Old 07-20-2010, 10:44 AM   #15661
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Running both push and drag brake will be counter productive. So run one or the other.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-20-2010, 11:22 AM   #15662
Why not have one slider? In the middle is off and in one direction is drag and in the other is push. This way it's impossible for the end user to get this wrong.
g26er is offline   Reply With Quote
Old 07-20-2010, 12:40 PM   #15663
2xs
I understand that it is counter productive to have both active. So why not eliminate the possibility to have both active by either putting both on one slider, as suggested by g26er, or having a toggle control to turn one or the other on.
I am just tossing the idea out there for your consideration.
2xs is offline   Reply With Quote
Old 07-20-2010, 04:06 PM   #15664
Team Tekin
Randy_Pike's Avatar
While I say it's counter productive some have used both on very large tracks.
We could merge the two as stated, maybe in the future. Push control does change depending on how long you've been at WOT where as drag brake does not.
Old 07-20-2010, 04:24 PM   #15665
PaZ
PaZ's Avatar
sorry to drop in but ive been out of racing my tc for a few months is 203 still the daddy or has there been a update?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 07-20-2010, 04:31 PM   #15666
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
208 will be out soon
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-20-2010, 04:48 PM   #15667
Trader Rating: 31 (100%+)
Hi All,
Does anyone have a good setup (and FDR) for an LRP x11 17.5? I fried the front bearing on my Duo 2 and Iím pretty sure the LRP doesnít turn the same RPMs.
Thanks,
Jose
ittjv is offline   Reply With Quote
Old 07-20-2010, 04:55 PM   #15668
Come on hurry up and release V208 !!
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 07-20-2010, 04:59 PM   #15669
theisgroup's Avatar
if i have any say on this, i vote no. it took you 2 months to convince me to run push and now everyone at my lhs runs push. i love it and have not found a setup that does not work better with push.
push is not the inverse of drag brake. so don't merge the 2 settings. and I can see running both
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-20-2010, 07:01 PM   #15670
hijinx's Avatar
Trader Rating: 47 (100%+)
Originally Posted by ittjv View Post
Hi All,
Thanks,
Jose
Hey there mate, i run a X11 17.5 in my TC5, my FDR is 6.5, seems to give great punch out of the corners and awesome top end speed aswell, have top qualified the last two race meets at my local track.
Turbo boost 48
Turbo timing 16
Delay 0.0
Start 2###
Finish 11500
Ramp 2
Throttle profile 5
Hope this helps you out, any other questions PM me
Cheers Scott
Sponsored by Yokomo Australia Team Hearns Hobbies, AKA Tires from Ryper Hobbies.Fantom batteries and motors. Hobbywing,Pro Amps servos,Wild Turbo Fans,TWT. Yokomo BMax2 Hobbywing Fantom Ion4 8.5t. Yokomo BMax4 III Hobbywing Fantom Ion4 6.5t. Yokomo BD7 2016 Hobbywing Fantom FR-1 4.5. S2H BODIES for all your custom RC paint jobs.
hijinx is offline   Reply With Quote
Old 07-20-2010, 07:01 PM   #15671
Can you explain please how they can be used to compliment each other? Very interested to hear. Thanks.
Old 07-20-2010, 09:10 PM   #15672
macdude's Avatar
I fail to understand how they could complement each other.
Push control keeps the motor rolling and from what i gather was really designed for brushed motors to make the decelaration softer.
Drag break does just the opposite. It makes the motor feel like it is being dragged down like a brushed motor when you let off the throttle. This gives the car a more positive feel.
So if this somehow works together, I have yet to understand it that way.
Maybe you can use the push control to fine tune in the amount of drag break as it acts as a counter to it.
If I am totally off here please someone let me know.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 07-20-2010, 09:56 PM   #15673
Krio's Avatar
Trader Rating: 150 (99%+)
Unlike drag brakes, Push is only active for so long after you return to neutral. How long is calculated based on how much time was spent accelerating and how much throttle was applied. Any push settings take priority over drag brakes, but once the calculated effect for push is over, your drag brake setting takes over; be it 0 or 100. Whether you could benefit from this softened transition from on power to brakes depends on your driving style.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 07-20-2010, 10:19 PM   #15674
cheehtae's Avatar
Trader Rating: 15 (100%+)
Anyone there using a speedpassion v3.0 17.5 , need a good starting point (FDR), BTW it's for a Tamiya 416WE
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-20-2010, 10:58 PM   #15675
niznai's Avatar
That sounds like a wisely chosen combination of the two might help with running a oneway.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
