Old 07-23-2010, 01:11 AM   #15721
xray09ACT's Avatar
xray09ACT is offline   Reply With Quote
Old 07-23-2010, 01:25 AM   #15722
Problem with the server. Sorry guys. Don't bother trying to download now.
regards,
Ben
tekinben is offline   Reply With Quote
Old 07-23-2010, 01:25 AM   #15723
pakk's Avatar
Trader Rating: 79 (100%+)
tekins site still shows 203 from dec 31st as the latest update.
I don't think Randy was talking about 208. I think he was excited about that new Salt movie with Angelina Jolie. It released at midnight.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-23-2010, 01:44 AM   #15724
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by AUDI 0000 View Post
Hi hope someone can help me out. I run a sportsman 21.5 TC class indoor asphalt track 100x46 feet (100f back straight). I first had a Tekin rs in a TRF416 and had nothing but problems trying to get acceptable temps coming off the track, went both ways with the gearing, settings were not to crazy, think 40 timing, no turbo, everyone at the time had Tekins and was trying to help. I burned up 3 motors coming out of a main well over 210F. I took a six month break from the TC racing. Tonite was my first race again, new car EVO V MS, new Tekin w Redline motor. Well again I came out of the main at 198F, and I hope the motor can handle 1 run to that temp because I am sick of buying motors. Both qualifiers and main I tried various gearing and timing boost ( no turbo, Drag brake on 3, start at 4k end at 14k), I started (per others w RS advice) at FDR 6.04 timing 40- off at 169F, then 6.43 timing 40- off at 145F, Thinking I am going in the right direction and again from advice I went to 6.73 and timing 50- off at 198F. The class doesnt allow turbo and 5 other Tekin users all at MAX timing talking about they never go close to my temps. To top it off it was easily the slowest car down the straight. What am I doing wrong... I am sorry this is so long.
I think your rpm range is close, but you are gearing too short, imo
5.5 to 6.0 is fairly standard for 17.5 around here, so with 21.5 you should be something like that or taller, maybe 5.0 to 4.5 and 40 boost to start.
It sounds like you are getting heat from too much rpm, also explains why you are slow on the straight.
I run that motor around 3.1 with an F1 direct drive and it flies !
Also when trying new settings, it's safer to run 2 to 3 mins and temp.
Another way to find a good baseline for gearing, is to run zero boost, and gear to suit the track, then back down 1 64p tooth per 10 deg of timing for ballpark ratio.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-23-2010, 04:33 AM   #15725
yokemad's Avatar
Thanx for the update 
yokemad is offline   Reply With Quote
Old 07-23-2010, 05:13 AM   #15726
xray09ACT's Avatar
Old 07-23-2010, 06:44 AM   #15727
AUDI 0000's Avatar
Thanks for your help, I will try changing gearing next week. Hopefully my motor is ok....
TAMIYA TA05v2 /// TRF416 ///
AUDI 0000 is offline   Reply With Quote
Old 07-23-2010, 07:30 AM   #15728
M-Technic's Avatar
Trader Rating: 15 (100%+)
I hope nobody stayed up all night expecting the v208 download
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-23-2010, 07:36 AM   #15729
hehe, he is messing with us
Markiempje is offline   Reply With Quote
Old 07-23-2010, 07:58 AM   #15730
niznai's Avatar
Are you sure there's no bind in the transmission? It is quite strange to get those temperatures with your setup.
Another thing to try is to get rid of the drag brakes. Those can put out a lot of heat if they work too much. You don't mention anythign about using the brakes, and that is a factor too. Try to get the gearing so you don't have to brake through the infield. Keep the brakes for emergencies and/or a hairpin right after a long straight.
One other thign to check is the timing on the motor. I used to run 21.5 Redline with zero timing on the motor and gear for acceleration rather than top speed. You get back your speed using the turbo. I still think that is best for small tracks.
Good luck.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-23-2010, 08:18 AM   #15731
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by yokemad View Post
Hi Guys
Can anyone Mail me the v208 Please
[email protected]
Thanx in advance
Originally Posted by xray09ACT View Post
yeah me too, [email protected]
no and no,you will have to register just like 203
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-23-2010, 08:19 AM   #15732
AUDI 0000's Avatar
Good luck.
my 416 and evo are both super smooth no binding i can see. I dont really use brakes the drag brake is on 3 wich is almost off, but it gives me enough braking. i can try not using it. As far as motor its a brand new stock redline I havent touched it, and our 21.5 class does not allow for turbo, just timing. Its just frustrating I want to figure it out. The FDR advice and settings from the locals havent been working for me. I will try FDR in the other direction next week and hopefully my motor still good. Thanks
Old 07-23-2010, 08:31 AM   #15733
niznai's Avatar
OK. I forgot you're not allowed turbo. Are you sure you calculate the FDR correctly?
Team Greasy Weasel
Old 07-23-2010, 08:56 AM   #15734
yokemad's Avatar
On v208 there is a timing advance option up to 80 is that for dual mode option?
Old 07-23-2010, 09:07 AM   #15735
How come I am keep getting the link to v203 (Hotwire v4.0.0) from the confirmation email? Did anyone get v208? has it officially released yet?
hardmankam is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
