Old 08-09-2010, 10:31 AM   #16381
Have the same braking problem as discussed here, i have also small delay before full braking power comes i also run LRP X12 motor (but 17.5T), using LRP transmitter.
Didnīt tried reflashing yet..
Xray | Tekin | LRP | Corally
Martyn666 is offline   Reply With Quote
Old 08-09-2010, 11:17 AM   #16382
macdude's Avatar
Just went to the track over lunch. With a duo 2 17.5 I get plenty of brakes.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-09-2010, 11:28 AM   #16383
Originally Posted by MikeXray View Post
For those with brake problems, have you tried re-flashing 208. I haven't seen anyone get less brakes with 208 around here??
ok , how do i reflash 208 ???
and do i do a reset after the reflash ???
sidecarphil1 is offline   Reply With Quote
Old 08-09-2010, 11:48 AM   #16384
Default 17.5 help
Hello,
Here is what I ran yesterday:
1/12
RS pro
17.5 Trinity(might be my problem)
80 spur
58 Pinion
New BSR tires
208 software
Boost 30
Turbo 4
This is my first time running 17.5 mainly run 13.5. I was getting beat pretty bad at the fast parts of the track. I am wondering where I am going wrong. The guys that were faster than me we also running RS's. I know I am missing something. The power difference is pretty obvious. Does anyone know what I might be doing wrong?
hacker1 is offline   Reply With Quote
Old 08-09-2010, 12:01 PM   #16385
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by hacker1 View Post
Hello,
1/12
RS pro
80 spur
58 Pinion
New BSR tires
208 software
Boost 30
Turbo 4
what size track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-09-2010, 12:09 PM   #16386
pakk's Avatar
Trader Rating: 79 (100%+)
It took a year and half, but one of the wire leads that go into the RX finally broke yesterday after a year and a half of tugging on the wires to program the ESC. I know I shouldn't be doing that and I have no one to blame but my self. I even have a short extension, but I don't really like using it.
If it comes down to it, I'll use the extension. I should probably buy a few more for my other tekins.
But I'm hoping, just maybe, that someone makes a small enough gauge wire to with stand this kind of abuse. That way I could yank on the wires to my liking. Anyone know of such a wire?
(just happened to be my biggest race ever too. #1 spot in the roar nats sportsman B main leading the race till my car turned off)
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 08-09-2010, 12:11 PM   #16387
Originally Posted by 20 SMOKE View Post
what size track
The track is about a mid size track.
Old 08-09-2010, 12:21 PM   #16388
20 SMOKE's Avatar
start 3xxx
end 6500
45 timing boost
5-10 motor
40/80
Jamie W
Old 08-09-2010, 12:24 PM   #16389
I GOT BRAKES
i think , tested it outside on the street and it looks ok
Old 08-09-2010, 12:27 PM   #16390
start 3xxx
end 6500
45 timing boost
5-10 motor
40/80
Was I over geared? also what would you gear a small track maybe I will try both setting. The track to me is small but everyone says its about a mid size. Thanks for all your help.
Old 08-09-2010, 12:43 PM   #16391
20 SMOKE's Avatar
you can try the 40 for a small and try a 45 on the med,you may be closer to 50 but its better to start low and go up
Jamie W
Old 08-09-2010, 01:32 PM   #16392
M-Technic's Avatar
Trader Rating: 15 (100%+)
Is timing boost a linear number? For instance, is you go from 20 to 25, is it the same amount of timing being added as going from 40 to 45? Or is it exponential?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-09-2010, 01:47 PM   #16393
bkspeedo's Avatar
Anyone from Pavement Nats want to post TC Expert settings?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-09-2010, 02:54 PM   #16394
tried the 208
but ive got to much drag brake its turned off car slows to fast off power
boost max
rpm start 8500
rpm end 22000
turbo 15
delay 0.11
ramp 2
brakes 60
any ideas?
dean-oz is offline   Reply With Quote
Old 08-09-2010, 02:56 PM   #16395
20 SMOKE's Avatar
Originally Posted by dean-oz View Post
tried the 208
boost max
rpm start 8500
rpm end 22000
turbo 15
delay 0.11
ramp 2
brakes 60
any ideas?
try a little push
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
