Old 08-11-2010, 08:40 PM   #16441
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
use the 203 setup,should be just fine
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-11-2010, 09:26 PM   #16442
Send a message via MSN to yellow_grey
Unhappy 208 update problem... ESC now not functional
Got a brand new Tekin RS Pro ESC and downloaded the new Vegas and Hotwire software.
Did the update as per the instructions and ESC was updated to 208 as shown in the advanced tab. However upon restoring default settings, error message was displayed.
"Some of the user values are outside the expected range! Your esc may not be compatible with this version of Hotwire."
I get the same message when i connect the ESC after restarting Hotwire software!
Now my ESC doesnt even light up and beep when i hookup the battery and switch on the receiver!
When i try to load the deafult settings and save it several times.... there are times when the above error message appears but there are times when it says it has saved it. However when i click on the current settings button to check what is loaded into the ESC, it goes back to the previous setting and doesnt want to load the 208 default settings!
Help!!
Radio: Fut 14MZ, Fut 12FG, Fut 4PK, KO EX-10
Rotary - Aurora 90, Vibe90SG, TT R90SE, A TREX600N Flybarless, 500SE, 450SE
F.Wing - Spot On120, Ultimate120, Tucano90, Mustang50, Ultimate40, Piper15
Jets - Baby Boomerang Jetcat P80, Rafale Jetcat P60SE, Skyhawk A4, Velox
On/Off Road - T2'009,T3,733,S18,Atlas Beat,MiniZ4WD,XB808,ZX-1,Savage Flux, TRF511,SCX10
yellow_grey is offline   Reply With Quote
Old 08-11-2010, 09:26 PM   #16443
Originally Posted by bvoltz View Post
I will look at it again, but I though you are asked to enter a start, then press the calc button, when I enter 4,000 a pop-up comes up and tell's me to start at 4,000 or higher.
You enter END, then calc, then select start.
-Mike
Old 08-11-2010, 10:41 PM   #16444
Jochim_18's Avatar
Just went to the DARKSIDE and got myself a tekin RS
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 08-12-2010, 04:09 AM   #16445
StevenOlsen's Avatar
hi guys, just thougt i post my tekin setup i has a lot of rip, i nearly keeps up with a mod car I looses about 2 sec over a 5 min run.
i have attatched my setup and a layout if the track, the straght is 25-30 meters
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 08-12-2010, 04:40 AM   #16446
marcel p's Avatar
Send a message via MSN to marcel p
again a crazy setup.
is this sensorless?
if i run this setup with sensor i burn my motor within 1 minute
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 08-12-2010, 05:28 AM   #16447
20 SMOKE's Avatar
Help!!
Un install the HW and re install,it sound like something didnt install,try a master reset on the esc by holding down both button.that message was there when 200 came out
Jamie W
Old 08-12-2010, 05:34 AM   #16448
Akudou's Avatar
You have any basic setups for Turbo's on mods? Would love to try a few minus the sacrifices of a few motors
Originally Posted by Randy_Pike View Post
Turbo can be used on mods it simply must be done properly. There are very few times where I've felt it would be needed. In mod if you need more motor, MOTOR UP!
Akudou is offline   Reply With Quote
Old 08-12-2010, 06:15 AM   #16449
is this sensorless?
nope its sensored, running it with a SP 13,5 V.3 an with a LRP fan
Steven Olsen
Old 08-12-2010, 07:26 AM   #16450
20Smoke,
Thanks for the reply.... spent a couple of hours figuring it out, but this time from a WinXP desktop.... got the same error message when i first hooked up the HW, but after updating the ESC with 208 again, it worked and was able to reset to default settings.
The previous update was done on a Win7 machine, so haven't tried to uninstall and reinstall again. I'll just leave it to the WinXP then, and maybe wait for an iPhone client when that gets out....
Old 08-12-2010, 08:31 AM   #16451
kartermdb's Avatar
Trader Rating: 15 (100%+)
Originally Posted by COLD AS ICE View Post
anybody have a good setup for 17.5 tc on 100 foot track with duo2 and 208 software?
Originally Posted by bkspeedo View Post
Anyone from Pavement Nats want to post TC Expert settings?
My settings from nats will be posted on the site whenever Randy gets around to it, he has them. It was a duo2 but the straight was a touch longer than 100 ft so a little adjusting should get you close.
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 08-12-2010, 08:49 AM   #16452
M-Technic's Avatar
The number that you manually enter is the end RPM, not the start. Your end should be much higher than 4,000.
I highly caution against anybody just popping this setup in their Tekin and running it for more than 30 seconds without temping. It will almost surely cook your motor.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-12-2010, 09:05 AM   #16453
Akudou's Avatar
+1 on that.. too much positives even if i say so myself
Old 08-12-2010, 09:14 AM   #16454
hey guys
got the brakes working but the speedo seems to have lost all its power
i tried various setups with it including my best lap time setup but it is now 2 seconds a lap slower , i can go full throttle coming into the corner and it doesnt seam to pull
motor temps are only 45 to 60 degrees C
we have a 210ft straight with a flowing quick track
any ideas the only way i can get it to move well is to MAX timing and MAX turbo with gearing of 6.8 !!!
sidecarphil1 is offline   Reply With Quote
Old 08-12-2010, 11:32 AM   #16455
TrevCoult's Avatar
I am amazed everything has not gone up in a great big cloud of smoke, there's a max of 80 degrees of timing on it, and it all comes in early!
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
