Old 08-11-2010, 05:06 AM   #16426
Akudou's Avatar
The new 208 have strong improvement on the brakes and is very much cooler on the motor at 56deg C 7min run after fiddlng with it on last weekend's race. Increased the endbell timing, the boost timing and even the fdr and the temp stayed consistent. Well done Tekin
Akudou is offline   Reply With Quote
Old 08-11-2010, 05:45 AM   #16427
mazmo's Avatar
Originally Posted by nerdling View Post
Hey H9_Nutter. Attached is my base line setup that I use for both 13.5 and 10.5. I think it might work for you. The screen shot is for 13.5, for 10.5 (and 8.5) I'd drop the timing and boost back a few steps with appropriate adjustment in gearing.
nerdling ... how much motor timing are u using?
thanks in advance
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 08-11-2010, 06:19 AM   #16428
macdude's Avatar
I notice this too. I haven't been running the RS because I was getting it done with a MMP. But I always like to try the new firmware to see if it is smoother than it was. Well I was really surprised at how good it feels now. And the motor is running 20-30 degrees cooler. Almost like running no timing.
Hopefully they will continue to work on the controller feel. I am trying the Novak Kinetic today. I suspect it to be even smoother than anything else I have tried. But we'll see. If it is not good there a few guys at the track that want it. And I don't even have it yet.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-11-2010, 06:38 AM   #16429
Akudou's Avatar
I use to run the rs with almost very limited timing, boost, throttle feel, turbo etc on the 203 and with the 208 i manage to raise the stakes of the feel, boost timing, turbo, endbell timing and even the fdr's and the motor is 15 to 20 deg Celsiuis cooler on the 208 which will eventually give u ample of space for fine-tune your setups. I run my RS on the sanwa M11-x and have yet to give it some more run time before i exploit the problems with the rs issue everyone have been talking about. Isnt the Novak kinetic is as similar as the LRP motors? Correct me if i am wrong.
I'm looking to try out the Redline series of motors and might startout with the 6.5T. Have never tried out anything lower than 11.5T sensored.
Old 08-11-2010, 07:11 AM   #16430
macdude's Avatar
The Kinetic is the new Novak Controller. It has dinamic timing build in. And it has 2 profiles. Just about everything can be adjusted from the controller. Timing, boost, rpm range. If you want more adjustability then you have to buy the novalink and then you can tune it like the RS via the hotwire.
But I am suspecting that it should be as smooth if not smoother than the LRP controller. I have never run one of those, mostly because all the guys that used to race brushed motors tried to convince me of how great they where, but I was always novak or tekin. As both where made state side.
Old 08-11-2010, 12:03 PM   #16431
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i would not use max turbo,there a re far better setups to get with out being maxed
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-11-2010, 12:45 PM   #16432
Akudou's Avatar
Usually the higher a turn of the motor, the higher boost or turbo one would use. Have never heard of anyone on the Tekin using turbo's on lower turn motors but i have seen the likes of hobbywing and have seen successive runs on their turbo mod on 3.5T's! Would love to give these a try on the Tekin but one step or one turn at a time..
Old 08-11-2010, 05:16 PM   #16433
bvoltz's Avatar
Trader Rating: 44 (100%+)
With ver 208, how do you get the starting RPM below 4,000?
bvoltz is offline   Reply With Quote
Old 08-11-2010, 05:48 PM   #16434
20 SMOKE's Avatar
start depends on what end you have,it is calculated formula
Jamie W
Old 08-11-2010, 06:08 PM   #16435
forrestboy's Avatar
Trader Rating: 16 (100%+)
Is there any way to have the 203 and 208 software on the same computer?
Team C Racing
evohobbies.com
forrestboy is offline   Reply With Quote
Old 08-11-2010, 07:08 PM   #16436
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Turbo can be used on mods it simply must be done properly. There are very few times where I've felt it would be needed. In mod if you need more motor, MOTOR UP!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-11-2010, 07:28 PM   #16437
bvoltz's Avatar
I will look at it again, but I though you are asked to enter a start, then press the calc button, when I enter 4,000 a pop-up comes up and tell's me to start at 4,000 or higher.
Old 08-11-2010, 08:04 PM   #16438
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
With a 30mm rollout, 4000RPM is a leisurely 7km/h. Adding too much timing too early will only result in extra heat. Anyway, it all depends on what you're trying to achieve. My current 21.5 setup has the timing kicking in around 8k RPM, but I use some motor timing on the Tekin Redline to give it some initial punch. YMMV
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 08-11-2010, 08:14 PM   #16439
Still Bill's Avatar
For WGT, I didn't have any problems with Novak or TQ boosters; however, I have more battery resources available towards the end of a run with a 200 mahr LIFE servo battery pack (requires no additional circuit board). And the LIFE also brings me up to minimum weight (930 gm) on my Gen-X 10.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-11-2010, 08:34 PM   #16440
Dog Bone's Avatar
Anyone have any setups for 1/12 on a relatively small track with the v208 software with a 17.5bl? There are a few v203 setups on the Tekin site, but nothing for v208 yet...
The track has a pretty tight infield, with about a 60' straightaway...
The car is a 125R.1.
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
