Old 07-08-2010, 07:25 PM   #15436
big al's Avatar
I'm sure this had been asked many times, but it's too hot to go back countless pages and hopefully find an answer..... Has tekin considered an android platform. Pretty please!!!
big al is offline   Reply With Quote
Old 07-08-2010, 08:49 PM   #15437
Default Weak Brakes
I'm not sure if this has been mentioned by anyone yet, so here goes.
My brakes, particularly when the care is barely moving (lining up on the grid) became extremely weak when I changed my final drive from 5.x down to 4.0. I don't brake much at higher speeds, so I didn't really pay attention to the difference. I first noticed the weak braking with my 21.5 that was already at a 4.0 final drive, but then
I wondered if maybe it was because I had no drag brake, so last night I experimented. Sure enough, when I bumped up the drag brake a couple steps (using the speedo), the brakes felt stronger. I bumped it up a few more steps, and sure enough, the car now stops quickly at very low speeds. So what happens when you pull the brake trigger is definitely impacted by the drag brake setting. Perhaps the speedo is adding the trigger brake to the drag brake, instead of making the trigger interpolate between the drag brake setting and full braking power.
The next thing I want to try is to dial in a bunch of drag brake, but then dial in a bunch of push control, and see if it ends up working like a lower drag brake setting with stronger overall brakes. Like maybe once you apply the brakes, the push control would shut off and then you'd have your drag brake + trigger brake.
-Mike
Old 07-09-2010, 07:51 AM   #15438
Capt'N_Slow's Avatar
Don't use Drag brake and Push Control at the sametime. When I tried it and my motor started to make strange sounds.
Only use drag brake or push control.
Micah
Capt'N_Slow is offline   Reply With Quote
Old 07-09-2010, 08:33 AM   #15439
niznai's Avatar
-Mike
Drag brakes and brakes are supposed to work separately.
The reason your car now has better brakes at low speeds is that the drag brake is able to stop it (not the normal brake). Not sure why your normal brake doesn't work, but it should. I can lock the wheels on my car with a RSpro and a 17.5 Redline. One other thing to remember is that a lower gear ratio like yours takes away the brakes.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-09-2010, 10:52 AM   #15440
macdude's Avatar
-Mike
That's really odd. The only time I have ever had break issues was with an older version of the software. The other thing that you might check and I have seen this affect the break power too is using the dual drive mode. If you run in sensored only mode this seems to make the breaks stronger. Where dual drive they feel a little weaker. And as I said before with version 198 was like there was none.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 07-09-2010, 01:27 PM   #15441
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-09-2010, 02:34 PM   #15442
Not doubting, but what's the reasoning for that? It doesn't make sense that they should be separate. What makes sense to me that the esc has a maximum amount of braking power that can be applied, no matter what. That would be reduced with the brake strength setting. With 0 trigger, you'd get none of it, and with full trigger, you'd get all of it. Then drag brake would simply change the "no trigger" point to be higher than zero, but full trigger would still be full trigger. Clearly it doesn't work that way.
So can I, with timing boost and a higher gear ratio.
See that's the thing, it makes sense that maximum braking potential would be less with a lower gear ratio, but it's like the car has no brakes at all with the trigger at low speeds, where it should still be able to stop flat. It's like the speedo's not even trying. But yet the drag brake has no problems, and will stop the car in its tracks once it gets below a certain speed.
Keep in mind I'm running sensored, but with the boost turned off. Perhaps I should try adding like 1 degree of timing boost, and see what happens.
-Mike
Old 07-09-2010, 02:50 PM   #15443
So i've geared my car down to a 5.99 final drive i'm trying to get as close to a Reedy Nats. setup. Going to also change the turbo delay to 0.3. What's a good RPM start and end range for 13.5?
immrwright7 is offline   Reply With Quote
Old 07-09-2010, 03:30 PM   #15444
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Randy_Pike View Post
The Duo2 likes to be ran with negative 5 on the timing with agressive setups.
What is the preference for a Duo2 17.5 for the motor timing? Thanks in advance.
bvoltz is offline   Reply With Quote
Old 07-09-2010, 04:27 PM   #15445
Senna Racing's Avatar
That is the motor timing
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 07-09-2010, 05:22 PM   #15446
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
heh.. you quoted your own answer.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-09-2010, 07:28 PM   #15447
20 SMOKE's Avatar
try randy's setup on tekin's site
Jamie W
Old 07-09-2010, 09:06 PM   #15448
M-Technic's Avatar
Trader Rating: 15 (100%+)
Like I said I like 0 to 1 tick of positive timing on all Duo2's.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-09-2010, 10:02 PM   #15449
bvoltz's Avatar
I'm just puzzled by the neg 5, I have it turn full + with 45 in the speedo... She is coming off the track at 190 and running 6.5 FDR..
I think I cut out the part Randy was talking about a Duo2 13.5, not 17.5, but my bad...
Old 07-09-2010, 10:02 PM   #15450
bvoltz's Avatar
Ok, thanks... I give this a try...
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
