Old 08-01-2010, 02:28 PM   #16171
darrenoakley's Avatar
Not too long till the indoor season starts here in the uk and running 12th this winter indoors.
Can anyone help out with a rough Tekin rs set up. I have my rollout and gearing sorted just wanted a pointer on the 13.5 Tekin rs 1s 208 please as all the ones on Tekins website seem to be 203.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 08-01-2010, 02:30 PM   #16172
Still Bill's Avatar
Assuming that you have Timing Boost in the low to mid forties, I see no issues with those settings.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-01-2010, 04:50 PM   #16173
team minkya trf's Avatar
i sent my tekin rs to tekin about 4 weeks ago and i havent heard from them yet how long does it usally take
speedpassion|trf416we|protoform|lrp|sanwa|m03|f109|hitec|xrayt2|tekin rs
team minkya trf is offline   Reply With Quote
Old 08-01-2010, 05:04 PM   #16174
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
email randy with yor Ra#
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-01-2010, 05:07 PM   #16175
20 SMOKE's Avatar
start with 40 timing boost add if you can handle more(traction)
start 3854
end 7954
0 motor
Jamie W
Old 08-01-2010, 05:13 PM   #16176
start 3854
end 7954
0 motor
Great cheers for the help mate.
Turbo off i take it ?
Xray x11
Xray T3 011
Old 08-01-2010, 05:23 PM   #16177
who is randy
Old 08-01-2010, 05:24 PM   #16178
wingracer's Avatar
Trader Rating: 24 (100%+)
Small addition to what smoke said. If you find you need more timing and are running a Tekin motor, try adding a bit of motor timing first. I find the Tekins like a little bit. If you still find you need more speed and temps aren't bad, go up a tooth or two on the pinion before dumping tons of timing on it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 08-01-2010, 05:27 PM   #16179
wingracer's Avatar
who is randy
Randy Pike. Read through this thread and his posts are all over the place. Go back to page 1070 for his most recent one.
Team Shepherd USA
Old 08-01-2010, 05:28 PM   #16180
thanks for your help ill give him a pm now
Old 08-01-2010, 05:58 PM   #16181
20 SMOKE's Avatar
YES
Jamie W
Old 08-01-2010, 07:45 PM   #16182
big al's Avatar
ok guys, I'm having a strange problem with my RS. It will periodically completely shut down. Receiver and servo are down as well and it will just roll then power back up. I'm running a 17.5 in spec mode (this also happened in 203). A friend of mine suggested that I try a different sensor wire, but I can't see how that would completely power down my electronics. Any ideas are appreciated. Thanks--Al
big al is offline   Reply With Quote
Old 08-01-2010, 07:48 PM   #16183
20 SMOKE's Avatar
make sure all solder connections are good and check the switch and leeds in the rs are connected to the board
Jamie W
Old 08-01-2010, 08:00 PM   #16184
Also try a receiver cap or a different servo, sometimes the servo will have a high rate of amperage drop the voltage and the receiver will have to reboot.
slsspark is offline   Reply With Quote
Old 08-01-2010, 08:01 PM   #16185
big al's Avatar
What's especially strange about the whole thing is that I can't replicate it. I'll take it to the next level and check all connections with an ohmmeter. Maybe I've got a broken wire somewhere. One thing that I did notice is that the problem becomes more frequent as the day gets warmer. All my connections seem sound and the switch seems to be doing it's job. Internal issue?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
