 11:14 PM   #16569
Default Thanks
My RS was fast last wekend. Very Nice!
Sterling Racer is offline   Reply With Quote
Old 08-16-2010, 11:18 PM   #16570
I see people asking for setups for motors but I think that with all the options v208 offers it is just like the suspension setup on the car. What works for one driver will be all wrong for another. I think we just need to get out on the track, run laps and experiment just like when you are trying to dial in the suspension. Start with conservative settings like the article implies, run some laps. Make a change and run some more laps. If your times drop and the motor stays relatively cool you are on the right track. It is time consuming but you will end up with a profile that suites your driving style instead of cutting and pasting a pro drivers setup and most won't end up on here complaining about weak brakes and motors going soft. Or burning up. Just a thought.
Xray T3 EU
KO Propo Helios
Hudy
Litemodz CVS
Old 08-16-2010, 11:25 PM   #16571
Originally Posted by JCarr View Post
I finally got to try out 208 on saturday. I just used teh same setting I had in 203 and the car was running 10-15* cooler and great brakes.(not that I had a problem before) I did however, have an old problem pop back up though that I had just fixed in 203. It seems I have good acceleration, but it seems like in one of the slower parts of our track, when partially on throttle, the car suddenly lunges forward and makes me push way off line. It was a while ago when I fixed this issue before so now I can't remember what I did to fix it. Does that sound like the boost may be coming in a little early and I should rais my start point? Right now my start point is at 5xxx and end at 15,xxx using a ballistic 17.5 with the timing one mark on the + side of the N.
Originally Posted by Randy_Pike View Post
This sounds like your turbo is coming on in the infield.
He says he's on partial throttle, so perhaps not the turbo? Throttle profile? The 208 is rumoured to have more progressive throttle response, so maybe it just feels different? Just some thoughts...
SlowerOne is offline   Reply With Quote
Old 08-17-2010, 12:02 AM   #16572
loriding69's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to loriding69
It wasn't fast at all.................It was a freak'n rocket dude!
and my SC, well we want speak about that
Double E
If your not here to have fun, then stay at home!!!
Breast Cancer Awareness is my race for the cure!
loriding69 is offline   Reply With Quote
Old 08-17-2010, 12:48 AM   #16573
TrevCoult's Avatar
I had that once with 203, I just dropped the start RPM one step to widen the range a little and it was fine.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 08-17-2010, 12:52 AM   #16574
TrevCoult's Avatar
I'm in the process of writing a 208 version of the guide. A few family things have been getting in the way or it would have been up there already.
Both the current and new ones are 12th scale biased as that is what I run, but 90% also applies to other classes too, so don't let that put you off.
Thanks for the kind words about it, happy it is helping people.
I also hope Mark Brown is able to update his guide. It is quite a task to do though as it is massive!
Trev
Schumacher Racing
Old 08-17-2010, 02:10 AM   #16575
For Mark's setup, check Pg 1098
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
