Old 07-03-2010, 10:53 PM   #15376
ericbeenorcal's Avatar
Default tekin rs pro system 4.5t
sup tekin heads!!
just picked up my 4.5t tekin rs pro yaal
was wondering exactly where to solder the capacitor and what happens if i dont use my tekin sensor w the bless motor?
and is this 4.5t too much power for a serpent s400 locked rear diff n spool front for indoor carpet medium size track,
any tuning suggestions and pinion/spur combo??
greately appreciated yaal, EB. norcal
Tekin RS ESC sensored-as1.jpg   Tekin RS ESC sensored-as2.jpg   Tekin RS ESC sensored-as4.jpg
BocaBearingdePeppo
ericbeenorcal is offline   Reply With Quote
Old 07-04-2010, 01:21 AM   #15377
HopeyOne's Avatar
Default Thanks
Thanks for the help guys, I'll give the suggested settings a try on Tuesday night.
Clueless Racing
Team Magic E4JR & E4
Tekin RS
Hacker 17.5
Novak 13.5
HopeyOne is offline   Reply With Quote
Old 07-04-2010, 02:35 AM   #15378
Originally Posted by ericbeenorcal View Post
sup tekin heads!!
Right where the instructions show to solder it.
What's a bless motor? I'm guessing you mean use a sensorless motor with your Tekin RS Pro? I believe the RS has a sensorless mode...but not real sure.
Not sure about running a locked diff...but most likely it is too much power for those tires.
Old 07-04-2010, 05:45 AM   #15379
Team-RTR's Avatar
im guessing he meant b/less (brushless abbreviation).. running without the sensor wire for the 4.5t is fine, but you must make sure the ESC is set to dual mode (sensorless).
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 07-04-2010, 06:25 AM   #15380
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it will go in dual mode automatically if the wire is not used
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-04-2010, 10:34 AM   #15381
pakk's Avatar
Trader Rating: 79 (100%+)
Default Launch control
I do remember Tekin commenting on this before saying that the feature does little to nothing. I believe it was in this thread. But I recently picked up a ESC that has launch control. Hold brake for a few seconds and at the first sign of throttle, you get full power. But it seems to me that this ESC is doing more than just giving you full power at the launch. I believe some timing is being played with. The car just accelerates a lot harder. Free wheeling it, the tires balloon a lot more with launch control then with out.
So here's my idea:
Incorporate a launch control with timing adjustment.
Make it so holding brake for a certain amount of time puts the ESC into launch mode. Then in the hotwire, ad a launch control slider. I don't really know what kind of timing adjustments are beneficial at launch. I have a feeling that just a set amount of timing is good. Maybe a ramp is needed, I don't know.
Just an idea.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-04-2010, 11:04 AM   #15382
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
What "Launch control" was on some brushed escs, was a current limiter bypass for at the start of a race.
Mac The Knife is offline   Reply With Quote
Old 07-04-2010, 06:14 PM   #15383
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Mac is correct. Any esc that is giving you a "launch" start is holding back power otherwise. We don't offer a "launch" because when you ask for full power, we give it to you.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-04-2010, 07:52 PM   #15384
I'm having a problem downloading the hotwire on window 7. Actaully two of use are having the problem. Is there something we are doing that is not letting us download the software?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-04-2010, 08:03 PM   #15385
20 SMOKE's Avatar
does your pc have a zip program,i just put the HW on my new laptop with W7 and it offered a auto install so i did that
Jamie W
Old 07-04-2010, 08:56 PM   #15386
Default tekin rs pro 4.5t
tnx for the info folks!
greately appreciated!
1 more question --
my esc rs pro gets super hot?
using a 93tzpur/ 33tpinion -64-
on a serpent s400 -- so hot that the sticky underneath the esc started to curl and unglue?
should i go higher or lower gear ratio? suggestions?
BocaBearingdePeppo
Old 07-04-2010, 09:03 PM   #15387
20 SMOKE's Avatar
1 more question --
add a second cap and drop pinion/raise spur
Jamie W
Old 07-04-2010, 09:40 PM   #15388
Even though my answer was right, this still does not excuse yourself of when the software updates will be available.
Using contractors for software development sucks.
Old 07-04-2010, 09:54 PM   #15389
Official's Avatar
So here's my idea:
Just an idea.
So far i have no Launch problem with my RS pro. All my launch was way faster then the LRPs with Launch controls, to a point if i tighten the rear diff too much i can actually pop a slight wheelie.
From what i see the power given out from the RS pro is like when you want is where you want it.
my 2 cents.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: [email protected]
Official is offline   Reply With Quote
Old 07-04-2010, 10:47 PM   #15390
Default 20 smoke
thanks 20 smoke!
imma try ur advice, 2nd cap means 2nd capacitor? if so can i use a novak capacitor on my rs pro?
-- am also converting my s400 to C/S countersteer set up for drifting,
i am looking for a 10t aluminum pulley for rear that will fit for my car any suggestions?
BocaBearingdePeppo
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
