Old 08-01-2010, 10:59 AM   #16156
I drove with v208 today for the 1st time
PLEASE GIVE ME v203 back !!!!
I used the same settings as v203 and same motor but i have no brakes any more !!!!
90% set up then 100 or 110% as running and still rubbish
I had my brakes on 60 to 65% on v203 !!!
other than that i cannot feel any differance
sidecarphil1 is offline   Reply With Quote
Old 08-01-2010, 11:02 AM   #16157
wingracer's Avatar
Trader Rating: 24 (100%+)
Something isn't right then. Everyone else likes the brakes better.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-01-2010, 11:33 AM   #16158
yeah i know
wierd , going to look tomorrow see if it is something i have done or the RS is pooped !!!
Old 08-01-2010, 12:14 PM   #16159
hairy's Avatar
I need a litle help(my friends would say I need alot), My Tekin w\v208 and when I had v203 after about a minute or so into a run the power drops off like I have no turbo at all. If I let the car sit for a minute the power comes back. My motor temp on a x12 13.5 is 135f+/-, and my speedo temp is 115f+\-. when I put it back on the computer the settings have NOT changed at all.
Antone have a solution to this problem?
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 08-01-2010, 12:28 PM   #16160
locked's Avatar
Sounds like it could be the floating full throttle endpoint problem that users of certain radios have had an issue with in the past, but setting your endpoint on the radio to 90% then calibrating the ESC, then putting the endpoint back to 100% should fix that issue. The ESC might not be seeing a full throttle input from the receiver after a few minutes, but if you make it so full throttle is a couple mm before the trigger is fully pulled, it should hopefully fix it.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-01-2010, 12:59 PM   #16161
hairy's Avatar
I tried the epa adjustment and no change. I am running a futaba 3pk.
MERLIN RACING
Old 08-01-2010, 01:08 PM   #16162
Still Bill's Avatar
Post all settings...And what kind of car are you using?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-01-2010, 01:46 PM   #16163
hairy's Avatar
X ray t2r
Settings as follows
Brushless fwd only w\ brake
volt cuttoff 25
drive mode -sensored only
motor direction-normal
throttle profile-3
currnet limiter-off
drag brake-25
brake strength-100
nuetral width-10
push-off
BOOST start 4608 end 12000
Turbo 16
ramp 1
delay-.5
MERLIN RACING
Old 08-01-2010, 01:58 PM   #16164
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
how much timing boost
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-01-2010, 02:02 PM   #16165
Senna Racing's Avatar
maybe a stuip ? but did you try them at 65% like with 203
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 08-01-2010, 02:03 PM   #16166
and fdr
Old 08-01-2010, 02:08 PM   #16167
locked's Avatar
have you tried different batteries? or tried turning the voltage cuttoff off or to 1s. might be spiking below 3 after a couple minutes
Dave Locke
Old 08-01-2010, 02:11 PM   #16168
hairy's Avatar
oops kinda important ain't it : timing boost 32
timing advance minimum
FDR 6.92
MERLIN RACING
Old 08-01-2010, 02:15 PM   #16169
hairy's Avatar
different batteries -yes, volt cutoff to off, no Not sure about using 1s on a 2s battery.
MERLIN RACING
Old 08-01-2010, 02:18 PM   #16170
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by niznai View Post
How long is the turbo function active for?
I think I this has been answered, but can't find or remember the answer.
Your choice of words makes it difficult to answer, but I think you are looking for this.
A turbo setting of 20 will give you the following reaction:
1.0 Ramp rate = 20 degrees in 1 second applied
2.0 Ramp rate = 20 degrees in .5 seconds applied
3.0 Ramp rate = 20 degrees in .30 seconds applied
That's how long it will take to reach full turbo timing. That amount of timing will stay steady till you drop below 100% throttle.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
