Old 07-18-2010, 10:30 AM   #15616
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
start here,but watch the temp
http://www.teamtekin.com/hotwire/ESC...-RS-TC-4-5.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-18-2010, 01:13 PM   #15617
Default V208 ??
Any chance we are going to see this before next weekend, We have a round of the British Championship here in England next weekend and I badly need the new software for the improved brakes ...
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 07-18-2010, 03:50 PM   #15618
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Do the new esc's have the profile to allow to run stock with no timing advance? Though i saw that that profile had to be loaded by the factory, Is this correct or can we down load the profile?
mdwaeracer is offline   Reply With Quote
Old 07-18-2010, 04:03 PM   #15619
TrevCoult's Avatar
The 208 RS software has the no timing advance profile built in. You just need to select profile 1 and you have it.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 07-18-2010, 04:19 PM   #15620
Hi guys, i'm after a little more punch/rip out of the corners. I'm running on a small technical carpet track using an Xray 009 with the 38t pulleys, Novak ballistic 13.5t and an fdr of 7.42. On the straight i can hold my own with the Speed passion users but infield i'm left behind. I'm running an RS with v203 using the following settings.
DB 40
RS 100
BS 100
NW 10
MT BL-FW
TP 5
VC 2
PC OFF
TIMING BOOST 50
TURBO BOOst MAX
TURBO DELAY 0.1
TURBO RAMP 1.0
START RPM 2548
END RPM 8004
SENSORED TICKED
The endbell timing is set right back to the - sign.
Any pointers appreciated.
BILKO1 is offline   Reply With Quote
Old 07-18-2010, 05:20 PM   #15621
DB 40
RS 100
BS 100
NW 10
MT BL-FW
TP 5
VC 2
PC OFF
TIMING BOOST 50 - Go Max
TURBO BOOst MAX
TURBO DELAY 0.1 - .o delay
TURBO RAMP 1.0 - 3.0 ramp
START RPM 2548 - around 4???
END RPM 8004 - 14500 end rpm
SENSORED TICKED
The endbell timing is set right back to the - sign. - Try some negative timing also. Novak has 30 degrees of timming stock.
Hope that helps.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 07-18-2010, 05:23 PM   #15622
DB 40
RS 100
BS 100
NW 10
MT BL-FW
TP 5
VC 2
PC OFF
TIMING BOOST 50
TURBO BOOst MAX
TURBO DELAY 0.1
TURBO RAMP 1.0
START RPM 2548
END RPM 8004
SENSORED TICKED
I would turn the motor timing back to the standard setting or N. Also set boost to max and reduce the turbo.set start rpm 5000 and end rpm 15000. turbo ramp 2. You could try zero turbo delay but see how it goes. I have run a 13.5 ballistic with the rs and it was rapid
Old 07-18-2010, 05:29 PM   #15623
20 SMOKE's Avatar
DB 40
RS 100
BS 100
NW 10
MT BL-FW
TP 5
VC 2
PC OFF
TIMING BOOST 50
TURBO BOOst MAX
TURBO DELAY 0.1
TURBO RAMP 1.0
START RPM 2548
END RPM 8004
SENSORED TICKED
need to know what size track and as stated above change the rpm range
Jamie W
Old 07-18-2010, 06:12 PM   #15624
STLNLST's Avatar
Trader Rating: 21 (100%+)
TQ and a win in 17.5 today running 208. Look for set up sheet to be posted on Tekin's website shortly.
STLNLST is offline   Reply With Quote
Old 07-18-2010, 06:16 PM   #15625
20 SMOKE's Avatar
just rub it in
Jamie W
Old 07-18-2010, 07:10 PM   #15626
mdwaeracer's Avatar
is the 208 available?
Old 07-18-2010, 07:24 PM   #15627
20 SMOKE's Avatar
no
Jamie W
Old 07-18-2010, 10:15 PM   #15628
STLNLST's Avatar
Originally Posted by 20 SMOKE View Post
just rub it in
You can run the same set up with 203.
Old 07-18-2010, 10:47 PM   #15629
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You should not be running 3.0 ramp rate on a track this short. Your end rpm is too low and this is causing your setup to bog down. On top of that your delay should not be this low with a start rpm as low as you have it set.
If you're going to run a delay in the 0 to .2 range your start rpm should be up around 5k. Understand that coming into the tightest 180 turn the rpms are still in the 3k range give or take. So running it lower than that serves no purpose.
I'd try a start around 5k, end around 15k , .1 delay , 10 turbo, 45 boost and find your gearing FIRST! This needs to be geared for the infield mostly. Then if you want to creep torwards max you can. Funny thing is that I've NEVER found a reason to run MAX anything and I still can lay the smack down in my stock classes.
If your gearing is right NO amount of esc tuning will help you.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-18-2010, 10:55 PM   #15630
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by Randy_Pike View Post
If your gearing is NOT right NO amount of esc tuning will help you.
Fixed
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
