Old 07-23-2010, 06:16 PM   #15811
Team Tekin
Tekin Prez's Avatar
You will have 30deg of sensorless timing, which is still slower than spec mode where everyone will put all the timing in the motor (and probably melt it eventually). So it will not be an advantage in a spec race to lose the sensor plug and change to sensorless. Unless at the same time you add a few pinion teeth and you might get close, but not faster.
Yes you need to set C1 and apply settings, then set C2 and apply settings.
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 07-23-2010, 06:24 PM   #15812
HyperFX's Avatar
Send a message via AIM to HyperFX
Originally Posted by JayL View Post
sounds like alot of people in stock will have a sensor wire "fall out" lol
Not a bug, and has no spec advantage.
4PK, DEX410, DESC410R, DEX210, Tekin RS/RS Pro/RX8, Ten SCTE, XXX-SCT, XXXT-CR, XXX, XX, JRx2
MOTOCROSS: Because Roller Coasters Are Too Slow!
HyperFX is offline   Reply With Quote
Old 07-23-2010, 06:32 PM   #15813
Team Tekin
Tekin Prez's Avatar
Thinking this over more you will actually only have 10% sensorless timing ( 3deg) if you are in Spec mode and the plug comes out. You do not get to set sensorless timing when in TP1, it automatically defaults to 10% which is TP1 when in dual mode.
If the led is flashing in nuetral showing you are in spec mode you cannot increase the sensorless timing. If the plug comes out you will be dog slow, but get home.
[email protected]
www.teamtekin.com
Old 07-23-2010, 06:44 PM   #15814
lupin_au's Avatar
Send a message via MSN to lupin_au
Are there instructions anywhere on how you select the preset and the custom settings without the hot wire?
I cant see them anywhere.
Exotek T2R | Schumacher Mission | M05 Mini | RC18R | X-Ray T2-007 EU | Tekin | Sprektrum | EDS
http://www.westcoastrccarracing.asn.au/
http://www.lupinzblog.com/
lupin_au is offline   Reply With Quote
Old 07-23-2010, 06:47 PM   #15815
MikeXray's Avatar
Trader Rating: 73 (100%+)
http://teamtekin.com/manuals/RSManual.pdf
what used to be throttle profiles are now timing profiles.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-23-2010, 06:53 PM   #15816
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
and in the email it tells you the value of timing for 2-5
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-23-2010, 08:38 PM   #15817
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Is there still the need to calibrate at less than 100% throttle epa then bump up to 100? Since installing 208 and doing my normal calibration (KO Eurus, set at 95 then bump to 100), the turbo is definitely kicking in before full throttle is reached. Quite a surprise mid-sweeper!
-rocky b
flatspunout is offline   Reply With Quote
Old 07-23-2010, 09:00 PM   #15818
pakk's Avatar
Trader Rating: 79 (100%+)
Can you no longer disable LVC?
Also, I think I found a typo.
When you mouse over the LVC bar it states...
LED3 3s Lipo--9v
LED2 2s Lipo--6v
LED1 3s Liop--3v (I'm guessing this one should say 1s?)
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-23-2010, 10:55 PM   #15819
Trader Rating: 15 (100%+)
so has 208 fixed anyones brake issue?
anyone start me off with a setup and frd large track with 10.5 x12 cheers
jay m is offline   Reply With Quote
Old 07-23-2010, 11:18 PM   #15820
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
LED3 3s Lipo--9v
LED2 2s Lipo--6v
Yes 1 led is 1s lipo cut off. There is no "off" as we felt there was no need for it. Even 4 cell won't get to 3v's for those still running it(not sure who).
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-23-2010, 11:30 PM   #15821
For those who runs A123 or LiFe battery,the 'off' feature is useful.
But I guess the way to work around is to choose the lower cutoff setting.
ie, when running 2SA123, I would have to pick 1S setting.
Is my assumption correct?
Edit: I guess I can also use 'custom' LVC as well.
hardmankam is offline   Reply With Quote
Old 07-24-2010, 01:24 AM   #15822
pakk's Avatar
When racing, I've always felt a lot more comfortable with LVC off. 3v is very low though. I doubt I'd ever hit it. I don't think I have ever pulled my packs off that low. Maybe my 1s dips that low after a pro-longed practice run. I guess I will find out.
*Photon* *SC10 4x4*
RCRD
Old 07-24-2010, 01:25 AM   #15823
pakk's Avatar
custom will only allow you go got as low as 3v, aka 1s.
*Photon* *SC10 4x4*
RCRD
Old 07-24-2010, 01:41 AM   #15824
Andrew Barr's Avatar
I am going to use my RS in my 12th scale with a 3.7v Lipo and 6v receiver pack (13.5 motor). Do I need to disconnect the red wire from the esc plug that goes into the receiver?
Also what position should the esc on/off switch be in (if it matters)?
Giant MTB
Andrew Barr is offline   Reply With Quote
Old 07-24-2010, 02:44 AM   #15825
just finished downloading 208 and am about to install it and see what it looks like. I did have a question though...why was 5400 and 20000 chosen for the start and end RPMs in the on-board profiles? Most setups I've seen run quite a bit lower end RPM.
Also I noticed the "Advanced" button doesn't do anything...looks like the software is already in advanced mode but clicking it doesn't bring it out of advanced mode.
Thank you for fixing the lettering on the buttons so they can be read without mousing over them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
