Old 08-01-2010, 09:15 PM   #16186
Micro-E's Avatar
Originally Posted by big al View Post
ok guys, I'm having a strange problem with my RS. It will periodically completely shut down. Receiver and servo are down as well and it will just roll then power back up. I'm running a 17.5 in spec mode (this also happened in 203). A friend of mine suggested that I try a different sensor wire, but I can't see how that would completely power down my electronics. Any ideas are appreciated. Thanks--Al
Big Al,
I had the same intermittent issue you described a while back. Drove me nuts, I tried everything... Someone from Tekin Tech Support told me it was my servo. I put a new servo in and have not had a problem since.
May not be your problem, but if you have access to a spare servo, it might be worth a shot.
- Erik
Micro-E is offline   Reply With Quote
Old 08-01-2010, 09:26 PM   #16187
big al's Avatar
I've been using this servo for about a year now, suppose it's possible. Just to clarify, It's not just the receiver and servo that stop working, the esc literally loses power. All leds are off. Went through all the connections just to make sure. Also, about a couple of months ago I accidentally spilled quite a bit of paragon fxII onto my chassis and electronics. Would that cause an electrical issue? I've cleaned out the receiver case and esc case as best as I could(took them apart), but I suppose some could still remain.
big al is offline   Reply With Quote
Old 08-01-2010, 10:35 PM   #16188
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
bigal, are you running ANY heat shrink on your solder posts on your RS?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-02-2010, 02:46 PM   #16189
Trader Rating: 38 (100%+)
If anyone is interested in a great deal on a netbook to use their hotwire on check this out:
http://www.rctech.net/forum/r-c-item...ing-track.html
or8ital is offline   Reply With Quote
Old 08-02-2010, 07:08 PM   #16190
big al's Avatar
Negative. I took special care to make sure nothing is close to or on the posts. As far as I can remember, this problem didn't arise until my paragon fiasco. Feel free to chime in people!!
Old 08-02-2010, 10:43 PM   #16191
mikeygar's Avatar
Trader Rating: 14 (100%+)
What's especially strange about the whole thing is that I can't replicate it. I'll take it to the next level and check all connections with an ohmmeter. Maybe I've got a broken wire somewhere. One thing that I did notice is that the problem becomes more frequent as the day gets warmer. All my connections seem sound and the switch seems to be doing it's job. Internal issue?
if issue is related to temperature, check your wires and batt connector if they are heating up. If your wires have a bad connection or have deteriorated, they will heat up to the point that they will not be able to supply the amperage they were originally rated to. Add the ambient temp to your already hot wires, heat = resistance and if you have too much heat, it may be the cause of the current dump you are experiencing.
mikeygar is offline   Reply With Quote
Old 08-03-2010, 12:26 AM   #16192
niznai's Avatar
My guess is that you have some sort of internal problem. Semiconductors capacitors and resistors usually cause these impossible to replicate problems. Over time these become permanent.
If everything outside checks OK, I think the next step is to look inside the speedy. Unfortunate.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-03-2010, 02:03 AM   #16193
12scale's Avatar
big al
I had a problem awhile ago where my car just stopped and then did it intermittently from then on, finally found the connection (Corally plug) to the battery had been arcing and the slightest movement would turn the car back on. long story short changed the connection and problem solved.
Cheers
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 08-03-2010, 09:15 AM   #16194
Default Tekin RS Pro
Can anyone come back to where is the best and cheapest place to buy one in the US ?
tfracing is offline   Reply With Quote
Old 08-03-2010, 10:11 AM   #16195
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
highvelocity,209
stormer,209
ampdraw,208
amain,219
just a few
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-03-2010, 10:22 AM   #16196
thanks
Old 08-03-2010, 10:30 AM   #16197
dizzy1's Avatar
Trader Rating: 24 (100%+)
bigal- had the same thing when 203 first came out on 3 of my cars. All same servo. Few locals all changed servos and stopped their issues, I kept my servos but had to put a 3300uf or higher cap on the receiver. Never a problem since. Seems the cap smooths out the power so no dips causing the esc to sense this and shut off which kills the power to the receiver. Switch to a spare servo(different brand, seems Ko servos had the most issues) and see if it goes away or try a cap if you have one.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 08-03-2010, 11:41 AM   #16198
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
ygpm
OVA is offline   Reply With Quote
Old 08-03-2010, 12:17 PM   #16199
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you bathed your RS in paragon that's not going to help. However you should have been able to blow it out with some air after uncasing it and as long as you got it all out it should be ok.
Check your servo like the others are stating. Also make sure you've got solid battery connections.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-03-2010, 12:31 PM   #16200
JayL's Avatar
What brand/model servo, that works fine with every other esc, are we talking about giving problems?
JayL is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
