Old 07-24-2010, 03:05 PM   #15856
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by locked View Post
When I posted that I had not seen the new labels for the settings in 208. I was going by 203
The way I understand it, "Timing Advance" is now a percentage of 30 degrees timing that only gets used in dual mode, like if your sensor wire pops out mid race. It would apply that 30 degrees (if set to 100) spread over the default RPM range around 5K-20K
What I referred to as timing advance (from what it was called in 203) is now called "Boost" and "Turbo Boost" is now just "Turbo"
timing advance has all ways been called timing advance same for timing boost and turbo,nothing has changed names or what is used in sensored or dual mode as for timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-24-2010, 03:14 PM   #15857
locked's Avatar
I'm getting old. Perhaps my memory is failing me. Oh well. Is my understanding of what the settings do correct?
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 07-24-2010, 05:09 PM   #15858
stiltskin's Avatar
Trader Rating: 102 (100%+)
Setup 208 today with my 203 settings. I used to be able to feather the throttle through the sweeper without any significant loss of power. Now when I feather the throttle, the car checks-up on me. I removed drag brake and tried different turbo delays with the same results.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 07-24-2010, 05:19 PM   #15859
wingracer's Avatar
Trader Rating: 24 (100%+)
When you say "feather" are you letting all the way off of the throttle or just backing up to say a half throttle position? If a half throttle type let off, try bumping up the throttle profile. If all the way off, may be time to try some push.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-24-2010, 05:56 PM   #15860
stiltskin's Avatar
Hey Sean. I'm trying to stay on full throttle. Never "off" throttle, just letting up a little to maintain my line. Never had this issue with 203.
Tony Rumple
Old 07-24-2010, 06:54 PM   #15861
syndr0me's Avatar
Trader Rating: 32 (100%+)
I find myself running less drag brake in 208 to achieve the same feel I had with 203.
syndr0me is offline   Reply With Quote
Old 07-24-2010, 07:23 PM   #15862
DaveW's Avatar
I didnt get to run my car much today with 208 (i was there for 6 hours and got 4 packs in). The brakes seem much better though (consistent, not necessarily stronger). I had the same loss of boost as before (after 3 or so laps) if i tried to set my transmitter up with 100%+ T/B EPA. So i went back to the previous setup and it worked fine.
Track temp was above 140 degrees today... i ran that x12 well into the 200 degree mark with no fade, and the RS was at the first LED for temp. Throttle response felt better with a start RPM in the 3k region. 5k felt better on 203, both with the same end RPM and timing settings. Car had plenty of rip! ("Is that mod?" )
Were you runnin the x12 today Tony? If so, you might need to go to the -5 timing insert instead of the -10 for our track.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 07-24-2010, 07:59 PM   #15863
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
presuming we run the same settings as v203..
with the improvements in v208 should we see similar, hotter or cooler motor temps?
curious as i wont be able to hit the track for a few days!
-mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 07-24-2010, 08:08 PM   #15864
wingracer's Avatar
Well it's not a drag brake deal then. I haven't run 208 yet but they say it has a smoother throttle response, which to me means less throttle for a given amount of trigger. So to get that back, you might need to bump up the throttle profile or just adjust your driving.
Which brings me to my question for the Tekin peeps. What if you don't want a smother throttle? I like punchy.
Team Shepherd USA
Old 07-24-2010, 08:09 PM   #15865
stiltskin's Avatar
+1
Tony Rumple
Old 07-24-2010, 09:23 PM   #15866
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Same issue here...anything less than full throttle and the car is a slug. Back off the trigger just enough to disengage the turbo and the car checks up noticeably. This is with 0 drag brake. This can be noticed on the bench as well...with 203 the timing boost kicks in just after LED 4 lights up (5k-18k RPM range), with 208 it is LED 6, almost to full throttle and just before the turbo activates. I tried re-flashing to 203 then back to 208, same results. This is with 17.5 Duo 2, no motor timing, TC rubber on carpet, 7.2 FDR, same settings as 203.
flatspunout is offline   Reply With Quote
Old 07-24-2010, 09:23 PM   #15867
STLNLST's Avatar
Trader Rating: 21 (100%+)
You could adjust your boost settings or possibly drop a pinion. Honestly....I would just run it first and then see if you feel that you need to add more punch. My laptimes were faster and the more linear trigger feel made me much smoother. I still had plenty of rip out of the corners as I pulled hard out of every corner. What class will you be running and what type of motor?
STLNLST is offline   Reply With Quote
Old 07-24-2010, 09:35 PM   #15868
wingracer's Avatar
Nice info there flatspunout. I think I know what's going on here but until I get a chance to try it myself, I don't think I'm qualified to comment. It will be a while before 1/12th season starts up again.
Team Shepherd USA
Old 07-24-2010, 10:03 PM   #15869
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The turbo cannot be "kicked on" until full throttle is reached, period. This is why KO radio users must do the +10 epa trick as that system tend to have end point float.
The RPM range has NEVER had an affect on turbo. If your theory was true flashing back to 203 would have fixed it.
Also DO NOT use a 203 equipped computer/hotwire to make adjustments to an esc equipped with 208. It can cause erratic operation.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-24-2010, 10:04 PM   #15870
Team Tekin
Randy_Pike's Avatar
Increase your +exp in your transmitter.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
