Old 06-18-2010, 08:37 AM   #15196
DaveW's Avatar
I need a clarification before i hit the track tomorrow. Im not gonna have practice time to try this to know...
If i set my start RPM at 5k, and turn off the delay, then turbo doesnt start until 5k... right? It follows start RPM regardless of wide open throttle?
Meaning, if my use RPM is above 5k (lets say 7500RPM) and i lift the throttle slightly but dont drop below 5k RPM (start RPM), then i am still in boost when i get back into the throttle?
I wanna solve this delay issue when i lift the throttle to check up going through traffic. Losing boost can cost me almost 2 seconds a lap on our current layout.
Also, is there anyway currently available to datalog a run? I could really tweak this thing if i had stored run info to compare too...
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 06-18-2010, 08:49 AM   #15197
You're confusing boost and turbo I think.
Boost is a function of RPM
Turbo is a function of time after full throttle is reached and is independent of boost for when it activates.
Timing on the motor can itself is a constant factor.
Boost is started at a specific start RPM and ramps up linearly to full boost by the end RPM. Lift the throttle anywhere within the boost range and when you get back on the throttle the boost timing will be applied instantly dependent on what RPM the motor is doing at that point once it is within the start and end RPMs. If the motor is under the start RPM no boost timing will be applied. If the motor is over the end RPM maximum boost timing will be applied instantly.
Turbo starts after a set time after full throttle is reached. The turbo ramp rate controls how fast the turbo timing is applied.
Check previous posts by Randy Pike/20Smoke or Team Tekin's forums for a more detailed explanation of boost and turbo.
I hate having to lift when I'm on turbo because I have quite a large delay (0.8-1.2 depending on the track). If you lift briefly you can get back on Turbo almost instantly but lift too long and you're back to waiting on your turbo delay time to get back on Turbo.
spongerX is offline   Reply With Quote
Old 06-18-2010, 09:17 AM   #15198
DaveW's Avatar
I had read back in the thread, i guess not far enough.
Your explanation makes perfect sense, and shows me i need to change my setup so i dont rely on turbo so much... or quite the opposite. Maybe i need to use turbo throughout the throttle band on a low ramp with no delay and modify the timing parameters. Lifting in traffic kills me, and i know those precious tenths can add up to a substantial lead over the end of a run.
Since i run LRP motors, i have been conservative with timing/turbo boost... maybe i need to push the envelope a bit more. Thanx!!
Old 06-19-2010, 07:35 PM   #15199
DaveW's Avatar
I installed my fresh from Tekin RS, and made some adjustments based on the previous posts. My car was a rocket, and i had NO problems.
I got rid of the delay and tweaked boost, turbo, ramp, and my start/end RPM's. It was hot today (over 90 degrees) and i pushed my LRP x12 well into the 200 degree mark and it ran STRONG, with no fade and TONS of rip. I ran NO fans today, and the RS never got over two LEDs for temp.
Old 06-19-2010, 09:30 PM   #15200
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
Default LED Error 1&2, 6&7
Team Tekin,
Just came back from the track today & my ESC started to have some problems during my Mains. The 1&2 & 6&7 LED is flashing. I have steering, but no roation on the motor. Tried all the suggested work around & no joy. Where do i send this ESC in? Is this going to be covered in my warranty. I bought this ESC recently. Is there any out of pocket expense to have this repaired? Please advise.
Thx,
John
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 06-20-2010, 01:49 AM   #15201
StevenOlsen's Avatar
HI DaveW
could you post you setup here, curently running a SP but would like to try my X12
Steven
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 06-20-2010, 02:40 AM   #15202
Originally Posted by StevenOlsen View Post
HI DaveW
Steven
Steven, I thought you were running the LRP SXX SS?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 06-20-2010, 02:47 AM   #15203
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Originally Posted by DJGonzo69 View Post
Team Tekin,
Thx,
John
Hi John
1,2 & 6,7 is wrong Motor type selected, I have not had this happen but I did reset a mates esc that had changed for no reason, check the setting for motor type.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 06-20-2010, 03:09 AM   #15204
dawgmeat's Avatar
what set-up did u run
dawgmeat is offline   Reply With Quote
Old 06-20-2010, 03:42 AM   #15205
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Would like to see the setup also . Quick question. How does the Tekin stack up against the new speed passion/ hobby wing ESC's?
Fast XXXS is offline   Reply With Quote
Old 06-20-2010, 04:43 AM   #15206
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
re phrase your ? how does SP/HW stack up to a Tekin
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-20-2010, 04:45 AM   #15207
20 SMOKE's Avatar
Team Tekin,
Thx,
John
hook up the HW and re flash and re calibrate,if it doesn't fix then it may have to go back,also make sure connections are good and nothing crossing over
Jamie W
Old 06-20-2010, 05:11 AM   #15208
jrxs-r's Avatar
Guys.... setup here for TC10.5 Rubber Carpet. Basketball court sized track.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 06-20-2010, 05:13 AM   #15209
stiltskin's Avatar
Trader Rating: 102 (100%+)
Team Tekin,
Thx,
John
Like others have said, it indicates wrong motor is selected. If you have any solder crossing between two poles, it will give you the same fault. It could be a very small sliver, but it will be enough to jack you up. Check the solder on the motor as well. Either place will cause this fault.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-20-2010, 05:21 AM   #15210
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Here's another one for the same track.. i beat him hehe
-Mark
ps. lol zack.. boosto! haha
File Type: pdf Tekin - PRECC - Winter Champs (20100620).pdf (484.8 KB, 115 views)
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
