Old 08-14-2010, 08:57 PM   #16516
Trader Rating: 17 (100%+)
Default duo 17.5 rpm
looking for rpm setting for my duo 2 17.5 with tekin 208
markny is offline   Reply With Quote
Old 08-14-2010, 09:00 PM   #16517
kartermdb's Avatar
Trader Rating: 15 (100%+)
Randy posted my nats setup a few pages back, take a look at it, it should give you a good idea.
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 08-15-2010, 04:08 AM   #16518
Hey guys,
I just got my first BL setup, an RS with 10.5 redline motor.
I am getting a little worried as the acceleration is INSANE yet I have now got my FDR down to 4.5... I note that most others are running 10.5 in the 6s.. Is there any reason for this?
Car is an HB cyclone, 40/75 with 16t pulleys (2.4375 chassis ratio) = 4.57 FDR.
After a long bash on the street (the full life of my lipo) I am still able to touch the motor... So its not burning hot.
FYI I am running the ECU on the stock firmware and am yet to plug in my hotwire.
Any input and suggestions for settings would be great. Just want to make sure this is normal and im not putting it under undue load (back in the brushed days I would gear the thing to suit my acceleration desires).
Cheers,
shadowR is offline   Reply With Quote
Old 08-15-2010, 06:09 AM   #16519
macdude's Avatar
Originally Posted by shadowR View Post
Hey guys,
Cheers,
This sounds pretty normal. The default mode the controller is running in is dual mode. That way it starts out sensored and the runs sensorless. Which is more effecient than running in sensored only mode. The big difference between brushless and brushed is the amount of torque the motor is able to generate. If you switch to sensored only mode you will want to gear down some and then play with the advanced timing function to achieve the right top speed for your track. This will make the motor hotter ( less efficient) but better power control. Really it will just depend on your driving style. I would go to the track and ask around and see what others are running and/or try out their cars. If you are keeping up around the track you may want to leave the setup as is.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-15-2010, 06:48 AM   #16520
Thanks macdude,
I actually geared back down (FDR 5) and pumped the timing up to 72 (on version 180) to feel a drop in power. I also tried this on the taller gears and felt it was over geared...
Perhaps I will go back to dual mode and try gearing up another notch to 4.2..
Im generally only going to be a basher and meet with friends in the city for tiled fun (been doing this since I was a kid) so track time will be scarce (unless by some form of miracle I get hooked). Im feeling the all out torquey feeling really suits me, its why it took me years to switch away from brushed (I loved the feel of a good 27 or 23).
Thanks again, I guess I was probably expecting too much from the timing boost.
Old 08-15-2010, 10:57 AM   #16521
Jochim_18's Avatar
First time out with the tekin RS last night I almost TQ on expert stock if I haven't clip a darn disc but manage to take the win on A-main. Overall I'm very happy I switch to tekin I'm back on the game again. I'm still running the 203 firmware but overall power delivery is smooth and wow I got some top end that was lacking on my Mamba max pro.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 08-15-2010, 11:40 AM   #16522
jtrcracing's Avatar
sounds great! congrats!
what engine did you use?
Shepherd velox v10, robitronic protos v2,robitronic mantis.
Shepherd Velox v8.
jtrcracing is offline   Reply With Quote
Old 08-15-2010, 01:06 PM   #16523
Jochim_18's Avatar
Novak Ballistic...
Old 08-15-2010, 01:36 PM   #16524
Originally Posted by Jochim_18 View Post
Novak Ballistic...
I have a problem, getting my 10.5 ballistic to be fast. Seems to never get hotter than 50*....
So i wonder how yor RS setup is?
When gearing heavy, 6.6 FDR it fades after 2 min, but temp is low..anyone?
Finken is offline   Reply With Quote
Old 08-15-2010, 01:42 PM   #16525
macdude's Avatar
Post your settings. I would guess that you are getting turbo fade. Sometimes setting the end point of your radio a little past 100% will fix it . Might also try setting your delay a little higher. And a little lower ramp for turbo. Probably also need to set your starting timing boost RPM setting higher. I ran into this problem with a 17.5. When I started gearing for the speed, it was too much timing too fast and I ended up going slow. Not just a little slower, like 2.5 sec a lap slower. Just from getting my RPM range and turbo settings to work together fixed my issue. I haven't run a 10.5 but there are a lot of guys on here that do and should be able to answer you questions. But it is always nice to know where your are starting.
