Old 08-08-2010, 11:45 PM   #16366
ok just upgraded to 208 and my brakes are terrible, there is a 0.5-1sec delay after i hit the brakes 100% to when the brakes actually start working. i used to run my brakes on 65% and now even at 100% they are terrible.
If i am at full throttle and turbo is active then i go full brake the brakes don't apply immediately, there's nothing for a few feet, a little for another few feet, then they apply as you would expect. If i'm running slower not at 100% throttle the brakes seem to be a little better.
my 208 setup is the same as my 203 setup, the power is the same but the brakes are horrible.
boost 40
rpm start 9xxx
rpm end 30xxx
turbo 15
delay 0.3
ramp 1
LRP X12 10.5t
Spektrum DX3r
I've redone the initial setting with everything on 100% etc.
How do i fix it? I have a big race in 3 weeks.
Chris...
gameover is offline   Reply With Quote
Old 08-09-2010, 06:35 AM   #16367
Good luck chris , i have the same problems for 3 weeks and no answers from tekin
sidecarphil1 is offline   Reply With Quote
Old 08-09-2010, 06:40 AM   #16368
cannon's Avatar
Trader Rating: 35 (100%+)
boost 40
rpm start 9xxx
rpm end 30xxx
turbo 15
delay 0.3
ramp 1
LRP X12 10.5t
Spektrum DX3r
Chris...
Interesting thing is when I see racers with problems with a few brands of ESC's they are always using Spektrum ... seemd to be a common denominator ....pure rubbish
BTW .. have you tried different frame rates as a test?
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-09-2010, 06:41 AM   #16369
Skiddins's Avatar
boost 40
rpm start 9xxx
rpm end 30xxx
turbo 15
delay 0.3
ramp 1
LRP X12 10.5t
Spektrum DX3r
Chris...
Go for the old 'weak reverse' trick
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-09-2010, 07:27 AM   #16370
Never had problems with my DX3s before update v208 so how is it a problem with spektrum
Old 08-09-2010, 08:06 AM   #16371
macdude's Avatar
boost 40
rpm start 9xxx
rpm end 30xxx
turbo 15
delay 0.3
ramp 1
LRP X12 10.5t
Spektrum DX3r
Chris...
I would check your set up on the hot wire. It sounds to me like push is active. I have so much trouble with the Hotwire interface, either not taking or just updating incorrectly. I almost always do everything twice just to ensure that I didn't screw anything up. The other though is to run drag break and see if this helps. No need to run a lot, but just a little to see if it feels a little better.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-09-2010, 08:11 AM   #16372
Lost Aggresiva's Avatar
Same here. Can't get mine to accept full throttle when I reset the speedo. So I've had to bump the throttle on the radio up to 110% and that seems to work. At least it gets me full throttle now.
Lost Aggresiva is offline   Reply With Quote
Old 08-09-2010, 08:20 AM   #16373
I always did that
calibrate at 90% then wind it up to 105%
brakes used to be calibrated at 100% then wound down to 60 to 65% depending on tyres and grip level
Now my brakes were calibrated at 90 and wound up to 110% and still nothing , they are not locking up as i had this on 203 they just dont work for 0.5 to 1 second
we only have 2 braking zones on out track , 1 at the end of the straight (70mtr) witch is scary with no brakes and 90kph and one slow chacane
come on Tekin peeps help us out , i had no problems with 203 and now i cannot drive the car as hard as i like too because of this .
I am seriously thinking of moving to another speedo manufacturer now because of this !!!!!
Old 08-09-2010, 08:27 AM   #16374
macdude's Avatar
I always did that
So using the HotWire what are your brakes set at. If I remember correctly the default break amount changes when you update the firmware.
Old 08-09-2010, 08:31 AM   #16375
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I have all speedos setup at 100% brakes, and use ATL adjustment with the 4PK to adjust brakes on the fly.
The difference in braking power in 1s 12th scale is about 15% increase from 203 to 208 for me.
What has really improved is the low rpm braking, as I can idle up to a grid position and stop on a dime.
Well done Tekin
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-09-2010, 08:40 AM   #16376
brakes on the Tekin are 100%
Old 08-09-2010, 09:57 AM   #16377
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by TeamTekin View Post
Actually it will Push, and then Drag Brake if you set both. When you reduce throttle quickly we reduce throttle a little slower if Push is on. When we do finally reach nuetral we will activate the drag brake.
Odd as it sounds the 2 can work together nicely. The x12 is a good example of a motor with a lot of cog torque that does not free spin and needs some push at times to smooth the slow down. Then some still like additional drag brake so they rarely have to use the brakes.
Tekin motors spin freely so it is unusual to need any Push. Tekin motors spin so freely it is typical to have at least a little drag brake.
This is the post I was talking about
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-09-2010, 09:59 AM   #16378
MikeXray's Avatar
For those with brake problems, have you tried re-flashing 208. I haven't seen anyone get less brakes with 208 around here??
Old 08-09-2010, 10:12 AM   #16379
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
same here,also with a reflash is trying a reset holding both buttons,that fixed a calibration problem
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-09-2010, 10:17 AM   #16380
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Hi larry F
Can you PM me your Tekin 208 set up for 17.5 ..right now I'm running 203 in my TC photon.....our track is 90X100
OVA is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
