Old 07-05-2010, 07:02 PM   #15406
tallyrc's Avatar
ahh.... so not just adding the spec timing... sweet..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-05-2010, 07:39 PM   #15407
reenmachine's Avatar
Trader Rating: 26 (100%+)
Yes, that was announced some time ago. The spec feature is complete but is being rolled out along with a host of other improvements.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-05-2010, 11:00 PM   #15408
I need some help with my tekin setup people because i'm stumped!
I'm running the Tekin RS Pro with a 13.5 duo 2 motor at nor-cal hobbies and my car doesn't seem to work well down the backend. My final drive ratio is at 6.49.
Throttle Profile is at 5
Timing is at 40
Turbo Boost 10
Turbo Delay 0.1
Turbo Ramp 2.0
I've geared that car all the way down to 5.10 final drive ratio but I was told that the car was overgear'd
Infield the car is perfect! but going down the 60ft straight-a-way my car is performing like a 17.5. Please help me people.
immrwright7 is offline   Reply With Quote
Old 07-05-2010, 11:52 PM   #15409
bigdadracing's Avatar
[QUOTE=Randy_Pike;7631700]DO NOT in ANY way add reverse to the unit trying to make brakes out of it. That will cause HUGE current spikes and you're going to ruin the esc.
You've been warned.
The latest software is in team hands right not under vigurous testing. There are some HUGE improvements to this software and it needs to be right. Bare with us...
randy will the new software be posiblly avalible by roar aspalt nats????
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 07-06-2010, 02:39 AM   #15410
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
It better be! I'm signed up for sportsman 17.5 and I don't have anything but a Tekin to run.
Old 07-06-2010, 07:35 AM   #15411
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Timing is at 40
Turbo Boost 10
Turbo Delay 0.1
Turbo Ramp 2.0
the straight is only 60ft?
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-06-2010, 07:39 AM   #15412
HopeyOne's Avatar
Default Thanks Heaps
Originally Posted by hardmankam View Post
Here are my suggestions:
#1.
Drag Brake 20
Rev strength 100
Brake Strength 100
Neutral Width 56 --> 10
Motor Type BL-FW
Throttle Profile 3 --> 4
Voltage Cutoff 2
Push Control Off
Timing Boost 40 --> 50
Turbo Boost 10
Turbo Delay 0.1 --> 0.2
Sensored (checked)
ESC Model RS Beta
Current Version 203
Start RPM 2950
End RPM 13996 --> ~11000
Turbo Ramp 2.0
or #2.
Drag Brake 20
Rev strength 100
Brake Strength 100
Motor Type BL-FW
Voltage Cutoff 2
Push Control Off
Timing Boost 40 --> 45
Turbo Boost 10 --> 15
Sensored (checked)
ESC Model RS Beta
Current Version 203
Start RPM 2950 --> ~5x00
End RPM 13996 --> ~13x00
Turbo Ramp 2.0
Check motor temp in both cases.
Thanks for your help guys, ran in the 13.5 BL class tonight with a Novak 13.5 motor and some of the setting changes mentioned on this thread, car was a rocket, pity I can't drive, but the car had heaps of torque and was equal to the fastest cars down the straight. Can't tell you how much fun I had, now I juist have to learn how to drive.
P.S. I'm not having the brake issue, not sure why, but I can lock the wheels if I stand on the brakes.
Back to 17.5 class this weekend, planning on keeping the same settings but maybe increasing the rollout slightly, would that make sense when moving from a 13.5 to a 17.5?
Thanks again......still grinning
Clueless Racing
Team Magic E4JR & E4
Tekin RS
Hacker 17.5
Novak 13.5
HopeyOne is offline   Reply With Quote
Old 07-06-2010, 08:32 AM   #15413
20 SMOKE's Avatar
yes you do need to change the gearing,probably 2-3 teath on the pinion
Jamie W
Old 07-06-2010, 09:00 AM   #15414
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Timing is at 40
Turbo Boost 10
Turbo Delay 0.1
Turbo Ramp 2.0
The straight at Norcal is longer than that. Regardless there are a few things you've left out: Where is your motor timed? What battery are you using?
The Duo2 likes to be ran with negative 5 on the timing with agressive setups. Also for 13.5 you've got a bit more room to play ONCE you've found your gearing. The turbo time delay should be higher than .1 . Try .3
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-06-2010, 10:44 AM   #15415
2wdrive's Avatar
Hoe do you adjust the timing on a DUO2? Do i need to unscrew the three philiphead screws to turn the endbell?
2wdrive is offline   Reply With Quote
Old 07-06-2010, 11:24 AM   #15416
M-Technic's Avatar
Trader Rating: 15 (100%+)
Yes.
And contrary to what Randy said I always like my Duo2's to to have about 1 tick of positive timing (one tick to the right of the large center hash).
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-06-2010, 11:59 AM   #15417
Right now I have the motor timed at one hash above the positive mark.
Old 07-06-2010, 10:24 PM   #15418
Team Tekin
Randy_Pike's Avatar
Yes the 208 will be available at the Paved Nats. I will be in attendance also.
Old 07-06-2010, 10:30 PM   #15419
Still Bill's Avatar
NOT!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-06-2010, 10:37 PM   #15420
Still Bill's Avatar
Default WGT with 1S Lipo and RS ESC
Randy,
Will there be any benefit in running the 208 on my RS in the WGT class at the Nats?
What specific settings will help me save my 1S lipo pack for the later part of a 6-minute race. I keep taking off into the lead for most races and then get caught (and passed) in the last minute. Grrrrrrrr...
Thanks.
Bill
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
