Old 07-06-2010, 10:38 PM   #15421
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Randy_Pike View Post
Yes the 208 will be available at the Paved Nats. I will be in attendance also.
Good to hear RP
Was hoping to use the RS in 12th 17.5
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-06-2010, 10:47 PM   #15422
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
how about a baseline for a SpeedPassion 17.5v3/ RS Pro, 80' straight, outdoor asphalt, technical parking lot track? lots of traction!
TC5R/5000mah-35c
new to sp motors, have heard to turn motor timing to max...have used Orion V2.
thanks for the help...
mkennedy is offline   Reply With Quote
Old 07-06-2010, 11:12 PM   #15423
What's news in the 208?
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 07-06-2010, 11:14 PM   #15424
The straight at Norcal is longer than that. Regardless there are a few things you've left out: Where is your motor timed? What battery are you using?
The Duo2 likes to be ran with negative 5 on the timing with agressive setups. Also for 13.5 you've got a bit more room to play ONCE you've found your gearing. The turbo time delay should be higher than .1 . Try .3
It was just a guess at how long the straight is. Sorry math was never my strong subject.
I'm using a tenergy 5000mah 40c battery. I also set the motor back to 0 as far as the timing.
I have the high rpm set at 15,000 and the start point at 3,149 rpm
immrwright7 is offline   Reply With Quote
Old 07-07-2010, 06:40 AM   #15425
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
will we be able to get the new software via email or through the site at the same time?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 07-07-2010, 08:40 AM   #15426
pmc
Hello
I run with other brand of escs in stock class, but i want to leave this brand and purchase a Tekin esc.
To the next season i will run in modified class and i want to know wish is the best motors brand to run with the RS Pro esc??
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 07-07-2010, 09:54 AM   #15427
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by immrwright7 View Post
I need some help with my tekin setup people because i'm stumped!
I'm running the Tekin RS Pro with a 13.5 duo 2 motor at nor-cal hobbies and my car doesn't seem to work well down the backend. My final drive ratio is at 6.49.
Throttle Profile is at 5
Timing is at 40
Turbo Boost 10
Turbo Delay 0.1
Turbo Ramp 2.0
I've geared that car all the way down to 5.10 final drive ratio but I was told that the car was overgear'd
Infield the car is perfect! but going down the 60ft straight-a-way my car is performing like a 17.5. Please help me people.
Either my gearing is way off or yours is. Because that is what I run in my 17.5 at norcal. I think I'm actually around 6.3ish. My car is not the fastest down the strait, but it seems ok.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-07-2010, 10:57 AM   #15428
Originally Posted by 20 SMOKE View Post
what size is the track
straight road approximately about 150ft..
Thanks.
ckloo is offline   Reply With Quote
Old 07-07-2010, 01:26 PM   #15429
I recon not enough turbo delay, and the car is bogging down with a truck load of timing before the speed is up.
I have a similar length straight, with a long sweeper into it. I run 0.7 turbo delay, and a bit less overall timing. We have a large flowing track.
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 07-07-2010, 03:04 PM   #15430
Trader Rating: 19 (100%+)
when will it be available to anyone in the public? Is there a version 206, im told at my local track there is? Thanks.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 07-07-2010, 03:07 PM   #15431
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
no there isn't,203 and 208 will be out next with no time frame
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-07-2010, 04:46 PM   #15432
20 SMOKE's Avatar
well 208 looks to be closer than we think
http://www.teamtekin.com/hotwire/ESC...n-TC-BD6-5.pdf
Jamie W
Old 07-07-2010, 04:47 PM   #15433
20 SMOKE's Avatar
Thanks.
ths should get you in the ball park http://www.teamtekin.com/hotwire/ESC...-Big-track.pdf
Jamie W
Old 07-07-2010, 06:49 PM   #15434
whats going to be different from the 203? faster? more options? or what?
★Randy Banks★
Old 07-07-2010, 06:58 PM   #15435
20 SMOKE's Avatar
randy hasn't said but on feature is for the stock class to go to a setting using the mode button and checking it by a flashing led
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