Old 08-15-2010, 02:08 PM   #16526
My settings is
Motor endbell N (on ballistic this is 30* or? This is a problem, Novak says 30 on N mark, other motors have 15 on N mark. This is confusing me.
Timing Boost 45
Turbo boost 10
Ramp 0.2
Turbo delay 0.2
Start rpm 5xxx
end rpm 20xxx
FDR 6.14
My competitors have MUCH more power, low and high. They run all on max, 5-20 X12 with FDR 6.14
One guy ran FDR 8.40 and ripped his belts and pullys..... but got 130* on X12
My motor dosent get hot, 45-55 degress C
Old 08-15-2010, 03:01 PM   #16527
Its always difficult comparing different motors Finken - who knows what the real motor timings are! BUT IMHO 5xxx is just WAY too low for a 10.5, especially on an X12; not familiar with the Ballistic but I can't believe 5K is OK. I start my X12 (-5deg timing insert) at 13xxx and my Tekin at 11xxx..
Can you actually see/feel your Turbo coming in before/after the car fades? Might be worth pushing the delay out to 0.5 + so you can check it IS coming in.
What is your ESC temp.?
yellowshark is offline   Reply With Quote
Old 08-15-2010, 03:19 PM   #16528
Tekin RS /RS pro 208 software set up
Has anyone got a link to an explanation of how the software works regarding boost turbo and timing advance, I am running a tekin rs with a GM brushless sport motor which is STAR wound will this affect the settings I need to use including the FDR on my xray t3 touring car.
I run indoors and overheating the motor is a realy big problem.
update.
I need to get my head round how the boost and turbo work and how to gear the car as I think I may have been over driving the motor.
there is no real info on the 208 software regarding set ups on the tekin website or forum .
I've just done a few runs with timing advance at zero, boost at 45 with 14000 to 4873 rpms and a turbo of only 5 and I get about 55degc with no fan fitted with a fdr of 7.5 .
I need to find a base fdr and also a base timing advance as my gm 13.5 brushless sport is labeld as having advanced timing 30 degrees.
the car seemed quick but didnt have the top end spool up ( posibly due to the advance being zero) but without somthing else to compare it to I have no idea
mobile chicane1 is offline   Reply With Quote
Old 08-15-2010, 04:04 PM   #16529
darrenoakley's Avatar
Think I am finishing at 14000rpm (same motor) and starting somewhere around 5000/6000
I find that it keeps the temps down nice at this setting.
Great motors though
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 08-15-2010, 05:00 PM   #16530
Hi guys I could really do with some help on where to start with this one.
Big regional meet today and I put the car down for Q2 and the ESC wouldn’t bind to the transmitter, all the lights were flashing. I tried a quick calibration but the single light just stayed in the middle blinking.
So I retired to the pit, tried a few times switching the transmitter and esc off, going into calibration mode. Sitting there it suddenly bound and I got 4 laps in.
Back at the pits it lost it again. In desperation I
Deleted and reinstalled Hotwire on the computer
Connected the ESC and hit Update to update the firmware with 208
Rekeyed my settings over the factory settings
Tried to calibrate and it worked.
Probably 3 or 4 minutes before Q3 I checked it and same problem. . Same thing I couldn’t fix it with calibration and then all of a sudden it bound and calibrated. I left it all on and then headed off to Q3.
In all it dropped out 4 or 5 times during the day but fortunately it was only Q2 that was missed. On the track there was certainly no problem, coming 2nd in the A final.
NOW today is the first time we have ever run with 208 – a red herring?
Loose connection – thinking about the vibration during a race and wondering how there was not an issue during racing if it were this.
Calibration is done with setting the throttle/brake epa back to 90%
KO transmitter and KO 2.4 module.
Have run this 2.4 for 18 months and never had a problem. Have run 203 since March and never had a problem. Could it be software or must it be hardware
Any ideas??
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
