Old 07-23-2010, 04:42 PM   #15796
Team Tekin
Tekin Prez's Avatar
We show the dual mode timing advance even when you are in sensored only mode, but it is not active. This is the timing you will have in sensorless to finish the race if the plug comes out or a sensor fails.
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 07-23-2010, 04:47 PM   #15797
STLNLST's Avatar
Trader Rating: 21 (100%+)
The nats are gonna be fun
STLNLST is offline   Reply With Quote
Old 07-23-2010, 05:00 PM   #15798
Send a message via AIM to munrath
Okay so Timing Advance doesn't apply to Sensored mode, but if the sensor comes out it will use it? So if I have it set to 30 nothing happens unless the sensor comes out? Correct?
Otherwise Boost of say 35 is the same thing as Timing Boost in the old software and Turbo is the same as Turo boost in the old software. Correct?
Current limit in on-road, what should I expect?
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 07-23-2010, 05:02 PM   #15799
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Is .02 as low as the delay goes? I set it to 0 delay, apply, close and reopen the hotwire and it is back to .02.
-rocky b
flatspunout is offline   Reply With Quote
Old 07-23-2010, 05:06 PM   #15800
Damnit Man's Avatar
Send a message via MSN to Damnit Man
Thank you!
Donovan P.
Damnit Man is offline   Reply With Quote
Old 07-23-2010, 05:12 PM   #15801
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Mark
Timing is all the same,in dual mode when the sensor wire falls off a value of 100 is 30*
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-23-2010, 05:14 PM   #15802
20 SMOKE's Avatar
-rocky b
never ran anything less than .3,maybe that's something they got rid of to help with to much timing to fast
Jamie W
Old 07-23-2010, 05:22 PM   #15803
Team Tekin
Tekin Prez's Avatar
Yes, I would set it 80% or more and you will still be slower than any sensored setup you had. If the plug comes out it will feel like Boost and turbo are turned off. Depending on how much motor timing you have set it will be even slower, but get you home with reasonable speed.
Yes
Current limit in on-road, what should I expect?Mark
A cooler motor and no loss of rip you can detect with about 80 or higher. If needed you can detune the rip, but not typical in onroad unless traction is low.
-rocky b
Yes. It was never really zero so and we decided to show you the real stuff instead of rounding.
[email protected]
www.teamtekin.com
Old 07-23-2010, 05:59 PM   #15804
Thanks!
-rocky b
Old 07-23-2010, 06:00 PM   #15805
syndr0me's Avatar
Trader Rating: 32 (100%+)
I've seen a couple of instances where the RPM range will go out of whack and set the end to something like 20k. I can't figure out how to reproduce it yet. I'll let you know if I figure it out. It reminds me of the 203 bug where you could click on the "fantom" box around the start RPM and it wouldn't actually select it.
syndr0me is offline   Reply With Quote
Old 07-23-2010, 06:03 PM   #15806
Suspended
If you have your ESC with v208 set to sensored mode and on stock spec profile tp1 but then had the dual mode set to max timing advance what happens if the sensor wire comes unplugged?
RC Racer OG is offline   Reply With Quote
Old 07-23-2010, 06:03 PM   #15807
20 SMOKE's Avatar
if you go from C1 to C2 and set the rpm range one will go back,i posted on what i did back a page
Jamie W
Old 07-23-2010, 06:04 PM   #15808
20 SMOKE's Avatar
Originally Posted by RC Racer OG View Post
If you have your ESC with v208 set to sensored mode and on stock spec profile tp1 but then had the duo mode set to max timing advance what happens if the sensor wire come unplugged?
it goes to into sensorless(dual mode) and you have 30* same as it did with every other version
Jamie W
Old 07-23-2010, 06:05 PM   #15809
Suspended
Sounds like a bug
Old 07-23-2010, 06:13 PM   #15810
JayL's Avatar
Sounds like a bug
sounds like alot of people in stock will have a sensor wire "fall out" lol
JayL is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
