Old 07-26-2010, 06:43 AM   #15916
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Lost Aggresiva View Post
I had something like that. After updating to 208, I tried resetting the speedy to my radio. All the lights were blinking like normal, but would not accept the signal for full throttle. Never had this problem with any previous version. This was with a Spektrum DX3R.
Bill
Sounds like your normal and reverse on throttle are wrong. Try reversing the setting from what it is on now.
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-26-2010, 06:47 AM   #15917
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by noline View Post
Hello there,
The motor is stock right out of the box I didn't even run it yet.where should I set it at ? And what gearing for a 50 x 25 carpet track with a 76 spur and a 1.72" inch tire
Also what would be your tekin settings for this motor?
ft or meters
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-26-2010, 06:49 AM   #15918
TrevCoult's Avatar
Originally Posted by cheehtae View Post
Problem:
After installing the new software and recalibrating all the parameters ( including TX) after doing all the stuff that is need ed to be done then when I would power up my speedo there would be blinking lights but no BEEPING sound and speedo won't store the settings it would do nothing.
HELP please.
That often happens when either the RS isn't receiving a signal from the receiver, or it can't find neutral. Check your wiring and neutral width setting on the RS.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 07-26-2010, 06:50 AM   #15919
stiltskin's Avatar
Trader Rating: 102 (100%+)
Problem:
HELP please.
If all lights are blinking, try to rebind your radio and receiver. Had this issue once before. Don't know why it did it, but the problem went away after a rebind.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 07-26-2010, 07:03 AM   #15920
reenmachine's Avatar
Trader Rating: 26 (100%+)
Also keep in mind that it won't beep if not connected to a motor, in case you're programming your ESC on the bench before you install it.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-26-2010, 07:04 AM   #15921
noline's Avatar
Hello there,
ft or meters you mean track size? If so it would be 50' foot x 25' foot
Originally Posted by 20 SMOKE View Post
ft or meters
noline is offline   Reply With Quote
Old 07-26-2010, 07:05 AM   #15922
M-Technic's Avatar
Trader Rating: 15 (100%+)
I can't wait to have two custom profiles saved on the speedo. It will be great for testing purposes. Run some laps, pull it in, quickly switch profiles, get back on the track.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-26-2010, 07:14 AM   #15923
20 SMOKE's Avatar
did it yesterday,had a turbo and non turbo set up
Jamie W
Old 07-26-2010, 07:20 AM   #15924
20 SMOKE's Avatar
Hello there,
ok,the motor has 40+ timing stock go with conservative setup to start
15 timing boost
start 5k
end 6500
25-28 tooth pinion,i don't go by tire size as i run outdoor and full size tire so this is a guess for a short straight.if you can go with the - side for timing on the motor bring timing boost up with a range 3-4k start 7-8 end with a total of 45-55 timing boost with motor
Jamie W
Old 07-26-2010, 08:11 AM   #15925
noline's Avatar
Ok cool,
thank for the tip, Compaired to a Duo 1 are these motors just asquick as the Duo 1? Or is theduo still the fastest?
15 timing boost
start 5k
end 6500
Old 07-26-2010, 08:30 AM   #15926
20 SMOKE's Avatar
i think it hard to compare with the boosted/turbo esc,i have not run either of them.my 12th has a tekin 13.5 geared at 35/76 with 53 total timing,a guy at the track was geared 44(i think)88 with 65 total with a duo 2 and we were equal,so in this case i say my tekin is faster.sorry to ramble
Jamie W
Old 07-26-2010, 08:46 AM   #15927
Hi guys
I heard from a friend that ROAR says that we will have to run TP1-TP5 only (no C1 or C2) in VTA, WGT, and 17.5 1/12th. Do any of you know if that is the case?
BIGBOT is offline   Reply With Quote
Old 07-26-2010, 08:47 AM   #15928
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Martyn666 View Post
Thanks a lot!! It was the sensor wire
The sensor wires are a HUGE weak link with modern brushless motors. I go through a sensor wire about every two months. 99% of the time, they look brand new, they just stop working. Always keep a couple extra on hand.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-26-2010, 09:10 AM   #15929
20 SMOKE's Avatar
Originally Posted by BIGBOT View Post
Hi guys
if it is a stock no boost it will be TP1,2-5 have timing values,so read the rules for the class
Jamie W
Old 07-26-2010, 09:31 AM   #15930
Just downloaded the latest 208 software today. What are the setting for LRP X12 4.5T BL motor. Let say the track straight is about 280ft...
Thanks for those who guide...
ckloo is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
