Old 07-23-2010, 09:08 AM   #15736
AUDI 0000's Avatar
Originally Posted by niznai View Post
OK. I forgot you're not allowed turbo. Are you sure you calculate the FDR correctly?
I just use SPUR/PINION=A x Int= FDR .I had 94sp, 34pn, 2.43- @6.7 was the hottest came off at 198f using a fan heatsink also. I will start at 4.5-5.0 fdr next week and try it I guess.
TAMIYA TA05v2 /// TRF416 ///
AUDI 0000 is offline   Reply With Quote
Old 07-23-2010, 09:21 AM   #15737
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by tekinben View Post
Problem with the server. Sorry guys. Don't bother trying to download now.
regards,
Ben
Originally Posted by hardmankam View Post
How come I am keep getting the link to v203 (Hotwire v4.0.0) from the confirmation email? Did anyone get v208? has it officially released yet?
read above quote,
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-23-2010, 09:22 AM   #15738
yokemad's Avatar
Originally Posted by yokemad;
On v208 there is a timing advance option up to 80 is that for dual mode option?
Anybody?
yokemad is offline   Reply With Quote
Old 07-23-2010, 09:41 AM   #15739
20 SMOKE's Avatar
Originally Posted by yokemad View Post
Anybody?
timing advance is in dual mode and should go to 100=30*.208 didn't com out to everyone since the server had problems,only a few got it,you may be the only non team driver that has it
Jamie W
Old 07-23-2010, 09:49 AM   #15740
duggyload's Avatar
Did the server have problems or does it still have problems ?
duggyload is offline   Reply With Quote
Old 07-23-2010, 09:54 AM   #15741
Originally Posted by AUDI 0000 View Post
my 416 and evo are both super smooth no binding i can see. I dont really use brakes the drag brake is on 3 wich is almost off, but it gives me enough braking. i can try not using it. As far as motor its a brand new stock redline I havent touched it, and our 21.5 class does not allow for turbo, just timing. Its just frustrating I want to figure it out. The FDR advice and settings from the locals havent been working for me. I will try FDR in the other direction next week and hopefully my motor still good. Thanks
I've been running a 21.5 outdoors, but without timing. For that, I've been running a 4.0, with about 12* on the motor. It gets up to about 160 when it's really hot outside. The few times in the winter I ran with timing, I was around 4.25-4.5, with about 45 boost, and rpms from 5000-15000 ish, and that was hitting 140* in much cooler whether.
So like someone said above, I think you're way off on your gear. I didn't see you post your RPM range, but I'd strongly suggest starting with something safe like 5000-20000, and work down from there.
-Mike
Old 07-23-2010, 10:06 AM   #15742
Suspended
Default V208
Randy, After you update youe ESC to v208 how do you go back to 203 or 200 if you want to? In v203 there was a list of versions to choose and in v208 only 208 is listed.
RC Racer OG is offline   Reply With Quote
Old 07-23-2010, 10:07 AM   #15743
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
208 is a go...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-23-2010, 10:09 AM   #15744
yokemad's Avatar
No go back to older versions...
That's what it says while updating...
Old 07-23-2010, 10:15 AM   #15745
Originally Posted by Randy_Pike View Post
208 is a go...
Thank you Randy and the Tekin Team!
downloading now....
hardmankam is offline   Reply With Quote
Old 07-23-2010, 10:16 AM   #15746
buffalobill989's Avatar
Trader Rating: 50 (100%+)
got my copy. will have to wait till i get home to install
buffalobill989 is offline   Reply With Quote
Old 07-23-2010, 10:18 AM   #15747
20 SMOKE's Avatar
un install and re install,see if that helps
Jamie W
Old 07-23-2010, 10:22 AM   #15748
Default Q
Tourque limit or not?
I'm running tekin redline 17.5 in sedan with a tekin rs
What setting for the llimiter? trying to go as fast as possible lots of fast cars in the class, btw we run 6mins
does the limiter help with heat?
thanks
in advance.
Sterling Racer is offline   Reply With Quote
Old 07-23-2010, 10:22 AM   #15749
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up Got it !
Thank you Tekin
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-23-2010, 10:28 AM   #15750
Krio's Avatar
Trader Rating: 150 (99%+)
thanks
in advance.
Don't run current limit if you want as much power as possible.
www.kriostasis.com
Krio is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
