Tekin RS ESC sensored > Tekin RS ESC sensored
Old 08-05-2010, 12:02 PM
  #16261
Trader Rating: 66 (100%+)
Originally Posted by BILKO1 View Post
Thanks for your reply,
I'm worried about the temp going up after the race when the esc is turned off is this normal?
Alot of people at our local indoor carpet track wire the motor fan to the batt +&- so that the fan runs when the speedo is turned off. That way we leave it plugged up after the race while we marshall then its cool when we get back to the pit. Just an idea if your worried about the temp after the race.
Gwoodrc is offline
Old 08-05-2010, 01:16 PM
  #16262
JCarr's Avatar
I have done this and it works very well.
JCarr is offline
Old 08-05-2010, 01:37 PM
  #16263
L@gger's Avatar
Originally Posted by macdude View Post
Just out of curiosity how do we get rid of "bling" on HW interface. I ...well how do I say it nicely...... dislike the interface. I thought that this version was not suppose to be so ugly. I figured that we would be at a point where branding could be kept to a splash screen. I really think the whole interface detracts from what it is capable of doing. And that is really sad. I hate showing someone new how to set up the controller because the UI is grotesque and makes me feel like I am back in the mid 90's when everyone was skinning there media players. And after all this time you still have not made the sliders functional. ie you can't click and hold and move them up and down.
Im too late but +1. I also dont like this look and I think changing curves of timing by clicking on it and so would be better.
L@gger is offline
Old 08-05-2010, 02:20 PM
  #16264
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Corally_27 View Post
can you please tell me how to select from c1 and c2 without using the hot wire
thank you
press mode button until TP led is lit,press INCR until 6 led's (C1) 7 led's (C2) wait for the beep and your done
20 SMOKE is offline
Old 08-05-2010, 02:27 PM
  #16265
Haven't run any fans since the weight reduction to 1350 grams came in.
BILKO1 is offline
Old 08-05-2010, 08:53 PM
  #16266
Default No brakes with rs pro and 3pk v208
Just upgraded to v208 before the past weekends race and had zero brakes. Tried to recalabrate and speedo chimes that it detects neutral and full throttle but just keeps beeping when I pull full brakes?? I tried playing with the settings on the 3pk but same thing over and over. Any help would be awesome.
HIGHTYMES is offline
Old 08-05-2010, 09:36 PM
  #16267
Trader Rating: 16 (100%+)
Downloaded 208, installed it on the RS Pro .. No brakes at all.
Redownloaded software, reprogrammed ESC, still no brakes.
Checked all the connections etc ... Nothing
Flashed the RS - no problem. I'll try it this weekend - I'm keeping fingers crossed. Looks like the Pro is going back to its maker.....
Spdjunky is offline
Old 08-05-2010, 10:03 PM
  #16268
runinonempty's Avatar
Trader Rating: 19 (100%+)
Originally Posted by 20 SMOKE View Post
How long of a straight
about 203ft
here is a link to the track
http://www.nearmap.com/?ll=-33.75811...h&nmd=20100630
Cheers
runinonempty is offline
Old 08-05-2010, 11:18 PM
  #16269
The MurfDogg's Avatar
Problem - Since downloading the new 208 software, 4 of my buddies have tried 208, and did not find setups they liked on it yet, and when they try to go back to 203, the hotwire will not allow them to do so. Then they find someone who has hotwire with 203 only, (have not used 208) and it will allow them to switch it on that hotwire. I have not used 208 yet, but if it will not allow me to use 203, which has been great for me, I do not want to start using it!
Any help would be great!
Also, how come you cannot download 4.0 anymore without 203. The same buddies cannot use their hotwires now.
Im confused by all of this. Glad I still only have 203...
The MurfDogg is offline
Old 08-06-2010, 02:24 AM
  #16270
bluephi1914's Avatar
Trader Rating: 34 (100%+)
I am loving the New Tekin Software upgrade.... KO Smooth and Tekin Top speed !!
bluephi1914 is offline
Old 08-06-2010, 02:37 AM
  #16271
VoneSkip's Avatar
Trader Rating: 27 (100%+)
+1
The Ultimate combination
VoneSkip is offline
Old 08-06-2010, 04:12 AM
  #16272
L@gger's Avatar
Im browsing all days and still didnt found answers for my questions.
How do i get to c1-c2 timing profiles onboard?? I tried 6-7 times pressing mode button then 5 sec wait and when I plugged it to PC I still saw the same profile active what I used before.
How it is with END RPM at dual mode? 50 % (15 deg) is added to sensorless period and after it reach END RPM what happens to timing? I saw Randy had END RPM 20 000 with motor what can go higher.
How it is with END RPM in sensored mode after timing boost period. If I reach END RPM of timing boost without full throttle?
I hope its understandable and I will get it finally answered. Thanks.
L@gger is offline
Old 08-06-2010, 04:33 AM
  #16273
20 SMOKE's Avatar
i answered it yesterday
20 SMOKE is offline
Old 08-06-2010, 04:39 AM
  #16274
20 SMOKE's Avatar
they cant use a 203 pc to make changes to a 208 esc,make sure they are using the same settings they used with 203.did they all use the same pc to upgrade to 208
20 SMOKE is offline
Old 08-06-2010, 04:46 AM
  #16275
20 SMOKE's Avatar
Originally Posted by runinonempty View Post
about 203ft
Cheers
50
10
start 3k
end 12
fdr 5.0
delay .3 (what evere feels good for you)
ramp1
0 motor,add to the first mark if you need more out of the corner and take a couple from boost,just watch the temps
20 SMOKE is offline
