Old 07-27-2010, 02:11 PM   #15976
TrevCoult's Avatar
Originally Posted by yellowshark View Post
Hi, I joined the Tekin family when 203 was out so I have not had to upgrade/downgrade before. Is the following correct
I download and install Hotwire 5
Attach the ESC and reflash with 208 from Hotwire 5
Now...
If I need to go back to 203 do I reflash from Hotwire 5 and continue to run 203 with Hotwire 5? I am assuming Hotwire 4 gets clobbered when 5 is installed and I do not have the luxury of 2 laptops to run the software version independently
Desperate to start install but I would like to know what I am doing
When you first connect your HotWire/RS after upgrading the computer to HotWire 5 it will tell you that you have to upgrade to use it. HotWire 5 is not compatible with any firmware earlier than 208. If you ever want to downgrade to 203 or earlier you will have to uninstall HotWire 5 and install HotWire 4.
It's easy really. Upgrade the software to HotWire 5, plug in your RS, upgrade to 208 when it tells you to, use it!
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 07-27-2010, 03:32 PM   #15977
barts71m's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Cpt.America View Post
Did you reset your EPAs and recalibrate after installing 208?
Yep I tend to do it after any major change like that to the system. JUst for safe keeping.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 07-27-2010, 05:50 PM   #15978
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Now...
I suggest not doing this. If you happen to accidentally use a Hotwire 4/203 to adjust a 208 equipped esc you can create a problem.
There's no reason to run 203 now that 208 is out.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-27-2010, 05:55 PM   #15979
Trader Rating: 21 (100%+)
Originally Posted by M-Technic View Post
Thats a good idea. But for some reason the Tekin plugs fit extremely tight in my receiver so I think the tape would make it worse.
I run a short servo adaptor between the Tekin and reciever.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-27-2010, 06:01 PM   #15980
Trader Rating: 55 (100%+)
You put far too much faith in software developers. I am one, so I know .
Mitch
WatchOut is offline   Reply With Quote
Old 07-27-2010, 06:27 PM   #15981
hairy's Avatar
o.k I know what I am about ask has probably been answered already, sorry,
I just updated to v208 and so far it seems great, havn't raced yet just playin' in the street, I also race in a class that requires an older version with only 10% boost, can I load both version on the hot wire?
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 07-27-2010, 07:13 PM   #15982
reenmachine's Avatar
Trader Rating: 26 (100%+)
Depending on what the definition of "10%" is in that class, one of the new onboard "canned" profiles will probably be the ticket, perhaps profile 2. What older version are they allowing? Do they give an actual timing value that's acceptable, in degrees?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-27-2010, 07:19 PM   #15983
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
See Randy's post above...
What older version do you have to run?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 07-27-2010, 07:21 PM   #15984
hairy's Avatar
we run v200
I guess I should tell you I'm an old fart and some of this computer lingo is confusing me. So the hot wire carries the program ? can I add v200 to the speedo as an option?
MERLIN RACING
Old 07-27-2010, 07:30 PM   #15985
we run v200
I guess I should tell you I'm an old fart and some of this computer lingo is confusing me. what is the reference to the hot wire in the post you referenced?
Randy was answering someone who wanted to run the new and old software. He says you can cause some issues if you program a V208 ESC with Hotwire 4 (old version)...so just use that as a precaution.
Old 07-27-2010, 07:32 PM   #15986
hairy's Avatar
what is a hot wire4?
MERLIN RACING
Old 07-27-2010, 07:33 PM   #15987
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
203
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-27-2010, 07:35 PM   #15988
hairy's Avatar
I'm sorry I'm really lost now...I have to buy a new hot wire to run v208?
MERLIN RACING
Old 07-27-2010, 07:40 PM   #15989
No...that is just the version for the software Hotwire interface.
Old 07-27-2010, 07:42 PM   #15990
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
Brakes addressed, very good to see. dynamic curves on dualmode. thank you for listening to us. finally a reason to move on from 189
R
UltegraSTI is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
