Old 12-08-2008, 10:41 AM   #1561
I downgraded the software and than i have my power back. upgrade it to189 and i don't have anny power anny moore.
Somting wrong with the software or my rs pro?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-08-2008, 10:44 AM   #1562
TRF415boy's Avatar
I'd say software. try uninstalling the hotwire on your computer then re-download off tekin's website and reinstall.
TRF415boy is offline   Reply With Quote
Old 12-08-2008, 10:48 AM   #1563
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
What brand of motor? Is it Sensored or a Sensorless?
I ran the 189 Software and everything worked perfect with a Tekin 13.5 in Dual Mode. Found I had to run the Timing at 65 to get the powerband the way I wanted it for how tight the track was..
dgullickson is offline   Reply With Quote
Old 12-08-2008, 10:55 AM   #1564
I run a lrp X11 10,5t with the bleu ring. tried it sensord ands sensorless and both were slow.
Downgraded it to the 183 and than it runs fast again.
sensord only slow again but than i need to time my motor.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 12-08-2008, 11:00 AM   #1565
Grenade10: bring it on to racing wed if you cant figure it before then but it probably a bad motor, you got spares just try one!
mxzhonkey is offline   Reply With Quote
Old 12-08-2008, 11:31 AM   #1566
shadow102's Avatar
Trader Rating: 21 (96%+)
How do I put the esc into dual mode?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 12-08-2008, 11:32 AM   #1567
Originally Posted by nnick View Post
You have to install the hotwire software and have the hotwire hardware
Then the only you need is to connect the hotwire hardware to your pc and that pc have internet access.
Start the hotwire application and that's it
So the firmware update is part of the Hotwire? Wouldn't that mess things up if you connect a FX or other ESC that uses Hotwire? Either way I downloaded the latest version (05/07/08) first thing so I'll be fine.
Old 12-08-2008, 11:33 AM   #1568
It is in dual mode by default. Unless you change it with Hotwire it will still be in dual mode.
Old 12-08-2008, 11:40 AM   #1569
TRF415boy's Avatar
The hotwire software looks for updates for every ESC that has been connected to it if you start it without plugging in a unit.
Old 12-08-2008, 12:01 PM   #1570
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you've upgraded to 189 you must make sure to recal your radio. You should also take note that in the RS and R1 the factory defaults have been changed.
Running your esc in sensored only mode with 0 boost should be the same as 183 software.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-08-2008, 12:11 PM   #1571
Kenny L's Avatar
Trader Rating: 16 (100%+)
Also make sure your radio is set to 50/50 not 70/30 throttle/brake.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-08-2008, 12:12 PM   #1572
RobS's Avatar
The problem I have been having is when I recalibrate the radio, it cannot find full throttle. It finds neutral fine, but when it goes to full throttle it just continues to blink. (This is a friend's car that I am setting up) So I bound my radio and I got it to calibrate, but still no throttle. The lights on the ESC light up as if it was working properly when I hit throttle/breaks but still have no motor. Any ideas? The ESC is brand new and never been run...
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 12-08-2008, 12:26 PM   #1573
Grenade10's Avatar
Trader Rating: 37 (100%+)
Try pushing for brakes and see if it runs. If so, just need to reverse the throtle (or std if it was already reversed). Happens on all Futaba's.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-08-2008, 12:27 PM   #1574
Krio's Avatar
Trader Rating: 150 (99%+)
RobS,
It sounds like your throttle channel needs to be reversed.
Randy,
Could you confirm that the RS doesn't use variable timing?
www.kriostasis.com
Krio is offline   Reply With Quote
Old 12-08-2008, 12:28 PM   #1575
Grenade10's Avatar
That is what I'm thinking after changing the sensor wire, but it is the DUO 17.5 that I finally got running VERY WELL!!
Put the Tekin into the Oval car, so the only one left is the Hacker ......
Out of town so, will not be there on Wednesday.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
