Old 12-04-2008, 10:40 AM   #1516
Regional Moderator
CarbonJoe's Avatar
Originally Posted by Adam? View Post
I have the throttle reversed on my 3PK too.
Is it normal for a 13.5 to scream like a 3.5 (on the bench) with the new software? It'll be interesting to see how it does on the track.
From what I've seen from the team drivers using the latest F/W at Cleveland, you'd better drop 4 - 5 teeth on your pinion or you'll heat that motor up quite a bit if you are using the "Timing Boost" feature.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-04-2008, 03:04 PM   #1517
Grenade10's Avatar
Trader Rating: 37 (100%+)
Just got the 4PK working last night and it's the same in it as well.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-04-2008, 06:45 PM   #1518
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by mangoman View Post
Just so you know if you want to save some dollars.... you really only need the pro version for on-road modified touring.
Don't forget 4wd electric off road as well. They work the ESC just as much, and in a more hostile environment. Heat, heat, and more heat.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-04-2008, 08:35 PM   #1519
mangoman's Avatar
My understanding is this should not be a problem, due to the fact that they dont run motors as low wind as on-road mod touring. Although it might be safer to go with the Pro, i think that reps have posted here that you only really need the pro for mod touring car.
The standard is "Motor Limit Brushless Mode: 5 Turn, 36mm can"
I dont run off road but im assuming you would just be getting massive wheel spin and dig holes in the track with a 4.5 or faster mounted.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-04-2008, 09:56 PM   #1520
CDW
Send a message via Yahoo to CDW
I am probably the 1000th person to ask this but what is the difference between the RS and the RS Pro? Which would you recommend for someone running 12th stock? Is there any advantages of getting the PRO over the non-pro other than motor limit?
Thanks guys for your time,
Team CRC/Team Matrix Tires USA/Fantom Racing/CDSUPERPRO/RK Designs/Access Hobbies & Raceway
CDW is offline   Reply With Quote
Old 12-04-2008, 10:51 PM   #1521
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
RS - you cannot run anything less than a 5t
RS PRO - Run whatever you want.
I usually recommend an RS to those running 19t or Stock (save yourself some $$), and recommend the RS PRO to those running Mod Sedan or 4wheel Mod Offroad.
dgullickson is offline   Reply With Quote
Old 12-04-2008, 11:16 PM   #1522
Grenade10's Avatar
And if you run 1/12 scale, the RS is shorter in height up off the chassis so it fits under the low bodies, and it weights a little less ..... all good things!!!
Keep it up guy's!
Old 12-05-2008, 12:50 AM   #1523
mangoman's Avatar
They say the pro version has more fets in it, something to help it with the faster motors **SHRUG**
Its slightly heavier, but can run bigger motors. Looking at the stats it has less resistance but i dont know if that means anything significant.
www.smaracing.org
Old 12-05-2008, 01:01 AM   #1524
Adam?'s Avatar
I think maybe full boost is excessive for a Novak 13.5. :-D I had to gear it down like 8 teeth, and it still ran hot. It seems pretty quick on the straights, but a bit gutless in the middle. I'm gonna hold off and wait for the official release. Hopefully new profiles from the team guys will show up quick.
Adam? is offline   Reply With Quote
Old 12-05-2008, 01:06 AM   #1525
yeah, double the FETs in parallel will half the overall resistance and double the current capability.
stocker is offline   Reply With Quote
Old 12-05-2008, 03:13 AM   #1526
TRF415boy's Avatar
If you're running full boost and have the motor timing up to max then you're over-timing it, which causes more heat for no more power. Back the timing until you see a loss in speed.
TRF415boy is offline   Reply With Quote
Old 12-05-2008, 04:31 AM   #1527
Will this be an option on the R1 as well???
And when will the new software update for the R1 be available??
I run a R1 in 1/12th on 4 cells and I need more timing than the hotwire can give me.
Isnt it possible to just link timing advance to throttle input?? Start with low timing for torque (and less startup probs on the sensorless R1) and end high for more topend)
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 12-05-2008, 04:40 AM   #1528
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Did ther motor "cog"? I had full timing and 12 deg in the motor timing and it won't run. Then you have too much timing!! In 1/12 I was at 40-84 with 1.70 rear tires. The motor came off at 170 deg. and didn't fade at the end of the 8 minute race. You can also listen during the race and here the "cogging" as the race goes on coming off the turn. I used it as a tuning aid for gear ratios or timing settings. I try to run as much timing and gear LOW.
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-05-2008, 06:23 AM   #1529
TRF415boy's Avatar
The R1 doesn't run sensored so no there won't be an update for the R1, this is a RS only update.
The R1 already does that, low timing on low RPM and higher as the motor revs up.
Old 12-05-2008, 07:11 AM   #1530
Krio's Avatar
Trader Rating: 150 (99%+)
Neither the r1 or rs changes the timing as the rpm ramp up...
The only thing close is the rs in hybrid mode where the timing on the motor is used to start (set that low) and then switches to the hotwire timing (set high).
I hope the next update comes with reactive timing *hint hint tekin*
www.kriostasis.com
Krio is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
