Old 08-16-2010, 07:32 AM   #16546
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Akudou View Post
Blow overs? You blew the motor you mean?
Mind sharing with me the settings for the 4.5T sensored turbo and its FDR? Would love to improve this current setting as we are trying to keep up with hobbywings turbo mod firmware on low turn motor.
No, blow over as in: air got under the car and lifted it into the air, causing it to do a couple of flips in the air before crashing back down.
I do not remember the FDR but the settings were something like: boost 35, turbo 10, ramp 2, RPM 7,000 to 20,000. It had WAY TOO MUCH power.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-16-2010, 10:34 AM   #16547
Hi all.
What are the effects of motor timing? For example, max timing boost, max turbo and no motor timing vs max timing boost, no turbo and max motor timing? In general, What would be the difference in these two settings?
RSCosworth is offline   Reply With Quote
Old 08-16-2010, 12:48 PM   #16548
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Matt W View Post
Hi,
Has anyone used the new 208 software yet? i ran mine the other night using the same settings as v203 and it ran no cooler and seemed to have very aggressive acceleration, not smooth at all, r u supposed to run different settings or gearing with the new software?
any thoughts?
If anything you should notice cooler temps and I'd double check your settings and make sure that everything is exactly the same as your 203 settings. I personally felt that 208 was smoother but there wasn't anything done to the throtle profiles from 203 to 208. Can you please post the settings you ran along with motor and motor timing?
STLNLST is offline   Reply With Quote
Old 08-16-2010, 01:29 PM   #16549
JCarr's Avatar
I finally got to try out 208 on saturday. I just used teh same setting I had in 203 and the car was running 10-15* cooler and great brakes.(not that I had a problem before) I did however, have an old problem pop back up though that I had just fixed in 203. It seems I have good acceleration, but it seems like in one of the slower parts of our track, when partially on throttle, the car suddenly lunges forward and makes me push way off line. It was a while ago when I fixed this issue before so now I can't remember what I did to fix it. Does that sound like the boost may be coming in a little early and I should rais my start point? Right now my start point is at 5xxx and end at 15,xxx using a ballistic 17.5 with the timing one mark on the + side of the N.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 08-16-2010, 02:31 PM   #16550
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
This sounds like your turbo is coming on in the infield.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-16-2010, 05:41 PM   #16551
chinamonkey7's Avatar
any good setup for Duo 1??I blow 2 of them this weekend
chinamonkey7 is offline   Reply With Quote
Old 08-16-2010, 05:46 PM   #16552
MikeXray's Avatar
Trader Rating: 73 (100%+)
For those that were saying they had weak brakes on 208, I noticed this this weekend. I reflashed 208 in the middle of the day, and I didn't change drag or push from default, I believe this is 0 for both. My car felt like the brakes were alot weaker than normal, I added 10 drag and they felt better.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-16-2010, 05:46 PM   #16553
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
felix what is the setup now
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-16-2010, 08:11 PM   #16554
Middle timing on motor
208 software
48 boost, 12 tubro, profile 3, 0.2 delat, 2.0 rate, start 3000, end 12000,
gearing: have try from a 6.3 to 7.2 final drive ratio, can't find a gear combo, my motor keep running 200+ degree,
NO Moooore Powahhh for me
Old 08-16-2010, 08:17 PM   #16555
artwork's Avatar
Trader Rating: 62 (100%+)
208 software
Sup Felix...
At Nats I was running a 17.5 Duo1 with the following settings:
Middle Hole on the Duo (10deg)
50 Boost
10 Turbo
Profile 2
Delay .3
Ramp 2
Start 7953
End 17000
6.05 Gearing with a good high speed fan
Car was easy to drive and coming off about 160 after 6 minutes
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 08-16-2010, 08:26 PM   #16556
Helllooo Art
thanks for the setup, I will give that a try
Old 08-16-2010, 08:31 PM   #16557
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Can I get a gearing recommendation for v208 stock spec profile with the SP 3.0 17.5? This is for a true sportsman driver, he is pretty new. Track has a 135' foot straight for this parking lot race.
Thanks Guys.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-16-2010, 08:44 PM   #16558
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
208 software
Is it a newer Duo 1 motor? If so they changed the stator design in them about 2 months ago to the same as a Duo 2 so they have to run with less timing in the motor now like the 2's like.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-16-2010, 08:50 PM   #16559
Trader Rating: 27 (100%+)
Im experiencing problems with 208 i never has with 203..Car is overheating and feels alot less punchy. I can deal with the less punchy part but its been running at 200 since i switched over and i cant get it to cool down.
Setup is
Epic Dual2 17.5
Middle on the timing
45 timing
10 turbo
.3 delay
Throttle profile 5
turbo ramp 3
and have tried between 6.4 to 7.2 gear wise. Seems to always be at 185 and up temp. Any ideas? This was at a tight indoor track.
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
[email protected]
mist467 is offline   Reply With Quote
Old 08-16-2010, 09:00 PM   #16560
MikeXray's Avatar
Thanks Guys.
Start at 4.0, you can go lower, but its a good starting point.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
