Old 08-12-2010, 12:07 PM   #16456
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by yellow_grey View Post
Got a brand new Tekin RS Pro ESC and downloaded the new Vegas and Hotwire software.
Did the update as per the instructions and ESC was updated to 208 as shown in the advanced tab. However upon restoring default settings, error message was displayed.
"Some of the user values are outside the expected range! Your esc may not be compatible with this version of Hotwire."
I get the same message when i connect the ESC after restarting Hotwire software!
Now my ESC doesnt even light up and beep when i hookup the battery and switch on the receiver!
When i try to load the deafult settings and save it several times.... there are times when the above error message appears but there are times when it says it has saved it. However when i click on the current settings button to check what is loaded into the ESC, it goes back to the previous setting and doesnt want to load the 208 default settings!
Help!!
Let's do this first. Don't hook up the esc, plug in the hotwire and start the software. Hit the "help" button and let us know what the software version is please.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-12-2010, 12:09 PM   #16457
Team Tekin
Randy_Pike's Avatar
Default Mark Burts Tq and Roar National Champ Tekin RS Setup
Here it is. Understand that Mark was carrying more corner speed than most with this setup. He simply didn't slow down in the corners as much as the other drivers. His FDR with this setup was 6.14.
Old 08-12-2010, 12:55 PM   #16458
M-Technic's Avatar
Trader Rating: 15 (100%+)
Mark lent to this setup to me at a local invitational race last month and it was fast and ran cool. This was a week or two before 208 was released but the only difference (and it may have been because of the track) is that were were running 5.9 FDR's.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-12-2010, 01:46 PM   #16459
kartermdb's Avatar
I also was running a touch of negative timing on a duo 2. I have not tried it with positive motor timing or a duo1. So temp often your first run!
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 08-12-2010, 02:36 PM   #16460
DaveW's Avatar
I know this is an RS thread, and this is probably a stupid question... but i just picked up an RX8 and was curious if everything i have learned with the RS can be used as a foundation to tune my RX8, and do i install 208 on the RX8 as well?
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 08-12-2010, 03:41 PM   #16461
macdude's Avatar
From my understanding yes update to version 208. But don't run the motor sensored only. Everyone that I know using an RX8 is has had problem with heat running in sensored only mode. Run it in Dual mode and check out the release note for 208 give some good tips to get the most out of running the T8 motors.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-12-2010, 04:02 PM   #16462
reenmachine's Avatar
Trader Rating: 26 (100%+)
Somebody correct me if I'm wrong, but I don't even think it's possible to run the RX8 in sensored-only mode.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 08-12-2010, 04:46 PM   #16463
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i believe you are correct,still the dual drive with timing profiles
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-12-2010, 07:05 PM   #16464
macdude's Avatar
Ok you are correct. I guess the guy that was telling me he was having problems with his was mistaken. I only run the MMP with a T8 motor in my 1/8 buggy.
Old 08-12-2010, 09:00 PM   #16465
lbckevin's Avatar
Trader Rating: 91 (99%+)
Your guys are wrong....
Yes, you can run an rx8 in sensored only mode. It was designed for sensored motors.
I am running an RX8 in my Jammin 4x4 in sensored mode with no problems at all. It does not get hotter than 97 degrees....
Read before you post.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-12-2010, 09:05 PM   #16466
Krio's Avatar
Trader Rating: 150 (99%+)
No, you cannot run sensored only in the RX8. The RX8 may use sensors to start, but you cannot change the fact that it goes to dual mode once rolling. This was done because the tekin T8 motors (and any other quality 8th scale motor) will not run properly on the high amount of advanced timing provided by the sensors, so tekin wisely removed the option to prevent meltdowns from people trying to run boost on 8th scale motors.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-12-2010, 09:36 PM   #16467
I didn't say it doesn't run sensored motors, just that it doesn't run in sensored only mode. It does run in dual mode, however, which uses the sensors to start and then reverts to sensorless.
Read before you post lol.
Pete Waydo
Old 08-12-2010, 09:49 PM   #16468
Team Tekin
Randy_Pike's Avatar
The Rx8 cannot run sensored only mode...It DOES however run in dual mode which is a sensored start, sensorless drive.
Old 08-12-2010, 10:11 PM   #16469
Still Bill's Avatar
And now back to RS discussions...LOL
Randy,
Do you have Mark B's WGT settings? He switched to an RS in his Darkside car for the A-main races. That gave him good speed on the back straight for Sunday.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-12-2010, 10:33 PM   #16470
DaveW's Avatar
lol Thanks guys... food for thought.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
