Old 12-06-2008, 05:48 PM   #1546
Regional Moderator
CarbonJoe's Avatar
Push control is the opposite of Drag Brakes, and it more useful on brushed motors. It is equivalent of adjusting the throttle trim so that the neutral position on the throttle actually has a little bit of throttle dialed in. Brushless motors have such little drag brake that this setting is basically worthless for them.
The Timing Boost feature adds software timing to the timing set in the motor. It is supposed to be available in the next version of RS firmware/Hotwire. Not sure when the throttle curve support or additional profiles will be added.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-06-2008, 07:09 PM   #1547
shadow102's Avatar
Trader Rating: 21 (96%+)
ok thanks guys that boost setting sounds useful looking forward to using it
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 12-07-2008, 11:47 AM   #1548
Trader Rating: 26 (100%+)
is there a way to check the sensor wire with the speed control?
eddie10 is offline   Reply With Quote
Old 12-07-2008, 12:05 PM   #1549
miller tyme's Avatar
With the ESC on, rotate the motor by hand, the last 3 leds should dimly light and go out in sequence as each sensor is activated.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 12-07-2008, 05:03 PM   #1550
TRF415boy's Avatar
Originally Posted by Quante View Post
Thats an easy one:
http://forum.teamtekin.com/phpbb3/vi...hp?f=20&t=1821
If you dont go over 80 timing, start is pretty good, when you do go over (and you need to on 4 cells) it starts worse and you'll be a sitting duck a lot longer when you're spinning out or have been pushed backwards.
I have allways run a GM EVO3 9.5, with this motor starts werent that good.
I recently (last 2 batteries) switched to the newer GM 9.5 purple and starts have improved dramatically.
But this motor really lacks power and need a lot more timing and I'm limited to the soft. timing! (now you hear for the RS they simply make a function that you can add timing upon the (fixed) sensor timing).
That is strange neither randy nor jim have told me about that, i'll ask them... Either way you're running the wrong speedo for your class, you really want to be running the RS, the R1 never really worked that well on slow motors, especially in lower voltages.
TRF415boy is offline   Reply With Quote
Old 12-07-2008, 05:05 PM   #1551
TRF415boy's Avatar
Originally Posted by RobS View Post
Ok guys well I have an small issues with a buddy's RS ESC. When I turn the car on all the led's light up really but are really dim. I tried downgrading the ESC to a older version then back up to the latest and it still does not work. If I hold the mode button when the 7 dim led's are on it will ramp up one time then go back to nothing. I also get an error message when I try to apply new settings on my hot wire. Any ideas?
edit: I have a motor that has a broken sensor board and it does exactly that, your sensor board is damaged.
Old 12-07-2008, 05:11 PM   #1552
TRF415boy's Avatar
Just wanted to share with you that I've used the new boost control to take 2nd place at carpet wars (UK) in 10.5 using a RS/Redline/tekin 3400 lipo today. As far as I'm concerned the boost control greatly improves the RS in spec classes, as well as in modified. As a bonus (or onsolation for not having TQ due to a backmarker) I did also get the fastest lap of anybody in 10.5 in the final
Old 12-07-2008, 11:42 PM   #1553
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Azmio: Contact me here about your esc: [email protected] I have some questions before we think about sending it back.
What version of the software are you running in your R1? We have improved the sensorless starts with somftware 183+.
Honestly though for any 4 cell racing the RS will truly shine even over our own R1. The sensored start is very nice to have when voltage is low.
The Timing boost software is in the hands of the team right now. Public release will be soon.
Sorry I haven't been on here the last few days, I have been out of the office.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-08-2008, 02:02 AM   #1554
I have updated my RS pro and now i have no power anny moore.
I'm going to reset the rs and try it again. I think somting went wrong wile updating. it was verry fast finished.
Driving away in the dual mode (sensord sensorless) than it has some problems.
Sensord only it goes great. hopfully i get the esc ok today so i can use it sunday.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-08-2008, 02:37 AM   #1555
Default 1/12th setting up date
After a couple of months of trying different settings i have finally I hope reached the definitive.
Running a Corally with SP 10.5R BL and RS ESc.I would love to run the redline but not available in the Uk.
Drag brake 45
Brake 50
Neutral width 2
Punch 4
Timing 90 but as i run sensored not really relevant
Fwd/Brk
Current limiter 85
Sensored mode ticked
think thats it.These settings gives the car a smooth and very linear acceleration .Handling has improved dramatically.In fact it feels slow.
But we all know slow is fast.
tellan is offline   Reply With Quote
Old 12-08-2008, 03:46 AM   #1556
Where are you finding the firmware updates? I've only seen ones for the R1 not the RS. Been looking all over Tekin's web site.
Old 12-08-2008, 04:32 AM   #1557
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
You have to install the hotwire software and have the hotwire hardware
Then the only you need is to connect the hotwire hardware to your pc and that pc have internet access.
Start the hotwire application and that's it
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 12-08-2008, 07:00 AM   #1558
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've been running the RS and RS Pro for several months onroad and oval on the carpet with very good success, but I ran into something yestrday in my 1/12 scale car running the RS.
I know how to watch for the sensor lights to flash when the motor is rotated. However, the one in the 1/12 scale does not flash, motor coggs, and goes into reverse. So I changed the sensor wire thinging it was broken, but still the same, then I checked using the Hotwire to make sure I was in full sensor mode and it was.
Thoughts .... ESC? ..... Motor? ..... Operator?
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-08-2008, 07:23 AM   #1559
Kenny L's Avatar
Trader Rating: 16 (100%+)
I've had this happen before was always bad sensor wire. New ones arent always good. Sometimes they dont uncoat the wires enough and they is not good contact. Double check all end of sensor wires.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-08-2008, 07:48 AM   #1560
Regional Moderator
CarbonJoe's Avatar
Also, try a different motor. If the sensor board is bad, that could also do it.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
