Old 08-04-2010, 09:14 PM   #16246
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Originally Posted by Friulimotosport View Post
Thanks for the input. I changed out rec. to one I had in other car and still the car when't WOT.
Was it a micro receiver you were using, is the 2nd one a micro as well ?
I tried 2 before I changed the whole system.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 08-04-2010, 10:19 PM   #16247
runinonempty's Avatar
Trader Rating: 19 (100%+)
Hi guys can I please get a good set up idea for 17.5 touring car using redline motor on large free flowing asphalt track using rubber tyres track has a very long back straight
Using 208
Also what would you recommend as a good fdr
Thanks in advance
Xray T4, Tamiya M05 S-Spec
with lots of dust
runinonempty is offline   Reply With Quote
Old 08-04-2010, 11:29 PM   #16248
Originally Posted by Randy_Pike View Post
While the brakes were an "issue" for some it certainly wasn't an issue for all. This is one reason why it's hard to work on something that appears to be limited to a select few people.
Once we gathered enough of the proper information we went to work on improving the brakes, 208 is out problem solved.
We could have released a new esc that had the improved braking software, have you spend another few hundred dollars and not give you the update/improvements for ..........oh yeah FREE!
I have no braeks with 208
they were fantastic with 203 now nothing
and the power delivery is sooooo smooth and linier , i want my BANG out of the corners back
Any ideas Randy ???
sidecarphil1 is offline   Reply With Quote
Old 08-05-2010, 04:07 AM   #16249
Regards
Gary
Second was also a micro rec. They both worked fine in 1/12 and WGT with tekins in them. Looks like I'll have to get a new radio/rec.
Friulimotosport is offline   Reply With Quote
Old 08-05-2010, 05:06 AM   #16250
tomracing's Avatar
I guess you used to run a high throttle profile in 203.
since these are used by the timing profiles you now do it on your transmitter.
have you tried the throttle punch setting or positive throttle servo curves in your transmitter?
that should return your punch like you had with the throttle profiles.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 08-05-2010, 07:34 AM   #16251
Originally Posted by 20 SMOKE View Post
this is 12th
No 1/10th touring car running 13.5t.
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 08-05-2010, 08:51 AM   #16252
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Using 208
Thanks in advance
How long of a straight
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-05-2010, 08:52 AM   #16253
20 SMOKE's Avatar
150-160 is good for the motor,how many led's are flashing
Jamie W
Old 08-05-2010, 09:04 AM   #16254
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Can't help you with the brakes.
But to get some of your zip back out of the esc, try dropping your end RPM down 1k, or 2k... (something like 4k-11k for 17.5), and maybe bump your throttle profile from 3 to 4.. something like that. You can compensate for the smoother and laggier acceleration with slightly more agressive timing settings... watch your heat.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-05-2010, 09:30 AM   #16255
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Sidecar: Make sure you're making the same adjustments to 208 as you had seutp in 203. There should be no difference between them assuming the settings are the same.
The throttle profile setting is still present in 208 but it MUST be adjusted with the Hotwire, NOT the onboard buttons.
Post your setup so we/I can take a look at it.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-05-2010, 09:44 AM   #16256
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks for your reply,
I'm worried about the temp going up after the race when the esc is turned off is this normal?
Yes it's normal. When you stop the car, you stop the airflow moving over the motor.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-05-2010, 10:31 AM   #16257
Have you tried a receiver capacitor? Something like this: http://www.amainhobbies.com/product_...tage-Protector
-Mike
Old 08-05-2010, 11:04 AM   #16258
Default c1 and c2 profiles
can you please tell me how to select from c1 and c2 without using the hot wire
thank you
Corally_27 is offline   Reply With Quote
Old 08-05-2010, 11:17 AM   #16259
Thanks Mike. I'll give it a try before buying new radio.
Old 08-05-2010, 12:06 PM   #16260
Ok set up from 203 swapped to 208
motor timing 5
Throttle profile 5
Neutral width 10
Timing 45
Turbo 8
Start 6,xxx
End 15,xxx
Turbo delay 0.4 to 0.0 dependant of feel and motor temp
motor temp after 7 mins is 65 to 70 dergees C
i used to have brakes of 60% on my transmitter now they are at 110% and 100% on the RS
I calabrate at 90% then up to 110% but still i need to brake 2 meters further from the corner than i did with 203 !!
could it help if i update the speedo again ???
cheeRS Phil
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
