Old 07-27-2010, 07:02 AM   #15961
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by hardmankam View Post
The least 'wear and tear' method is to use 2 extension cords.
Rx <--ext cord1 --> <-- ext cord2 --> ESC
of course, you will plug/pull the middle joint. if the plug gets damage, you will just have to replace one of the cords. no harm to Rx or ESC.
In the world of clean electronics installations, I'd love to see someone using two receiver extensions
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-27-2010, 08:32 AM   #15962
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Hey,
i see these little 7" netbooks on ebay and they come with windows CE. Can i use hotwire on this OS?
thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 07-27-2010, 09:08 AM   #15963
barts71m's Avatar
Trader Rating: 34 (100%+)
Tried 208 tonight but didnt seem to wanna take to my ESC.
Updated software as per normal, car seemed to be running like it was sensorless.
Uninstalled V208 and changed sensor lead, switched back to V203 car came to life. Reinstalled V208 it all seemed to be fine. Went out for my heat and again no bang, just running slow. Again reinstalled V203 and car was all good again.
Running Tekin RS with SP v3 21.5
Was running profile C1, sensored mode, 2s
40 Timing
10 Turbo
Std rev range 5000 - 20000
5 Neutral width
.5 delay
2.0 Ramp.
Any suggestions?
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 07-27-2010, 09:34 AM   #15964
M-Technic's Avatar
40 Timing
10 Turbo
5 Neutral width
.5 delay
2.0 Ramp.
Any suggestions?
Those settings are extremely conservative for a 21.5. However, it seems like you have other problems as the speed control seems to be switching to dual mode. I have seen the sensor board go out on a Tekin. It might need to go back for service. I would try using a different motor and a few different sensor wires first.
Old 07-27-2010, 09:43 AM   #15965
barts71m's Avatar
Cheers man..
seems strange that it works with no issues with older software though. Might be an expensive trip, have another one to go back aswell that broke a cap and shorted itself.
As for the settings just tame to start off with, but didnt get to give it a test, runs fairly stout with the V203. Dont lack anything for straight line or low speed. Motor temp is barely there aswell. Like 44-49 deg Cel.
Old 07-27-2010, 10:28 AM   #15966
M-Technic's Avatar
Yeah, it sucks to have to send it in to service. However, by trying a different motor and more sensor wires you will be able to remove all variables and know if it's a problem with the speed control or not.
Old 07-27-2010, 11:17 AM   #15967
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
40 Timing
10 Turbo
5 Neutral width
.5 delay
2.0 Ramp.
Any suggestions?
Did you reset your EPAs and recalibrate after installing 208?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-27-2010, 11:38 AM   #15968
niznai's Avatar
Originally Posted by teeforb View Post
Hey,
thx
No. Do a search around the dedicated forums and you'll see.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-27-2010, 11:47 AM   #15969
Trader Rating: 21 (100%+)
Hey,
thx
Do a Google search for netbooks with XP.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-27-2010, 12:31 PM   #15970
lbckevin's Avatar
Trader Rating: 91 (99%+)
I got my Asus EEPC netbook at Sams Club for $175
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-27-2010, 12:35 PM   #15971
darrenoakley's Avatar
Thats what I use for the hotwire and works great.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 07-27-2010, 12:41 PM   #15972
Originally Posted by M-Technic View Post
Life would be great if there was an easier way to remove sensor wires and the Tekin's receiver wires to make changes.
All i do is wrap a tab of battery tape down one side of the plug around the bottom and back up the other side. Then poke 3 small holes in the tape at the bottom for the receiver pins. You then pull on the tape not the wires.
Probably all ready been mentioned but worth a shot
Xray x11
Xray T3 011
Old 07-27-2010, 01:15 PM   #15973
Hi, I joined the Tekin family when 203 was out so I have not had to upgrade/downgrade before. Is the following correct
I download and install Hotwire 5
Attach the ESC and reflash with 208 from Hotwire 5
Now...
If I need to go back to 203 do I reflash from Hotwire 5 and continue to run 203 with Hotwire 5? I am assuming Hotwire 4 gets clobbered when 5 is installed and I do not have the luxury of 2 laptops to run the software version independently
Desperate to start install but I would like to know what I am doing
yellowshark is offline   Reply With Quote
Old 07-27-2010, 01:35 PM   #15974
M-Technic's Avatar
Thats a good idea. But for some reason the Tekin plugs fit extremely tight in my receiver so I think the tape would make it worse.
Old 07-27-2010, 01:54 PM   #15975
buffalobill989's Avatar
Trader Rating: 50 (100%+)
used to do that on rec crystals. worked like a charm
buffalobill989 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
